Old 10th February 2016, 05:24 PM   #1
CharlesS
CharlesS's Avatar
Default Another Moro Kriss. This One with Arabic/Jawi(?) Script On the Blade
I have come across this unique kriss recently. I was primarily interested in the rarer hilt style, though it's on a later kriss(I believe first third of the 20th century).
The bonus on this was was the script, one side with the name in English and cursive, Walter Salomon. In doing a search for "Walter Salomon" I have found several of some note that would fit the era of the kriss, but no links to the Philippines.
The other side of the blade looks to be Arabic...or is it Jawi?
I have also noticed how closely this one's hilt resembles one Battara posted earlier:
http://www.vikingsword.com/vb/showth...highlight=jawi
Even the blade inscriptions are in the same style with the name here even clearer, but the Arabic/Jawi script quite different.
The pommel style here was of particular interest to me, but otherwise the fittings are quite plain, with the hilt wrapped in layered black lacquered cording, and not attached one band of cording to another, as we would typically see in Moro cord wrapped hilts. The metal bands are the lower end of silver alloy.
The original scabbard came with this kriss and it was broken to pieces and beyond repair, but definitely in a Maguindanao style. The one you see is its identical replacement.
I'm hoping I will be as lucky as Battara in getting a translation of the Jawi script, but seriously doubt this example can be attributed to Datu Piang.
Old 10th February 2016, 06:08 PM   #2
Very nice Charles. Congratulations! It doesn't look like the same name as Piang, but then again I don't read jawi.
I might place the blade a little earlier toward the turn of the century. Also the grenning, th "beak" on the ganga, and the scabbard are Maguindanao in appearance, so I agree.
Maybe Oliver can translate yours like he did mine.
Old 10th February 2016, 06:56 PM   #3
carlitobrigante
fascinating piece. Please keep up posted on how the research into Mr.Soloman goes!
carlitobrigante is offline   Reply With Quote
Old 10th February 2016, 07:32 PM   #4
Gustav
Most probably you can find him here:
https://archive.org/stream/acx2371.0...age/1/mode/2up
There is a misprint just on his name (Walter Walter is him):
https://archive.org/stream/acx2371.0...walter+salomon
and another misprint in index:
And perhaps his daughter:
http://easthamptonstar.com/Obituarie...l-E-Salomon-96
Gustav
Old 10th February 2016, 09:05 PM   #5
CharlesS
CharlesS's Avatar
Amazing work Gustav. With a name like "Salomon" it likely can't be anyone else other then the one you found. His appointment in 1911 goes along perfectly with how Battara and I guesstimated the age of the kriss.
Thanks SO MUCH for this incredible help!
Now, if we can just get that Jawi translated.
Old 10th February 2016, 09:18 PM   #6
Gustav
You are welcome.
Gustav
Old 11th February 2016, 09:51 AM   #7
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Salaams All....What Script?... It says in English Walter Salomon...The Arabic on the other side says exactly the same !! Walter Salomon. Arabic proceeds without showing vowels wltr slmn and no capitals.
Ibrahiim al Balooshi.
Old 11th February 2016, 12:32 PM   #8
CharlesS
CharlesS's Avatar
Thanks for helping us complete the translation Ibrahiim.
