Old 24th September 2015, 03:37 PM   #1
Default Pamor
Question;
Is there a specific name within the Keris world for blades that have distinct differing pamors on each blade face?
With thanks
Gavin
Old 24th September 2015, 05:20 PM   #2
Dwi Warna, Gavin IIRC .
If I'm not someone will be along to correct the error soon .
Old 25th September 2015, 03:28 AM   #3
Thanks Rick,
I ran it through the translator to get an understanding of the literal translation;
Dwi was not recognised but Warna is colour so if I was to hazard a guess this would be double colour?
Could this term then be used on a blade that also shows two pamor on the one face of the blade?
With thanks
Gavin
Old 25th September 2015, 03:53 AM   #4
http://www.vikingsword.com/vb/search...earchid=519555
Old 25th September 2015, 04:17 AM   #5
Some helpful reading, thank you.
Gavin
Old 25th September 2015, 04:21 AM   #6
I thought it the best way for me to help you, Gav .
Old 26th September 2015, 11:04 AM   #7
in this context of pamor, 'warna' means pamor.
'dwi' = two
'tri' = three
'panca' = five.
thus dwi warna = two pamors, tri warna = three pamors, panca warna = five pamors
Last edited by A. G. Maisey; 27th September 2015 at 09:03 AM. Reason: after effects of anaesthesia
Old 27th September 2015, 01:36 AM   #8
Hi Alan,
Am I correct in the application of these words being that it can refer to both a differing pamor to each face and also differing pamors to one face or is there more specific terms when drilling down this much.
With thanks
Gavin
Old 27th September 2015, 02:15 AM   #9
no gavin, these terms only refer to differing pamors that are the same on each blade face, when you have a different pamor on each blade face it is called pamor tangkis and is considered to be a protective device against black magic.
Old 27th September 2015, 10:52 AM   #10
Thank you Alan.
Old 27th September 2015, 12:56 PM   #11
Keris tangkis example.
Old 28th September 2015, 11:49 AM   #12
Gustav
On Lombok different Pamor on each blade side is called Pamor Seliwah, according to Ir. H. Lalu Djelenga.
Old 28th September 2015, 12:17 PM   #13
Thank you Gustav.
I am wondering about the name in other keris cultures too, Malaysia, Southern Thailand, Sumatra, Bali and the many others...Would Bali fall under the Java name perhaps?
Gavin
Old 28th September 2015, 12:21 PM   #14
[QUOTE=Gavin Nugent]...Would Bali fall under the Java name perhaps?/QUOTE]
I doubt.
Old 17th February 2021, 11:25 PM   #15
i am resurrecting this old thread because i just encountered this name Pamor Seliwah regarding such pamor in Lombok in another place so this can confirm that name to a certain extent, though it is quite possible this other source got this info from Ir. H. Lalu Djelenga to begin with. I believe in Jawa this would also be referred to as keris tangkis.
Here is my humble example.
