Old 16th November 2016, 02:50 PM   #1
corrado26
corrado26's Avatar
Default Iron Khanjar
A collector brought me this khanjar. Total length is 445mm, length of blade is 265mm, hilt and sheeth are made of magnetic iron, weight with sheeth is 499g.
Would like to invite comments by the specialists here. Thanks
corrado26
Old 16th November 2016, 03:23 PM   #2
Saracen
Saracen's Avatar
Late Qajar period (Persia), late 19th and early 20th century
Saracen is offline   Reply With Quote
Old 16th November 2016, 03:24 PM   #3
Saracen
Saracen's Avatar
double, sorry
Old 16th November 2016, 03:54 PM   #4
It looks Persian from the Qajar revival period.
Old 16th November 2016, 07:56 PM   #5
mariusgmioc
mariusgmioc's Avatar
Persian and Qajar, yes but there is something about the traces of pitting on the blade that makes me wonder whether it is not wootz.
Since the blade will benefit anyhow from some polishing, why not give it a try?
Even the hilt an scabbard could benefit from some polishing & etching as they have been very crudely cleaned, so much detail was lost.
I would polish the blade with grits 1000-2000-3000 then try etching it for wootz.
I would also polish the hilt and scabbard, gently, with grits not lower than 2000/3000. Then blacken it with Perma Blue and polish out the high relief with grit 3000.
But it is not my blade.
Old 16th November 2016, 08:33 PM   #6
Saracen
Saracen's Avatar
Слишком поздно для булата
Too late for wootz
Old 16th November 2016, 11:02 PM   #7
Thoughts on the blade:
1. Could the blade not be wootz but laminated instead?
2. Could the blade be older woozy and later repurposed?
Some possibilities I see for this blade being in Qajar mounts.
Other thoughts?
Old 16th November 2016, 11:15 PM   #8
Saracen
Saracen's Avatar
Грубоватые долы, крупное травление и последующая гравировка на клинке (соответствующая гравировке на рукояти и ножнах) - все за позднее изготовление клинка.
Rude valleys, large etching and subsequent engraving on the blade (corresponding to the engraving on the hilt and scabbard) - all for the later production of the blade.
Old 17th November 2016, 06:39 AM   #9
mariusgmioc
Yet, I have seen quite a few Qajar Khanjars with wootz blades. So, if it will be the case, this one won't definitely be an exception.
I guess that most of them were refurbished older blades.
Old 17th November 2016, 07:07 AM   #10
Oliver Pinchot
Wootz blades were produced in Iran into the 20th century.
Nasr al-Din Shah (r. 1848-1896) was responsible for a neoclassical movement in Iran, designed to counter European influence and stimulate the economy. Swordsmithing was revived and some very good wootz blades were forged. A number of the better examples bear his name.
Old 17th November 2016, 07:36 AM   #11
Saracen
Saracen's Avatar
Спасибо за эту информацию
Thank you for this information
