Old 21st November 2015, 10:43 AM   #1
AHorsa
AHorsa's Avatar
Default Not an arm or armour, but maybe you can help
I just received this french ground find. Diameter is 4cm and it seems to be made of bronze. It is showing the counterfeit of a 17th cent. person. Does anyone of you have an idea what this could be/was used for?
Cheers
Andreas
AHorsa is offline   Reply With Quote
Old 21st November 2015, 04:04 PM   #2
Maybe posting this in the 'miscellania' forum might be better suited ?
Old 21st November 2015, 05:29 PM   #3
belt plate? horse harness decoration (horse brass)?
Old 21st November 2015, 06:38 PM   #4
kahnjar1
kahnjar1's Avatar
Maybe a seal for using with sealing wax? Frankly I have no idea but just a suggestion.
Stu
Old 21st November 2015, 09:01 PM   #5
disregard
Last edited by A. G. Maisey; 21st November 2015 at 09:03 PM. Reason: wrong suggestion.
Old 21st November 2015, 09:30 PM   #6
A Senefelder
I have no idea what this is but thought it odd that the two holes were punched from opposite sides, one punched front to back, one punched back to front ( as shown by the remnants of the cone created by driving a sharp implement through the metal ).
A Senefelder is offline   Reply With Quote
Old 22nd November 2015, 01:04 AM   #7
Oliver Pinchot
Appears to depict Leopold I Holy Roman Emperor (1640-1705)
also knows as "Hogmouth" for his distinctive Habsburg chin.
Old 24th November 2015, 07:58 PM   #8
AHorsa
AHorsa's Avatar
Thanks for the answers!
Yes, those holes seem to be drilled unprofessional through the metal. VBut in old times before it landed in the ground.
@ Oliver: Possible, but I´m afraid the many noble persons of this time looked like that.
There is a rest of some connection or the like left on the left side (picture of the back). Maybe this can give a hint...
Thanks and best regards
Andreas
Old 3rd December 2015, 12:49 AM   #9
Dave T.
"...thought it odd that the two holes were punched from opposite sides, one punched front to back, one punched back to front ( as shown by the remnants of the cone created by driving a sharp implement through the metal )."
I think I see the reason for the holes coming from different directions. The design on the disc is repousse work, where the thin metal is hammered from the back side to create a raised design. If one tried to drill or punch a hole where there was a hollow under the thin metal it would distort the design. You would flip the piece whichever way would put the thin metal directly against a firm backing surface (like a block of wood or lead) before you tried to punch a hole at that spot. The hole on the left was in a depressed area of the design, so it could be punched without flipping the disc onto its face.
Dave T. is offline   Reply With Quote
