Old 21st November 2015, 03:49 PM   #1
harrywagner
harrywagner's Avatar
Default Pesh Kabz?
I am inspired by Shakethetrees Pesh Kabz ( http://www.vikingsword.com/vb/showthread.php?t=20743 ) to try and identify this knife. The seller thought it was a Pesh, but it is unlike the Afghan Pesh I have seen. The chisel work on the blade and guard look Indian to me. Does anyone recognize this? TIA for any help!
Harry
harrywagner is offline   Reply With Quote
Old 21st November 2015, 06:20 PM   #2
A.alnakkas
A.alnakkas's Avatar
I like those, the quality is nice, but are newly made in Afghanistan as far as I know. Some are nicer, with all metal construction. The dealers from Afghanistan in Sharjah souq sell these often.
Old 21st November 2015, 10:17 PM   #3
mahratt
mahratt's Avatar
It is a modern knife ...
Old 22nd November 2015, 01:45 PM   #4
harrywagner
Thanks. It may be recently made. I don't have a clue as to its age, but am all ears if someone else does. Can you provide any supporting text for this assertion? Thanks again.
Harry
Old 22nd November 2015, 06:01 PM   #5
ward
I would suggest you look closely at the engraving. It is to crisp you see this with mechanical engraving. Basically they use a pc hooked up with a engraving drill. I have also seen this used on older pieces to add some flash.
Old 22nd November 2015, 06:38 PM   #6
harrywagner
Thanks. The engraving does look too perfect, and the blade doesn't look as old as the bone and wood used in the handle. I think you are right. I'll put this one down as contemporary Afghan. Thanks again!
