Old 9th January 2016, 12:29 PM   #1
Cerjak
Cerjak's Avatar
Default Dagger with fullered blade for id.
This dagger has horn grip decorated with a white bone flower.
Anny comment on it will be welcome
Old 11th January 2016, 11:39 AM   #2
Fernando K
Hey there
Perhaps, I will say something that is obvious, the sheet seems to be a broadsword adapted, modified, as you uploaded a later post.
Affectionately. Fernando K
Old 11th January 2016, 04:52 PM   #3
Cerjak
Cerjak's Avatar
Hi Fernando
It is a interesting supposition but in this case because of the shape of this blade the original blade used to made this dagger should be a much more wider blade may be 7 or 8 cm .
I will add later the dimensions from this dagger so you could have a better idea of the proportions
Best
Cerjak
Old 11th January 2016, 04:59 PM   #4
It will be interesting to know how this will develop .
Old 13th January 2016, 12:08 PM   #5
Cerjak
Cerjak's Avatar
In fact this dagger if made from a sword blade could be from a blade about 4.5-5 cm wide.
I could superposed this dagger on top of this this Dussage blade in order to have an idea of the geometry of a possible original blade and has exactly covered it .
This Dussage has its blade about 4.5 cm near the hilt.
So it ‘s a possibility that this dagger could be a broadsword adapted but I don’t have picture from a blade fullered till the tip .
Old 13th January 2016, 02:59 PM   #6
Roland_M
Roland_M's Avatar
This dagger has some characteristics of an early scottish Dirk.
But i am unsure, i will check my literature, when i am back from work. I have a feeling, that i have already seen this type of dagger.
Roland
