Old 20th December 2005, 05:56 PM   #31
nechesh
nechesh's Avatar
Mans, why would the snout have to protrude more to be hanuman. It still looks like a monkey to me. We often see Ganesha, Siva and other deities and demons depicted in a variety of forms. I don't see how you can say this could not possibly be a hauman because it's snout isn't long enough.
Kai Wee, if the provenance is there for Javanese origin then you are undoubtable correct. It is interesting that in later Balinese blades we still see form and appearence that is closer to these earlier Jawa keris than what we see in later Javanese keris. For instance, the custom of polished blades that we normally associate with Bali used to be the normal practice in Jawa. Much the same happened when Yoruban music moved to Cuba in the diaspora. The Cuba music stayed truer to it's origins, perhaps in an attempt to maintain it's identity with Africa while the music in Africa continued to evolve and change. Beautiful blades regardless.
Old 21st December 2005, 02:40 AM   #32
Mans
Mans's Avatar
Indeed, very difficult to identified about the Abstract hilt. So many arguments and interpretations which came out from our mind...
I just thought that the Hanuman smiles not like this one
But, what ever it was, This hilt is very impressive, isn't it ?
Kai, I agree that the Old Balinese keris resemble with Javanese. But I think the Balinese has the histories it self although any the Javanese touch So, the Balinese keris still has characteristic it self.
Here the link for example the old Javanese Keris (before Majapahit Era):
http://keris.fotopic.net/c684298.html
http://keris.fotopic.net/c450928.html
http://keris.fotopic.net/c618304.html
Majapahit Era (1300-1500s):
http://keris.fotopic.net/c645331.html
http://keris.fotopic.net/c669644.html
http://keris.fotopic.net/c785067.html
Mataram Era (1600-1700s) :
http://keris.fotopic.net/c451023.html
http://keris.fotopic.net/c710134.html
http://keris.fotopic.net/c461570.html
We can see that the Javanese keris still different with Balinese, specifically at some Ricikans on Sorsoran.
I think the 1st keris which you posted is an impressive old Balinese keris on Early Mataram period 1500-1600s). Very beautiful workmanship. Same with your Balinese kris which you collected
Mans is offline   Reply With Quote
Old 21st December 2005, 04:46 AM   #33
nechesh
nechesh's Avatar
I think the one thing we can all agree on is that ALL the hilts displayed in this thread have been impressive.
Still, i'm not sure i even see the smile on this one the way that you do and i think we would need more angles and better pictures to ever begin to come to any real conclusions here.
Thanks for the links to all those beautiful keris. I would like to point out the difficulty in using these keris in comparision to keris which have been in collections for as long as the ones in Jensen's book have. The examples you display show the wear and erosion of centuries of acid baths and staining, while Jensen's examples are pristine as if recently made, having not received such treatment. Certainly many of the blades you show were once much more robust with the ricikan more intact and better developed. These blades would have once been polished in the way Balinese keris typically are, but that look went out of style in Jawa and the rough etch appearance came into mode. So comparisons are tough. Therefore, i think i'll sit on the fence awhile on this one. With one low quality photo of only a part of the blade we really don't have enough information to argue about. I suppose that even if this blade were collected in Northern Jawa it could still have had a Balinese origin. But i have seen Javanese blades of similar character. I wouldn't bet the farm either way.
Old 24th December 2005, 02:16 PM   #34
Mans
Mans's Avatar
Yes you right that to distinguishing of the Javanese keris is too difficult. So that why many people must doing hard to learn about its .... and often some of them has frauded, kept strong them firm although they has a wrong knowledge We can't say anything because the keris is also bring the convictions on each of them, aren't they ?
Usually, I used so many keris to learning its. It is a method which can make us esier to learn and distinguishing the Javanese keris. We'll know the keris which has a good workmanship (Garap), Good ironwork and pamor, also we can know about the Tangguh and Pakem (estimated made).. but still difficult, isn't it
About the Acid Bath (Warangan), it is an a part of the whole on the Keris Cultures. To give the warangan, we must do some phase from Mutih/Methak, nyelup 'till give it the keris oil. It is a very difficult activities and complicated too. We must know well about the characteristic of the iron and pamor material and when we should take away the keris from Warangan in order to get the optimal output. So that why just a few people can and wish to do it.
Old 24th December 2005, 04:01 PM   #35
nechesh
nechesh's Avatar
Hi Mans. I'm not sure if you misunderstood me or if you just wanted to add the above information. I wasn't implying that the examples in Jensen's book would not have received warangan treatment, but since they have been in museum collections since the 1600s they did not while the Javanese blades you show from the same era were washed over centuries with much blade erosion. Hard to compare physical attributions between them comsidering. It is also my understanding that Javanese blades were once polished in the manner that we gererally see Balinese blades. This makes comparison even more difficult since these Jensen examples appear to have such a polished finish while your examples have the rough etched finish that has become the custon in Jawa as well as other islands.
Having spent the last few years working on my skills with warangan i can attest first hand to the difficulties of blade staining. I have had to stain some s few times before getting them "right" and still have a few i've done that need reworking. But when you get it right it is very satisfying.
Old 25th December 2005, 12:10 AM   #36
BluErf
BluErf's Avatar
I think it is wholly possible that different regions of Java had different styles of kerises at the same time. Java is a big place and can hold many courts, many kingdoms at the same time, and I believe at least a couple of them did co-exist in different parts of Java at the some time. The kerises in Jensen's book were, I believe, collected in the coastal areas (Pasisir), which could have keris styles similar to the Balinese courts - big robust blade with prominent ricikan. The kerises in the other areas could have been like what Mans have been posting - relatively petite blades with wide sor-soran and narrow middles and tips. I've seen these in some keris books as been attributed to 16-17th century too.
Old 25th December 2005, 12:11 PM   #37
Mans
Mans's Avatar
I mean, I just need to add informations that if we need to learn about the Javanese keris, we must indentifying and know when the keris came not or with warangan, because warangan process is a part of the whole the keris culture at Jawa. Rough or smooth condition also shown where the keris from. For example, if keris from Majapahit and Sedayu era, it must be smooth although it give Warangan. But if the keris from Madura Pamekasan, Cirebon, or Pajajaran, usually more rough. So, the conditions of the blade shown the technique of iron and pamor work, then we can distinguishing each keris from period and regional. The conditions of the blade is just 1 from many aspects to analysing the keris
Old 25th December 2005, 02:22 PM   #38
Mans
Mans's Avatar
Originally Posted by BluErf
Hey, beautiful old Putri Satu hilt! I love the old stately look. Very nice and warm feeling.
Hei, you has nice Putro Satu & Putri Satu too. Very charming too
I think we'll got a cool feeling if we hold it..
You have many impressive collections Kai Wei
Old 23rd February 2006, 02:39 PM   #39
BluErf
BluErf's Avatar
I really should be saving the money for my wedding, but this was too good to pass up...
http://www.kampungnet.com.sg/modules...view_album.php
Old 23rd February 2006, 09:17 PM   #40
nechesh
nechesh's Avatar
Kai Wee, why on earth would you need a wife when you have all those beautiful keris.
That new one is a beauty...congrats!
Old 24th February 2006, 02:46 AM   #41
BluErf
BluErf's Avatar
...so that I can raise one or two keris nuts to carry on the tradition? Its a lucky thing my girlfriend doesn't visit this forum. hahaha!
Old 20th May 2006, 02:45 PM   #42
Alam Shah
Alam Shah's Avatar
Default Links to Members' Keris Galleries...
Besides BluErf's Keris Gallery, there are others from this Forum who had created their personal Keris Gallery in KampungNet. (Creating your own Keris Gallery is FREE).
rahman's - Koleksi Tok Penghulu
Alam Shah's Collection
Man's - Koleksi Hidayat
John's Collection
Raja Muda Collection
VVV's Collection
Simatua's Collection
Other Keris collectors are welcomed to create their own Keris Gallery in KampungNet.
No representative from USA, yet...
Old 20th May 2006, 06:33 PM   #43
fjfredericks
WOW, Now these are some nice collections! I may just have to start collecting Keris too!
fjfredericks is offline   Reply With Quote
Old 21st May 2006, 06:40 AM   #44
BluErf
BluErf's Avatar
Looks like we missed out the album of one of the best collector in Singapore - Tengkurizan's collection. It is very strong in Bugis and Malay kerises. Take a look, and you will be impressed.
http://www.kampungnet.com.sg/modules...bum.php&page=2
Old 21st May 2006, 11:12 AM   #45
Alam Shah
Alam Shah's Avatar
Default collection list...
Definitely agreed that this is one fine awesome collection. Hmmm... Tengkurizan is not logon as Tengkurizan... else would be included in the list. .
Old 23rd May 2006, 04:42 PM   #46
BluErf
BluErf's Avatar
No problems, Shah. We have the start of a great virtual keris museum on Kampungnet.
Old 24th May 2006, 12:57 AM   #47
Alam Shah
Alam Shah's Avatar
Another awesome keris gallery, here and others from this Forum who had created their personal Keris Gallery in KampungNet. (Creating your own Keris Gallery is FREE).
. Isreena - Tengkurizan's Collection.
Have a virtual tour.
Old 1st June 2006, 06:49 AM   #48
Isreena
Isreena's Avatar
Wink KNet
Oh.... How sweet you guys..... I'm sorry for not having the time yet to update my album in KampongNet. Will do it soon I hope...... You guys are the real "Masters" I'm just a small time keris collector. However, I am more than happy to contribute . I hope to see more collectors having their album in KNet soon?
Isreena = Tengkurizan
Isreena is offline   Reply With Quote
