Old 3rd July 2015, 08:02 PM   #1
rickystl
Default Mark on Barrel
Hello all.
Not sure if this is allowed. This barrel is from an Algerian long gun I recently Posted on the Ethnographic Forum. Thought maybe one of you European enthusiests might reconize it? Looks European (?) of some sort. Thanks for any help.
Rick.
Old 4th July 2015, 12:14 PM   #2
Andreas
It looks very similar to an Inspector's Belgian proof mark, of the type used between 1853 and 1877. If that is indeed the case, I would expect that the barrel would also have the EL or ELG proof mark, perhaps hidden under the stock?
Andreas is offline   Reply With Quote
Old 4th July 2015, 03:37 PM   #3
thinreadline
thinreadline's Avatar
Originally Posted by Andreas
Yes like a Liege Malherbe mark.
Old 4th July 2015, 06:29 PM   #4
Andreas
I meant the mark of an inspector of the Liége proof bench. Malherbe was a manufacturer, they didnt use a crowned M as their trademark but " PJ Malherbe a Liége"
Old 5th July 2015, 12:27 AM   #5
thinreadline
But they also did inspection work too. To give two examples on guns ...
1.
The attached picture shows a a Belgian Made Spanish M-1857 Rifle Musket .The buttplate is marked with Malherbe’s
(CROWN) / M mark.
2.
JC Militaria has a mid 1800's .59" Bore, Norwegian/ Belgian Military Kammerlader Breech Loading 'Under Hammer' Rifle. Breech Marked 'PJ Malherbe & Co, Liege'. A 554 A 554The breech
is Belgian manufacturer marked 'PJ Malherbe & Co, Liege'. The trigger
guard and action have matching numbers '148' and it has several small inspection marks including 'Crown Above M'.
Old 5th July 2015, 02:43 PM   #6
rickystl
Gentlemen:
Thank you very much for your responses. So, may I conclude this is likely a Belgium made barrel, with a Malherbe - Liege Inspector's mark ?
Rick.
Old 5th July 2015, 03:34 PM   #7
thinreadline
Originally Posted by rickystl
Gentlemen:
Rick.
That is what I believe is most likely, however , as we all know, native made weaponry was often 'enhanced' with European markings. Usually though, these spurious markings are easily distiguished. To my mind, this marking is genuine. But that is only my opinion.
Old 6th July 2015, 01:46 AM   #8
rickystl
Hello again.
Well, your opinion is much closer than mine, which was zero. LOL
I know what you mean about the spurios marks. They are usually detectable. But this looks like an obviuos "stamp". And your information makes complete sense. So I'll add this to the notes on the gun.
Thank you and Andreas for your information. A neat example of being able to utilize the knowledge on this Forum.
Old 6th July 2015, 08:12 PM   #9
thinreadline
Hello again.
Thanks Rick , thats a pleasure , and thank you for showing us your gun , it is a beauty !
