Old 1st July 2015, 03:21 PM   #1
CSinTX
CSinTX's Avatar
Default A Poleaxe like Halberd
This halberd recently made its way to my collection. It was originally located in a Chateaux near Versailles in really rough condition. The metal was cleaned and haft replaced. As you can see, the blade is shaped like a traditional poleaxe. It is quite heavy compared to most halberds. The languets seem to be much larger than normal and there is heavy reinforcement where they meet the head. I was thinking it might be circa 1475? Does anyone know of other similar examples? Thoughts on origin? Could it be 15th Century? As always, all comments are welcome.
Old 1st July 2015, 08:03 PM   #2
Marcus den toom
Marcus den toom's Avatar
I am no expert on halbeards, but i am quit sure it is more likely a late 16th century version than a 15th century version seeing as the shape does not match any i have seen in the early manuscripts i useally study.
Please, do you also have pictures of this piece before it was cleaned?
It is of course once own choice, but cleaning the steel and replacing the haft just made this piece so much less valuable, historically speaking
Old 1st July 2015, 11:31 PM   #3
Is the posted halberd so different from examples in 'German Landsknechts and their Captain' depicted in 'Kriesgordnung' by Hans Döring in 1545 ?
Old 2nd July 2015, 01:57 AM   #4
A Senefelder
I cannot tell from the pictures. Is the point of the fluke ( the back spike of opposite the axe blade ) thickened at it's tip?
A Senefelder is offline   Reply With Quote
Old 2nd July 2015, 02:14 AM   #5
Timo Nieminen
Timo Nieminen's Avatar
Looks mid-16th century. Though at least some of the elements of this style are seen on blades about 1500, most examples I've seen are mid-16th, and some are later. I don't think it could be as early as 1475.
How heavy is it?
Old 2nd July 2015, 07:52 AM   #6
ulfberth
Hi Casey,
Like Fernando says it could very well be a landsknecht halberd.
Here is one from the Wallace museum, and it has almost the same patina as the one you have, with the description:
Halberd Germany
early 16th century
Iron or steel and copper alloy
Length: 44.6 cm, blade and socket
Weight: 1.22 kg
Maker's mark Stamped
kind regards
Ulfberth
Old 2nd July 2015, 04:01 PM   #7
CSinTX
CSinTX's Avatar
Thanks everyone for your thoughts. I tried updating the images with better ones and it let me delete the old ones but not add the new ones. I will add them at the bottom of this post.
I did locate a poleaxe in the Wallace collection with a similar blade but of course it has the usual hammer instead of spike on the rear that is typical of poleaxes. http://wallacelive.wallacecollection...ype=detailView
Marcus, I do not have images of it before it was cleaned. It is my understanding that the haft was in tattered pieces. I understand the hesitation to restore such old items but sometimes I think it is warranted depending on condition.
Fernando, thank you for the great image. I guess to me, the difference is the curved blade. The halberds in your posted image have the more common straight line blade that angles forward. I do have another halberd that I got along with this one that is very similar to the ones in this image. I will try to get it posted soon. Interestingly, when you google search “Landsknecht halberd” many images come up of Landsknecht fighters with curved blade halberds so perhaps it would be a Landsknecht item. See image below-
Senefelder, the tip of the rear spike is slightly thick. I do not think most halberds of this time and design had the really thick “beak like” rounded rear spike found on the more slender Italian or later style halberds. The entire piece is thick and heavy duty likely reducing the need for it.
Timo, I will have to try to weigh it but with a replacement haft any number may be somewhat insignificant. I just know that in the hand it feels much heavier than the other examples I have studied.
Dirk, thank you for the fine example from the Wallace collection. It seems to bridge the gap between my piece and what we normally think of as a poleaxe.
Old 2nd July 2015, 06:01 PM   #8
... Fernando, thank you for the great image. I guess to me, the difference is the curved blade. The halberds in your posted image have the more common straight line blade that angles forward. I do have another halberd that I got along with this one that is very similar to the ones in this image. I will try to get it posted soon. Interestingly, when you google search “Landsknecht halberd” many images come up of Landsknecht fighters with curved blade halberds so perhaps it would be a Landsknecht item...
Still the straight edged and slightly inclined blade bears a position in the Landsknecht halberds records.
See below a publication by George Snook, depicting the photo of a halberd which he assumes as being a Landsknecht example.
Old 3rd September 2020, 04:23 AM   #9
CSinTX
CSinTX's Avatar
I recently lucked in to IDing this mark from a similar example and wanted to add the info to the record here.
"In the period from 1586 to 1591, Claus Lerchli from Kempten supplied Zurich with halberds, murder axes and bill hooks."
Old 3rd September 2020, 01:12 PM   #10
Good find, Casey .
Old 3rd September 2020, 03:45 PM   #11
ulfberth
good find indeed , halberd markings always are difficult , and this one remained unknown for some time untill now ....
Old 3rd September 2020, 09:56 PM   #12
BUCC_Guy
BUCC_Guy's Avatar
An excellent looking piece. Certainly worth the clean-up.
BUCC_Guy is offline   Reply With Quote
Old 7th September 2020, 12:51 AM   #13
M ELEY
Awesome to finally pinpoint any smith's marking or arsenal stamp on ANY piece! Helps to build the historic record and fill in the puzzle pieces! Good work, Casey!
