Old 4th July 2016, 11:10 PM   #1
CharlesS
CharlesS's Avatar
Default An Attractive and Vicious Indian Battle Axe / Show Us Your Indian Axes!
The multitude of Indian battle axe styles and some of their strange, and dubiuous axe heads that sometimes make you wonder how they were used is a fascination for me. Just think of the many forms of the Chota Nagpur bullova axe.
This one is not one of the wilder more mind blowing versions of an Indian battle axe(in this case a saddle axe called a tabar, or tabarzine), but is aesthetically pleasing, very well made, and with a initially odd looking axe head that is perfect for a horseman. The axe is 29in. in length, with a 4.5in. wide axe head and a 4.25in. cutting edge. The axe head is beautifully forged from homogeneous steel. Note the barely noticeable temper line at the edge. The heavy axe is fitted with a steel bolster that is fitted on to a steel portion of the upper haft. Unlike some examples which have a steel bar reinforcement running partially down the haft, this one has a very thick steel bar reinforcement that runs down the full length of the haft, and is tightly held in place by steel rivets decorated with brass rivet covers. There is a steel ferrule at the end of the haft.
The axe is heavy in hand and I think would be a bit awkward for a infantryman, but in the hands of a horseman it would be deadly indeed. Note the subtle curvature of the blade's edge which allows for a powerful downward cut at an angle for maximum slashing, not unlike a shamshir, or a curved tulwar.
As a side note I am not sure of the reason for the humble chiseled area at the top of the blade that has been painted red...perhaps a armorer's mark?
Please join the thread if you are an Indo-Persian collector and show us your battle axe!!!
Old 5th July 2016, 09:05 AM   #2
estcrh
estcrh's Avatar
Charles, I m glad I did not bid against you, I have a similar one and decided to hold off. Not a commonly seen style.
George Stone shows some interesting axe variations in his book.
Old 5th July 2016, 08:22 PM   #3
estcrh
estcrh's Avatar
Indian axe, the very heavy steel head inlaid with brass and silver designs, the wooden haft reinforced with steel along its length and with applied brass rosettes.
Old 6th July 2016, 03:02 AM   #4
estcrh
estcrh's Avatar
A plain one of the same type.
Old 6th July 2016, 11:35 AM   #5
Royston
Default Tabar
That's a nice one Chearles
Mine has an all steel head and shaft with horn slabs.
Nice items. Not handled that many, but those that I have always seem well balanced.
The last picture is my Bulova collection.
Roy
Old 6th July 2016, 12:26 PM   #6
Royston
Default One more
This one has a very small, yet thick and heavy head
( That's a normal sized zippo).
The head alone weighs about 400 g which on the end of a 65cm shaft makes for a good impact.
Steel shaft this time with a one piece wooden grip rather than horn. Notice how it is not slotted all the way to the butt.
The brass ornamentation around the steel pins is almost identical in both axes.
Roy
Old 6th July 2016, 04:56 PM   #7
estcrh
estcrh's Avatar
Charles, as you pointed out to me the one I saw was not the one you now own, I should have looked closer. Here is the one I mentioned.
Old 6th July 2016, 05:01 PM   #8
estcrh
estcrh's Avatar
Here are some examples from Junagarh Fort Museum, India.
Old 6th July 2016, 05:21 PM   #9
estcrh
estcrh's Avatar
I have found this type being called "tungi", Indian, mid-19th century, curved iron head; wooden shaft painted with geometrical designs.Illustrated in "Islamic Weapons - Maghrib to Moghul" di Anthony C. Tirri", pag. 339, fig. 254B.
Used by the Khond people of Southern India.
Old 6th July 2016, 05:24 PM   #10
estcrh
estcrh's Avatar
Here is another two "tungi", the top one is from Terri's book, the lower one is mine, it has a very long shaft.
Old 6th July 2016, 07:32 PM   #11
CharlesS
CharlesS's Avatar
see below
Old 6th July 2016, 07:36 PM   #12
CharlesS
CharlesS's Avatar
Some amazing displays! Thanks for the input and sharing examples. The riveted haft certainly seems to the norm. That is the first I have seen with horn inserts, and it's very attractive.
Royston, the brass bands added to the rivets must make for an incredibly sturdy haft!
With the "tungi" I just couldn't help but wonder if the axe head was on backwards, but I suppose not.
In the the display pics the more "traditional" axe heads seem to predominate, but the "L" shaped heads with straight line edges were obviously popular too. I have always found those a bit odd to handle. I am assuming there was a certain method to maximizing their use.
Thanks again for the input, and the great pics!
Old 6th July 2016, 10:30 PM   #13
Norman McCormick
Norman McCormick's Avatar
My one and only Indian axe. Rattan shaft with steel finial top and bottom. Blade still sharp with original red 'paint'.
Norman.
Old 6th July 2016, 10:48 PM   #14
estcrh
estcrh's Avatar
The axe tungi axe head could have been made / mounted in a way that identified the individuals who used them as belonging to a particular tribe.
Here is another unusual example.
Burmese axe with curved head and fan shaped blade. The head cast and painted black and red. Octagonal head fits onto shaft with turned wooden handle,painted in bands of red, green, yellow and black. Tear-shaped terminal, 740 mm (Length). Given to the Field Marshal in Burma. Gunby Hall Estate, Lincolnshire.
Old 6th July 2016, 10:53 PM   #15
estcrh
estcrh's Avatar
Here is an L shaped Indian axe that I have, it looks like it originally had a spike at the top of the head and maybe some battle scares.
Old 8th July 2016, 01:51 AM   #16
estcrh
estcrh's Avatar
A couple more, described as being "Southern Indian".
Old 11th July 2016, 11:36 PM   #17
Timo Nieminen
Timo Nieminen's Avatar
My Indian axes (I have some unmounted heads, but I need to search to find them all for a group shot).
Long axes: The top one has a modern haft, but the head is supposed to be old. The bottom one is a beautiful 440g of axey goodness.
Short axes: The top and bottoms ones are modern. Second from the top is old. Second from the bottom is supposed to be old, but I think it's modern. But I like it anyway.
