Old 13th January 2016, 12:45 PM   #1
Kubur
Kubur's Avatar
Default Giant Koumiya
Any comments about giant koumiya unlike the one sold by Oriental arms?
He said: "The actual use of such big Koumaya dagger is still a mystery: It is definitely old, early 20 C. and not a tourist souvenir. Is it for ceremonial use? or may be an advertisement to a Koumaya maker?? In any case it is an unusual and interesting authentic item."
I agree it's an authentic stuff. Some of them have real good blades others don't, but they are all old. early 20 C & end of 19th.
Kubur
Old 13th January 2016, 01:29 PM   #2
Helleri
Helleri's Avatar
Could you better define Giant? I don't know the size of the relatively small one, so I don't know the size of the larger one. Also I was told that large simple butte rings instead of Riveted bails with all the attention the rest of one has = tourist knife. I don't know how true that is though. Because most things in history have been made to varying degrees of quality.
Old 13th January 2016, 04:37 PM   #3
As Lily von Shtupp from "Blazing Saddles" used to say, " What a nice guy...."
Old 13th January 2016, 06:25 PM   #4
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Originally Posted by Kubur
Kubur
Salaams Kubur see http://www.vikingsword.com/vb/showth...roccan+daggers and or type in Moroccan daggers to Forum search. I think it is the "Gendarmes Hat" style. Shown at my post on #6. (Chapeau de Gendarme)
Ibrahiim al Balooshi.
Old 13th January 2016, 08:59 PM   #5
Kubur
Kubur's Avatar
Salaam Ibrahiim,
Yes they are chapeau de gendarme.
The biggest 60cm and the smalest 40cm.
Shukran for the link!
Kubur
Old 14th January 2016, 08:09 PM   #6
Kubur
Kubur's Avatar
I will reply to myself... I can't be disapointed.
Here a photo of Stone's glossary with the same huge koummiya, look at the siz of the dharia to compare, impressive...
Old 14th January 2016, 08:20 PM   #7
kahnjar1
kahnjar1's Avatar
Don't really think you can compare sizes from this illustration. It is a drawing, not a photograph and would not be to scale.
Old 14th January 2016, 08:43 PM   #8
Kubur
Kubur's Avatar
Of course its to scale, its clear! and its a photograph...
Or maybe a drawing after photograph, the book is a mix of photos and drawings.
Do you have it? Have a look...
Old 14th January 2016, 08:58 PM   #9
kahnjar1
kahnjar1's Avatar
In order of your statements... No, Possibly, Yes and Yes
Old 14th January 2016, 09:22 PM   #10
Salaams Kubur, I think the chart you have supplied from Stone is about sufficient though I have to agree with it being somewhat blurred perhaps because it is a sketchograph ... however, I note the daggers you present are there in the chart ...Possibly at 8 and 3... Can you confirm that...and are they both Hat of the Policeman styles?
I think it would be a good idea if you can to stick up the key to that chart which would serve Library well for those who dont have Stone ... Hats off to that if you can
Note. Perhaps Stone missed the important Talisman 5 geometric decoration at the hilt of the largest in the chart and at #1 ? ; 5 fingers of the Hand of Fatima design.
Old 14th January 2016, 10:46 PM   #11
Helleri
Helleri's Avatar
I took the image into gimp to see if I could squeeze a little better detail out of it.
Old 14th January 2016, 11:23 PM   #12
harrywagner
harrywagner's Avatar
Default Stone's?
Great looking Koummya. Thanks for sharing. Is this the book that page is from: A Glossary of the Construction, Decoration and Use of Arms and Armor in All Countries and in All Times? Crazy title, but what a great reference page! Is the rest of the book as good?
Harry
harrywagner is offline   Reply With Quote
Old 15th January 2016, 07:05 AM   #13
kahnjar1
kahnjar1's Avatar
Harry
Hi Harry, Yes, and yes the book is worth getting hold of if you can pick it up. A good reference book though unless you know what an item is called it can take time to find it.
Stu .
Old 15th January 2016, 02:15 PM   #14
harrywagner
Default Stone's hook
Stu .
Thanks Stu. I just purchased a paperback copy from Amazon. I would have preferred a hardcover but the difference in price sure makes the paperback appealing! This author has another book, also on Amazon, with an almost identical title, except that it ends with "... All Countries and in All Times, with some closely related subjects". That book can be had for the price of a modest lunch. Does anyone know if this is a second edition, or if it is worth buying if you already have his other book? Thanks again!
Harry
Old 15th January 2016, 02:46 PM   #15
Kubur
Kubur's Avatar
Harry
Hi harry
It's the same book, different editions...
A little bit old but useful, enjoy!!
Kubur
Old 15th January 2016, 03:16 PM   #16
harrywagner
Default Thanks!
Hi harry
Kubur
Thanks!
Old 16th January 2016, 06:21 AM   #17
Default Koummya in Forum Library.
Salaams All...see this ~
http://www.vikingsword.com/ethsword/koummya/index.html
and type into search; Moroccan Daggers.
Old 16th January 2016, 07:44 PM   #18
Kubur
Kubur's Avatar
And the best link is
http://nimcha.fr/koummya.htm
This guy is amazing, he should write a book!!
Kubur
Old 16th January 2016, 09:18 PM   #19
Iain
Iain's Avatar
Kubur
The author of the site is a member although I don't believe he's been active for a while. I recommend the 1939 paper referenced at the bottom of his web article.
Old 27th January 2016, 10:19 PM   #20
archer
Default Gaint Koumaya
A link to Giant koummya 24 inches OAL. Here is a normal sized heavy all steel one 15 3/4 inches OAL , the blade is chrome plated and it doesn't appear to have been put into use. Windows 10 has complicated photos. I'll try to get it working, It looks to be the same style as others shown. Steve
Old 28th January 2016, 12:26 PM   #21
Kubur
Kubur's Avatar
I can't see your pictures...
To wait another big daddy....
Kubur
Old 28th January 2016, 01:46 PM   #22
Richard G
No's 23 and 24 from Stone's Glossary, are presumably the "Met. Omani" khanjar posted by Kubur on the "Omani Khanjar (Jambiya) for Comment" thread.
Richard
