Old 22nd August 2016, 12:07 PM   #1
Cerjak
Cerjak's Avatar
Default JAPANASE 32 PLATES KABUTO HELMET FOR IDENTIFICATION
Who can tell me more about this Kabuto ?
Type and period ?
Any comment on it will be welcome.
best
CERJAK
Old 22nd August 2016, 02:27 PM   #2
mariusgmioc
mariusgmioc's Avatar
Type and period ?
best
CERJAK
Looks like a genuine and nice Edo era piece.
You may find more information if you post your question on the specialised Nihonto forum.
www.militaria.co.za (if my memory serves me right)
Old 22nd August 2016, 06:43 PM   #3
Cerjak
Cerjak's Avatar
Thank you I 've just post it in Nihonto forum in the katchu section.
Best
cerjak
Old 23rd August 2016, 12:58 PM   #4
asomotif
asomotif's Avatar
Is it magnetic ?
Old 9th September 2016, 07:16 PM   #5
Cerjak
Cerjak's Avatar
Originally Posted by asomotif
Is it magnetic ?
YES IT IS
BEST
CERJAK
Old 10th September 2016, 02:12 AM   #6
estcrh
estcrh's Avatar
Type and period ?
best
CERJAK
You have a 32 ken (plate), tetsusabji (russet iron), suji bachi (raised ridges / ribs) kabuto (helmet) with what appears to me to be a kuro usushi (black lacquer), tetsu (iron), ichimanjû shikoro (ichimanjû type neck guard)....."ichimanjû" means “one curvature” and with this type only the "hachitsuke-no-ita" (first lame) has any real curve to it. Ichimanjû shikoro have five or six lames, and they extend out and down rather than just out. There are several types of shikoro with some being similar to the ichimanjû shikoro.
The problem I see with this kabuto is the shikoro does not fit tightly against the "koshimaki" which is the plate that wraps around the lower part of the hachi (helmet bowl). This could be due to the fact that the shikoro is not original to the kabuto or it could just be loose as I can see that the rivets which hold the shikoro in place are missing, this is allowing the shikoro to raise up instead of being tight against the "koshimaki" making it look a bit un-natural.
One reason that a shikoro is removed can be that the hachi was originally lacquered and either the lacquer was in bad shape and needed to be redone or someone simply wanted the lacquered helmet bowl to look like russet iron. Re-lacquering properly can be expensive and russet iron often commands a higher price from collectors. It can be hard to tell if the helmet bowl was originally lacquered but you can look for tiny fragments of lacquer that were not removed, this would tell you for sure.
Below are images with arrows, the red arrows point to missing rivets that hold the shikoro to the hachi and the yellow arrows point to were the shikoro is riding above the edge of the koshimaki.
Old 10th September 2016, 02:19 AM   #7
estcrh
estcrh's Avatar
Below are some illustrations of various multi plate kabuto shapes, you can see which one most closely matches your kabuto.
Old 11th September 2016, 09:20 PM   #8
Cerjak
Cerjak's Avatar
Dear estcrh,
Thank you very much for your very interesting comment.
As you have mentioned most of the rivets which hold the shikoro in place are missing and in my previous photos the shikoro does not fit tightly against the "koshimaki but in the next photos you could see that now the shikoro fit perfectly againt the bowl.
I have spent a lot of time looking everywhere with magnifying lens but there is no one fragments of lacquer and so I believe that this kabuto is tetsusabji (russet iron),
Best
Cerjak
Old 11th September 2016, 10:48 PM   #9
estcrh
estcrh's Avatar
Dear estcrh,
Best
Cerjak
That looks much better, you can find replacement rivets online.
