Closed Thread
Old 13th November 2015, 12:30 PM   #1
harrywagner
harrywagner's Avatar
Default Javanese Keris?
This is a fairly recent purchase. I believe it is from Java, but only because the seller thought so. I imagine is was meant as a display item, but could also have been a tourist piece. It is not a weapon (IMO). I like the split blade and the little guy that serves as the hilt. He looks like he is wearing a baseball cap, which I find amusing. Comments welcome.
harrywagner is offline
Old 13th November 2015, 03:10 PM   #2
I wouldn't call it a display item or a tourist piece Harry. You haven't really provided very good photos for a better assessment though. I do suspect from what i can see that yours is a fairly recent one, late 20th century or later. Very hard to tell without clear close-ups though. The crack was probably intentional rather than being a forging flaw, but it is hard to tell in the photos.You are probably right that this keris was not intended as a physical weapon, giving this long crack in the blade. Keris serve many purposes within Javanese culture and sometimes their purpose is more talismanic than practical. They also serve as an aspect of formal dress. So no, this wasn't made specifically as a wall hanger. There is some lore about the mystical power of gazing through such openings made in the blade. When these openings are made with this purpose in mind it is called combong.
David is offline
Old 13th November 2015, 06:07 PM   #3
harrywagner
Default Better photos
Thanks David. Here are what I hope are better pictures. I agree about the split blade being intentional. It makes the piece even more interesting. I like it, whatever it's intended use. Here is the info the seller provided:
"Indonesian Keris from Yogyakarta region (Java). Carved wooden hilt represents mythical serpent Nanga Sasra. The Wilah (blade) is wavy (13 dapor lok) with elaborated forging pattern (pamor) and a slot representing the mythical serpent Nanga Sara."
Old 14th November 2015, 01:30 AM   #4
The description of this keris given by the seller is not quite accurate.
The blade is 13 luk, pamor is adeg in the body of the blade, and probably what we can call a "flame" pamor in the base ( I can give a Javanese name for this, but I will need to spend more time on analysis of this little patch of pamor in the sorsoran). It is probably a 20th century blade, but I cannot be certain of this from photos, no matter how good.
The wrongko (warangka, scabbard) is Solo (Surakarta) gayaman, which is the informal, everyday style, the wood can probably be classified as kayu pelet, it might be timoho, but I cannot tell from a photo. The pendok (metal scabbard cover) is bunton style, the photos are not good enough for me to identify the embossed motif, but it is most likely lung-lungan ( twining vines and foliage).
The jejeran (ukiran, hilt) is a Madurese style, depicting a serpent, it would be legitimate to describe this as a jejeran with naga motif. The mendak (hilt ring between hilt and blade) is a Central Javanese kendit set with pastes.
The only thing wrong with this keris is the hilt, it is totally out of place, it should be taken off the keris and displayed separately as a miniature sculpture. This existing hilt should be replaced with a Solo planar style of hilt, preferably a yudowinatan model.
Do this and you will have an absolutely correct Solo gayaman keris that could be used for wear on most occasions. It is a recent keris, but most definitely not "tourist", or "wall hanger". It is the real deal, but get rid of that hilt, it does not belong.
A. G. Maisey is offline
Old 14th November 2015, 09:49 AM   #5
Jean
According to the EK and the Pamoratlas this pamor pattern with a triangular motif at the base and pamor Adeg above it is called Junjung Darajat and said to originate from Madura or East Java. Personally I am not convinced that the void in the middle of the blade is intentional.
Jean is offline
Old 14th November 2015, 12:04 PM   #6
harrywagner
Default Replaced hilt
Thanks A.G. and Jean. The seller bought the hilt separately, and it is a replacement. The original hilt, not pictured, is rather plain and also wood. It looks similar to the hilt I have seen on many Keris. I will post a photo as soon as time allows. Thanks again.
Harry
Old 14th November 2015, 07:07 PM   #7
Sometimes "plain" is better Harry simply because it is more correct. These fancier naga hilts are not only recent carvings, they are newly imagined forms that are a bit untraditional. Doesn't mean they are unattractive necessarily or should not be collected as the tiny sculptures that they are. But Alan is quite correct that this hilt doesn't belong on this keris. Something like this would be far more suitable for this keris.
David is offline
Old 14th November 2015, 09:12 PM   #8
harrywagner
Thanks David. The original hilt looks almost exactly like the one in your photo.
Old 14th November 2015, 09:15 PM   #9
harrywagner
Hi Jean,
I'm not sure either. The seller thought it was. I'll post some close-ups as soon as time allows. Thanks for the info!
Old 14th November 2015, 09:40 PM   #10
The blade is Madura or East Jawa, most likely Madura, but even so, the pamor in the sorsoran has several possibilities, and at the moment I cannot see it clearly enough to be too positive about what I'm looking at, I'm not at home right now and I'm using a very small, very cheap notebook.
The blade crack probably started as a cold shut --- a welding flaw --- but would then have been preserved and refined to make it into a magically charged complong that will capture beautiful women and late model Maseratis for you, simply by looking through the crack at them and wishing.
Old 14th November 2015, 09:42 PM   #11
harrywagner
Many thanks for this incredible information. This is very generous of you. I could not be more surprised by your last paragraph! I have a modest collection, but of the knives I do have I was sure this one was a display or tourist item. I am very happy to know otherwise. I am not a purist though so a tourist item or display piece would not be out of place in my collection, but it is still nice knowing it is not.
I bought two Keris from this seller. He has never let me down. I had not planned on posting photos of the other one, but am re-thinking that. I was certain it was a display piece. Now I am not so sure.
Thanks again for the info. Much appreciated.
Harry
Old 15th November 2015, 09:00 AM   #12
This post concerns the pamor motif found in the sorsoran of Harry's keris.I've now been able to see it clearly, and I've been able to access my records.
Jean has nominated junjung darajat.
I have never seen junjung darajat, but my understanding is that it combines a small patch of ujung gunung, which is a miring pamor, with one of the mlumah pamors, my notes do not mention combination with another pamor miring.
Personally, I am inclined to regard this keris as having dwi warna pamor, that is two pamors in the one blade.
One of those pamors is adeg, this is clear, but the other pamor?
I feel that we have 4 or 5 possibles:- Putri Kenurung, Bawang Sebungkul, Sombro, Pengasih, and maybe the outside possibility of Slamet.
From these I'd be inclined to put my money on Pamor Sombro. When Sombro is combined with a second pamor the two pamors together can sometimes be given another name, but there is only mention of it being combined with mlumah pamors, not with miring, thus I feel we must regard this blade as dwi warna:- adeg sapu + sombro.
Old 16th November 2015, 03:42 PM   #13
harrywagner
Hi Jean,
Here are some close-ups of the blade. The seller thought the split was intentional. I think it adds interest to the knife, so if it was an accident, it was a fortunate one!
Harry
Old 17th November 2015, 09:11 AM   #14
Jean
Hello Harry,
Thanks for the pics, I maintain my opinion that the split is accidental but if you like it, that's OK!
I attach the pic of a typical blade with combong, as you can see the void in the blade is due to the wear of the grooves in the sogokan.
Jean is offline
Old 17th November 2015, 11:00 AM   #15
I agree with you Jean:- is is accidental, but it did not look like it does now directly after the weld failed. It started as a cold shut, an accident, but it was preserved and improved into a magical blade feature.
The thinking is:- this was given to us by God, who are we to refuse it? no, I won't try to get the weld to take, I will accept God's gift and enhance it.
Old 17th November 2015, 04:08 PM   #16
Jean, while i have often seen people refer to holes worn through sogokan by excessive access washing i do have to wonder if this was the original intention of the term combong (or complong). I have seen blades where such an opening is obviously the intention of the smith and have to wonder if people calling these worn out blades "combong" is just a way of adding special interest where none should really exist.
David is offline
Old 17th November 2015, 06:37 PM   #17
Jean
Hi David,
I don't know and frankly I have not a very strong interest in these blades
If you search "keris combong" on Google you will find many pics of combong blades in the 3 categories (wear, welding flaw, and intentional). There is for instance a "special kamardikan keris" with an obviously intentional combong.
BTW Dr Google does not seem to recognize the term complong and I must say that I never heard it.
Jean is offline
Old 17th November 2015, 07:47 PM   #18
Oh David!!!!
You doubter!!!!
Goodness,gracious me!
Old 17th November 2015, 08:18 PM   #19
Jean, in reading, or listening to Javanese, there is a problem that I doubt exists in most --- maybe all --- other languages.
Words change form in both sound and spelling and still mean the same thing.
Linguists refer to Javanese as a "non-standard language", I'm not quite sure exactly what the academics mean by this, but my experience tells me that the only way to understand Javanese is to let go of preconceptions regarding sounds and spelling and try to grasp the overall context. In conversation you need to be reading body language as carefully as you are listening to words.
The word "complong" means simply a hole, or a gap, or an opening, its use is not only in respect of keris.
This word "complong" could be rendered by any other combination of the vowels and consonants used in construction of the original word, provided that it sounded reasonably similar, or if in conversation the other party was totally tuned into the conversation, under which circumstances it could well become something like "conpongipun", or "kekerconipun", or some other invention of the speaker. Clever native speakers of Javanese paint with words and in exchanges with close friends or family do not always stick with recognised forms.
If we consider the word "keris", in friendly conversation this will sometimes become "keferis", which in turn can have "ipun" added to it = "keferisipun".
Just to clarify:- I do not speak nor understand Javanese sufficiently well to always be able to recognise the Javanese use of language I have described above, I am repeating what I have been told by Javanese native speakers.
You possibly know of "Cockney rhyming slang" ? "noah's ark" = "shark", "trouble & strife" = "wife" and so on.
Its a similar sort of thing with spoken, non-formal, Javanese.
The words "complong" and "combong" both mean "hole".
Both words can have a number of completely different meanings and forms, depending on context.
Neither word, in any of their forms, refers uniquely to keris.
Old 17th November 2015, 08:39 PM   #20
Oh David!!!!
You doubter!!!!
Alan, you can just call me Thomas...
Jean, i don't really have that much interest in keris with holes eroded through the sogokan or for that matter keris with forging flaws which are then exaggerated to appear intentional. I am, however, very interested in keris with more of a mystical nature and i am indeed interested in keris where a combong has been placed in the blade by the smith with purpose and intention. That is why i am trying to make the distinction.
I suppose that given the literal translation of the word combong/complong as "hole" that any hole in a keris can legitimately be named as such. However, i am aware of the lore which assigns a specific mystical nature to such holes and what i am questioning is whether that mystical assignment began with intentional openings in the blade or whether it is also valid for these worn-through examples. It does seem to me that the worn-through variety receive such attention simply to increase the desirability of an otherwise worn out blade. But i am not claiming to know the answer here, only question it.
David is offline
Closed Thread
