This sword was sold recently. It looks like an early touristic object. But the blade is good and the guard is really well done. It's a short sword with a full brass hilt. Any idea??? Syrian, Arab, Turkish? 19th or 20th c.?? Best, Kubur |
Uncharacteristic sabre blade with a Saif hilt, thus I would consider it a SAIF.
In my opinion it would be extremely dificult to pinpoint the specific origin of this sword. My guess would be an Indian blade mounted somewhere in the Arabian Peninsula (maybe Damascus). But I am merely speculating. |
Thank you Marius
But the trophies on the guard are VERY Ottoman. Is it possible that it's simply a touristic sword made in Syria or Turkey? But if it's touristic, it's really well made... |
#4 | |
![]() Quote:
Regarding the "trophies" on the hilt, I don't think they are very relevant since the hilt itself is not very Turkish. But I'm again speculating. Let's hope there are more knowledgeable people who can shed more light on this one. PS: It appears the blade was etched to give it a grayish-old appearance. |
The hilt looks very Syrian to me, which was part of the Ottoman Empire.
Does the blade have an edge on it? I reminds me somewhat of swords made for Masonic ceremonies ("light of the orient", etc). Some of these swords were made fairly well.
How thick is the blade? It seems an unusual shape. The flat slab style makes me wonder if it was intended as something other than a weapon.
A couple of other options:
1. a cut down kilij/pala 2. a marriage |
The problem it's the third one that I see.
Maybe early 20th for early tourists or a kind of standard equipment, military? Why a short blade? tourist suitcase, child, on boat??? |
another
I could be way off on this...But I think I am seeing between the pictures a pretty clear casting line (a seam from casting with a two part mold). It looks like all the low points have been painted black (or in other words antiqued). The engraving doesn't have the kind of marks that push etching/chasing creates. But the faded incomplete lines of the etching look like what you get from casting. And the blade looks like it is pretty much a flat bar of homogeneous steel. It really looks like a prop blade. The kind of thing that would be used in stage acting, low budget movies, and parades/festivals. Maybe even a training blade?
#12 | |
![]() Quote:
#13 | |
![]() Quote:
You keep referring to this being Ottoman.....I would have thought that the Ottoman Empire was long gone by the time this sword was made........ |
#14 | |
![]() Quote:
Now, after seeing the second example, I believe it is much more likely a marriage between an immitation of a blade (cut from sheet steel) and an immitation of a Saif hilt. Last edited by mariusgmioc; 6th April 2016 at 10:19 PM. |
#15 | |
![]() Quote:
I might be wrong, but the blade appears to be made of flat sheet steel with some scandi grind to give it the appearance of an edge. Also the angle between the hilt and the blade gives away a decorative poor immitation of a sword. Now, after seeing this second example, I am pretty sure the first one is about the same. At first, the blade gave the appearance of a triangular (Shamshir-like) blade, but now I tend to believe is also plain sheet steel that might bend even if swung at an angle. |
#16 | |
![]() Quote:
#17 | |||
![]() Quote:
#18 | |
![]() Quote:
Cut from sheet steel made through industrial lamination would still qualify it for old? PS: I would bet that you are older than any of the two blades in the photos you posted. |
#19 |
I saw quite a few of very similar ones on the walls in Arab restaurants.
#20 | |
![]() Quote:
Generally speaking they are fine and even on the older stuff. Cheap modern mass production casting in comparison tends to looks more like this from what I have seen. High thinner cast line in some spots, but rounded off, with flat wider parts (a sloppy cast line). But it isn't the cast line (rather the quality of it) alone. It's that taken with everything else. The pattern balding out in some places. The black paint in the recesses of the pattern instead of copper chloride or zinc oxide build up. A tinge of brown smearing on some of the high points that looks like it could a thing layer of varnish. The wire wrap looking like it was part of the cast as well, instead of twisted wired actually wrapped on. Taken with the blade. It just looks cheap and newish to me. Maybe I am being overtly analytical and it is leaving me too much reservations. But a lot of losses on past vintage and antique flips has taught me to look for what is wrong about a piece, before looking for what is right about a piece. And if I saw this at the local flea market, an estate sale, or the local auction house...I would pass ![]() |
#21 |
Sorry. The computer decided on its own to duplicate my post :-(((
" Matrix" is taking over? |
#22 |
It reminds me of the "beater" sword I purchased, and posted, recently. Sorry.
#23 |
Another one, sold recently
exactly the same but with the scabbard, any idea? I still think at an old touristic sword around 1900... from where Turkey or Syria??? |
Display Modes | |
