Old 9th November 2016, 04:37 PM   #1
donsamadhi
donsamadhi's Avatar
Exclamation Mughal? or Indian dagger?.
Hello
I`m writing to ask you for an identification of the dagger. Probably it comes from the period of the Mughal Empire`rule but I`m not sure, it`s a specific item. The hilt is made from jadeit and the carved motifs on it are specific too. I have never seen something like that before. Or maybe it was made as another turistic souvenir?It`s difficult to say and the blade looks as it had been used before. It is incrusted with silver and contains some symbols perhaps Islamic . Please for more information.
Alex.
donsamadhi is offline   Reply With Quote
Old 14th November 2016, 10:40 AM   #2
ALEX
ALEX's Avatar
Hello Alex,
Your suspicion is correct, it is a "touristic souvenir". It is not Mughal. The hilt is Asian (could be Chinese), the blade looks like cut from sheet metal, not forged. In my opinion this is more a fantasy item rather than anything particular or authentic.
Old 14th November 2016, 04:02 PM   #3
Roland_M
Roland_M's Avatar
Originally Posted by ALEX
Hello Alex,
A touristic souvenir with a jade hilt, are you sure? The hilt seems handmade without machine driven tools and the corrosion on the blade looks old.
But I'm just a collector, not an expert and for my eyes the pictures are not good enough for a proper statement.
Some macro-pictures would be useful.
Best wishes,
Roland
Old 14th November 2016, 04:13 PM   #4
I too thought that it was a tourist or export item when I saw this. I agree with Alex.
Old 14th November 2016, 05:26 PM   #5
ALEX
ALEX's Avatar
Best wishes,
Roland
Hello Roland,
The hilt material does not look jade at all (i.e. nephrite jade), and the work actually does look machine made and very crude. There are tons of jade/jadeite/quartz daggers currently being produced in India.
The blade could look old, but if it is cut of sheet metal - the look is irrelevant.
The form is actually of Turkish kard (very vainly), but nothing is right about this one. Here's the proper SAMPLE
Old 14th November 2016, 11:04 PM   #6
donsamadhi
donsamadhi's Avatar
Arrow
I see, there are different opinions. So, I will try to give you more details. First of all , the blade is not made from the sheet metal! it is double edged blade made from resilient and quenched steel and it gives beautiful sound. It was etched from deep corrosion which covered it in the whole. That`s why it has got dark a bit.But the incrustation before was completely invisible. The blade is not flat at all, as it seems to be on the photos, but it is slightly cylindrical and it narrows to the edges. The carving on the hilt is not done mechanically, for sure! The specialist from minerals and rocks said that it was hand-made. He also claims that it has to be an old work because of the detrition which can be seen with the naked eye. Unfortunately , the photos don`t show it. It is jadeite for sure (so called jade) the scratch is white and the hardness points that it isn`t a nephrite, it is rare and worth. The problem is from what culture and period it comes from. I couldn`t find information about. The motifs are very original and unusual.
Tomorrow, I will give you more photos with high definition. I hope they will show much more to confirm what I`ve written above. It is difficult to take a good photo of it because it fades away, that`s why some attached photos have bigger contrast to show better the carving.
Thank you for your interests,
Alex.
Old 15th November 2016, 02:48 AM   #7
Oliver Pinchot
The blade is Ottoman from the beginning of the 20th century. The grip, whatever stone it is, is Persian work of the 1940s or 50s. It is what collectors call a "married" piece, i.e. two parts wedded together from disparate origins. These are often sold in bazaars and suqs in the Middle East and environs.
Old 15th November 2016, 07:08 AM   #8
mariusgmioc
mariusgmioc's Avatar
Alex.
Hand-made... maybe in the sense that the electrical rotating tool that was used to make it was held in the hand.
Examine the grooves and engravings on the hilt under 10x magnification. If they have a circular cross-section, they are machined with a hand-held electric tool. If they have a crisp, triangular cross-section, they are carved/chiseled with a chisel.
But in the end we all believe what we want to believe.
Old 15th November 2016, 12:55 PM   #9
ALEX
ALEX's Avatar
Oliver,
I never stop learning from you and being amazed by the depth of your knowledge. Thank you for that!
Marius,
Likewise, thanks for clarifying hand/machine made. This is also what I meant by that it seems made with electrical hand-held rotating tool opposite to archaic or antique carving.
Old 15th November 2016, 02:59 PM   #10
mariusgmioc
While, it is dificult to say from the photos, the material might be Onyx, which is found in abundance in Anatolia. The green or whitish varieties of Onyx not only look exactly like Jade, but also feel like jade to the touch and can be extremely misleading. I have seen also glass immitations of Jade that are extremely difficult to distinguish from real Jade (but those I have seen so far only in Chinese "jade" products).
Old 17th November 2016, 08:48 PM   #11
donsamadhi
donsamadhi's Avatar
Lightbulb Extra photos.
I attached better photos which shows that it wasn`t done mechanically
I think that Olivier`s opinion is the best, probably it was made as he said , from two different pieces of daggers. But is it a touristic souvenir??
Thank you all for your opinions, I`m waiting for more.
Alex
Old 17th November 2016, 08:53 PM   #12
donsamadhi
donsamadhi's Avatar
Lightbulb Blade.
The shape of blade.
Old 17th November 2016, 11:29 PM   #13
donsamadhi
donsamadhi's Avatar
Best wishes,
Roland
And of course you Roland
Best regards.
Old 18th November 2016, 11:36 AM   #14
mariusgmioc
Thank you for the additional photos!
Certainly very poorly machine milled. No doubts about that.
Also pretty sure it is Onyx, very abundant in central Turkey.
Sorry!
Old 18th November 2016, 12:00 PM   #15
mariusgmioc
You may want o have a look at my posting regarding Jade/Onyx in the Ethnographic Miscellania section of this forum.
Old 20th November 2016, 10:22 PM   #16
donsamadhi
donsamadhi's Avatar
I respect your opinion Marius ,the expert of minerals was thinking about the jade and bovenit. Finally he said that this is jade. The signs points to the use of simple tools, but there are some doubts. I see that nobody else wanted to comment that
Everyone can be wrong only by looking at photos. I always rely on the opinions of the other people. Thank you.
Best Regards,
Alex
Old 21st November 2016, 10:55 AM   #17
ALEX
ALEX's Avatar
Some experts call any green stone a jade, including green quartz, jadeite, etc. It depends what definition they use. "Real" jade is referred to as Nephrite, and can contain some quartz. You may see
THIS LINK
Old 21st November 2016, 09:40 PM   #18
mariusgmioc
1. Why am I pretty sure it is not Jade (Nephrite or Jadeite)?!
1.1 Jade was and is in big demand and commands rather high prices. Therefore, it is used on valuable pieces of certain artistic value and not wasted on "tourist" items.
2. Why am I pretty sure it is Onyx?!
1.1 Onyx of precisely this coulour is found in abundance in central Anatolia and comes very cheap.
1.2 Onyx is charaterised in that it has a layered structure with parallel layers (see the photo of the horse) which can be easily identified also in the hilt (see the first three photos). Albeit I have seen pieces of up to 3 centimetres thick without any discernable layer.
3. Why am I pretty sure it was machined with a rotary tool?!
1.1 The grooves have circular cross-section and display transverse parallel traces of the rotating tool (see photos 5 and 6).
1.2 The entry/exit point of the tool is round (see last photo).
But I am definitely not an expert.
Old 23rd November 2016, 12:48 AM   #19
I must also add that the motifs and style of carvings on the hilt are not typically Mughal. Closest I have seen are more related to Persian, but the quality of the carving again is not like that found in Persian ivory hilts (albeit a softer material).
I must also agree with the possibility of dremel tool work looking at the micro-pictures.
Old 23rd November 2016, 02:31 AM   #20
I'm also with Marius et al. - clear signs of modern tools (and low quality work, sorry).
Old 23rd November 2016, 10:38 AM   #21
mariusgmioc
As Oliver pointed out, the blade looks rather typical Turkish made and the decorations on the hilt look Persian style, yet, they are quite different from the genuine Persian works.
The blade also looks rather thin and flat like cut from sheet/band stock steel and not forged.
So I would bet on Turkish origin, attempting to immitate Persian style.
Old 1st January 2017, 05:56 PM   #22
donsamadhi
donsamadhi's Avatar
Default Happy New Year! :)
Dzięki wszystkim za komentarze i pozdrawiam,
Alex
Hello everybody
I see there are a few comments since I last was here. I have to say that it is unlikely that there is some using of tools type dremel. The hilt was made at the latest time 1945-1948 and it is solid information. I think there could be used some rotary tools but I doubt they were powered by electricity. The stone is rather the bowenit and for sure it isn`t an onyx.
Thank you for all comments.
Best regards.
Alex
Old 2nd January 2017, 04:49 PM   #23
I think Oliver was, as usual, very polite and generous. The silvery decoration on the blade looks very "Syrian" to me. The blade /tang transition ( shoulders) are not even straight, with a gap at the point of insertion. The carvings are crude and, IMHO, made with Dremel tool. On that I am in complete accord with Marius and Battara.
My 5 cents worth is that it is a pretty crude and unprofessionally-made tourist item made somewhere in the Middle East within the past 10 years. Turkey and Syria come to mind in the very first row of candidates.
Old 2nd January 2017, 06:12 PM   #24
iskender
Wink according to a popular saying !
" die hoffnung stirbt zuletzt" crude translation "hope is the last to die" iskender
iskender is offline   Reply With Quote
Old 3rd January 2017, 12:58 PM   #25
donsamadhi
donsamadhi's Avatar
Question
I wonder why you are convinced of this dremel. The subject was lying for 50 years in one of the houses. I have total confidence! I know successor, the owner has been dead for 30 years. I observe the suggestion of a little discouraging ;/
