Do you recognize the mark on this short knife with a serpentine quillon guard? It looks like a crowned two headed flying dragon with a shield on its chest. What maybe letter N (maybe an I & V) is on the bottom left, with o and R on the bottom right.
The overall length of the knife is 8 ⅝ inches, and the width at the quillons is 2 inches. The blade is 5 6/8 inches long, and ⅛ inch wide where it meets the guard. The grip is ⅞ inch diameter at its widest point. These photos are copyright (c) 2015 by Dana K. Williams. All Rights Are Reserved Last edited by dana_w; 9th May 2015 at 02:37 PM. |
Mark:
I think this resembles the double-headed eagle mark of the Imperial Tsars of Russia. I have posted a picture of that mark below. Notice the crown that bridges the two heads of the eagle. This appears to be present in your mark also. The talons should be holding an orb and scepter, but corrosion on the knife blade conceals that area. Ian. |
#3 | |
#4 | |
Probably way off with this, but if this is a Russian imperial eagle, didn't Peter the Great decree that imperator should be used instead of tsar? Not sure if they used the IR abbreviation, but the 18th century would be a fit for the style of the dagger?
#6 | |
Dana:
I hope that we have not focused too much on a possible Russian origin for this emblem. The double-headed eagle is a much-used insignia, and Wikepedia notes the following: http://en.wikipedia.org/wiki/Double-headed_eagle The double-headed eagle is a common symbol in heraldry and vexillology. It is most commonly associated with the Byzantine Empire, the Holy Roman Empire, the Serbian Empire, the Russian Empire and their successor states. In Byzantine heraldry, the heads represent the Emperor having authority over both secular and religious matters, Byzantine emperors were regarded as Christ's viceregent on Earth. It also signified the dominance of the Byzantine Emperors over both East and West. In the Holy Roman Empire's heraldry, it represented the church and the state. Several Eastern European nations adopted it from the Byzantines and continue to use it as their national symbol to this day.There are many options to explore. An 18th C origin seems reasonable to me based on the appearance of the knife and scabbard. Ian. |
18th easily .
Or incredible forgery . |
#9 | |
http://www.habsburger.net/en/chapter...blem-habsburgs And there are things like the Coat of arms of Montenegro: http://en.wikipedia.org/wiki/Double-...Montenegro.svg But I do think your original guess is probably right. |
#10 | |
