#31 | |
One can only wonder what further delights await down the hallway . By what method are they all suspended on the wall ? |
#32 |
Thank you for the kind words, I can tell you that the use of the walls in my family room and the hallway took a lot of (expensive) negotiation with my wife to get the space allocated.
MANOLO: Living here in South Florida expose my Keris to the highly corrosive enviroment that nature can provide, heat, moisture and an occational bad wind, this problem is solved with the exeption of the bad winds, by having the house at a nearly constant temperature using the air conditioning system year round, this also lower the moisture (humidity) content to an acceptable level. nechesh: I also have a constant desire to handle my pieces, which I do at least on a yearly basis, where they are cleaned and scented and oiled, and it seems to be working as I have noticed no corrosion on the blades. They are in fact very easy to get down the way they are mounted. RICK: The hallway is also occupied all the way down and so is the opposite wall in the family room but to a much lesser extend. They are mounted with three 1 5/8' white panel nails if they are on an angle, two where the gambar meet the gandar and one to support the angle. If they are hung straight just two is necessary. Once the nails are in place I use 28 GA green painted wire (corrosion free) between the two nails and they are locked in place, yet easy to take down and reinstall, the wire can be reused over and over. Best regards to you all
#33 |
A VERY NEAT DISPLAY OF KERIS, WITH THE WHITE BACKGROUND IT ALMOST LOOKS LIKE A FLOCK OF KERIS FLYING TOGETHER
I HAVEN'T BEEN ABLE TO ADD TO ANY OF MY DISPLAYS LATELY AS I CAN'T FIGURE OUT HOW TO HANG THEM ON THE CELING YET PICTURES OF OTHERS COLLECTIONS AND DISPLAYS IS THE NEXT BEST THING TO SEEING THE COLLECTIONS IN PERSON. THANKS FOR THE PIC'S GUYS IT ALWAYS MAKES FOR A GOOD TOPIC.
#34 |
Very impressive display of keris indeed Erik. Your collection has been one of those I've been secretly hoping to see and here we are even though it's only a glimpse of part of what you have. Thanks for sharing and wouldn't mind seeing more.
One must commend you guys for having good understanding wives for allowing displays even in family/public room/halls etc. I only have my private hi-fi room to play with and compromising some sound acoustics.
#35 | |
Actually it has been a long and delicate series of high level detante and negotiation that has allowed me to slowly spead my collection around the common spaces of my home and in general my wife has been very good about it. But i would actually prefer to have my own room for my collection since sometimes sharp and pointy delicate antique objects are not so good to have around during a party or when your friends want to bring their small children over. Erik, i wasn't questioning the care of you blades as i am sure you keep them in very good order indeed. My own personal obsession, however, requires that i handle each and every blade at least every few weeks so i tend to keep them all at ground level reach.
#36 |
This system is easy to install, change as needed, makes the knives accessible
and requires no special tools. 2 nails, some 28 gauge black wire and a brass or nylon washer. |
#37 | |
#38 | |
Some prefer vacuum tube amps I hear . http://www.thoraudio.com/ |
#39 | |
. They are great for female vocals, a favourite of mine...
#40 |
Ah ha !
Paul who owns Thor is an old schoolmate of mine . If you're into vacuum tubes then you're hardcore my friend . Now back to the subject at hand .....
#41 |
I've got small children, so display in my home is not an option. Here's a wall in my office. The sword hangers are handy, and permit me to easily rotate through examples from my collection.
#42 |
Andrew
Dhat display of yours looks wonderful Lew |
#43 | |
#44 | |
#45 | |
#46 |
Naga Sasra, that sweeping display just blows me away, fabulous even if many are out of reach. Speaking of out of reach, I put several items at ladder level several years ago after a good waxing:
#47 |
for me, the exposure, it is only when friends want to see my collection.
But in the future, I would have a room for my collection. 5 meters * 6 meters galvano |
#48 |
I hang the knives at the wall or I used magnetic stands.
Luc |
#49 |
Hey Luc, where do you get those stands?
#50 |
I do it myself & with a friend who can works the metal (cut sheet of metal)Luc |
#51 | |
#52 |
So while going across the web I found these pictures from a travel blog that might be inspirational and also show off some nice weapons
. and one of the best displays I've seen: Last edited by wepnz; 19th July 2009 at 02:01 PM. |
#53 |
wow... you guys have quite the collections amassed there...
If i could even have just 3-4 really nice antique ethnographic weapons I'd be contend for years... I have a couple machete-type blades and two swords, a folding knife, and a badik...
#54 |
Here are my displays:
#55 |
One of my 'old-style' displays.
#56 |
Well... nice displays folk.... I still have a small room wich is begginning to be overcrowded...
And that's nearly a half of my collection, newly aquired pieces toghether wiht stuff I would like to sell (reason downsizing my collection) the other half is with pieces I will never sale is kept in boxes, cos I'm renovating my appartment. Last edited by Valjhun; 19th July 2009 at 09:06 PM. |
#57 |
I look at the beautiful collections displayed in this thread and wonder about security in this modern age. It seems that ones personal property, which used to be respected by others, is no longer held in this regard. A shame, and an indicment on modern society!
The unfortunate thing about this is that one can no longer safely display their collection in an open room, and it needs to be kept in a secure place, out of sight. Unless one is fortunate enough to have a seperate room which can to some extent be "fortified", there remains only a large safe, or a hidden place to display ones collection. I have the latter, and although not large, only 2m wide x 600mm deep, it has doors which also serve as a display area, and will in fact hold quite a reasonable number of items. |
#58 | |
#59 |
Most keris are kept in their bags in a chest except for a few favorites which are displayed .
This is an old family chest which I have selected to store them in . A sort of Pusaka itself . ![]() There is a play on words in the crest . ![]() Yes Jose, it runs in the family ..
#60 | |
I do have one observation... The tension, and pressure on the sling of your awsome Martini Henry, will pinch it two, eventually. I've had similar happen to me.
