Old 9th September 2016, 01:09 PM   #1
Multumesc
Multumesc's Avatar
Default Old ax
Hello.I recently saw someone this weapon.What is it ?How old is it? Thank you for the answers.
Multumesc is offline   Reply With Quote
Old 9th September 2016, 01:16 PM   #2
Pukka Bundook
By the edge and the stampings, to me it looks very recent.
Also the scale -blackened look says recently forged.
Might be wrong though!
Richard.
Old 9th September 2016, 05:25 PM   #3
machinist
As for age I cannot say. I imagine this is more agricultural rather than a weapon, or at least a tool in peacetime and perhaps, in old days, a weapon in wartime.
Here is a similar piece (scroll down)If you use search terms like Hache de chais and Tranche-marc you may find more information, also the book Les haches, by Daniel Boucard.
machinist is offline   Reply With Quote
Old 9th September 2016, 05:43 PM   #4
You may also call it a coupe marc, as discussed HERE
Styles vary among the different regions (of France).
The short handle allows you to introduce it inside inside the whine press, to chop the bagasse, with short moves, holding it with one hand,; reason why its head is so heavy.
PS
It's Axe.
Old 9th September 2016, 06:06 PM   #5
broadaxe
Not a Coup-Marc but a hewing axe for squaring logs into beams. The blade is one sided and canted, and the short handle is correct, it was meant to be used single-handed.
There is a very similar weapon in the same style (usually from Styiria), but the blade is centered and sharpened from both sides, mounted on a 1.5m haft.
Old 10th September 2016, 11:48 AM   #6
Originally Posted by broadaxe
Not a Coup-Marc but a hewing axe for squaring logs into beams...
So it is ,
Old 11th September 2016, 11:10 AM   #7
Multumesc
Multumesc's Avatar
Default Old ax
