Old 14th March 2015, 08:08 AM   #1
kahnjar1
kahnjar1's Avatar
Default POWDER MAGAZINE/BANDOLIER for Comment
Just received this interesting old belt/bandolier, holding tubes for measured charges of black powder. Origin was stated as Afghani but the brass buckle suggests Omani. Anyway a very hard to find item IMHO.
The 9 tubes are of bamboo??? with woolfibre stoppers capped with leather. The tubes measure 4 1/2" (115mm) and are approx. 30mm diam. The tops are decorated with inset white metal of some sort.
The leather pouch attached to the belt has a very hard to decipher stamp on the back which looks like: Middlemore & Lambert
1909
Birmingham
together with the large stamped letters M.R/O This is obviously an old British Military pouch of some sort.
Comments welcome.
Stu
Old 14th March 2015, 09:47 AM   #2
thinreadline
thinreadline's Avatar
The small pouch looks like one of the pouches from the 1901 Royal Navy Bandolier .
Old 14th March 2015, 10:05 AM   #3
colin henshaw
Nice piece Stu, with good honest wear. I like it. With the Omani type buckle, what about East Africa for origin ?
Old 14th March 2015, 12:28 PM   #4
thinreadline
Could the stamp say 'Middlemore & Lamplugh' ? This was a firm of Birmingham leather equipment manufacturers to the War Dept up to 1920 . What is it about the brass buckle that indicates Omani to you ?
Old 14th March 2015, 08:23 PM   #5
kahnjar1
kahnjar1's Avatar
Thanks Threadline. Yes the stamp likely says Middlemore & Lamplugh. As I said it is rather indistinct. Thank you for the clarification. However the pouch style is not the same as those shown in your other post. Yours show a single layer flap, and the one on my belt has a double layer.
In relation to the buckle, it is similar in shape and design to those used on most true Omani belts and has been discussed elsewhere on the Forum. This style appears to attributed to the interior of Oman....Rostag/Nizwa regions.
Attached is a pic of an Omani ammunition belt with the same buckle.
Stu
Old 14th March 2015, 08:32 PM   #6
kahnjar1
kahnjar1's Avatar
Maybe, as Omani traders/slavers were all over the region. The belt/flask of yours recently on the Swap Forum, I believe, also has an Omani belt, but merged with a flask from somewhere else in Africa.
Stu
Old 15th March 2015, 12:50 AM   #7
thinreadline
Thanks for that info re the buckle. My mistake re the flap . in that case your pouch is the Infantry Pattern 1903 ammunition pouch . This has the double flap and the 5th rivet to the rear which would have originally retained a brass 'D'.
Old 15th March 2015, 02:08 AM   #8
kahnjar1
kahnjar1's Avatar
Yep that looks like it. So it also fits with the 1909 date stamped on the back. I have no doubt that the pouch was likely "souvenired" from British equipment and used (maybe) to hold lead balls....sounds logical anyway.
Stu
Old 15th March 2015, 05:51 PM   #9
thinreadline
Stu
Yes that will be it ... the 1903 equipment although designed initially for infantrymen , it saw long service ( up to the late 1940s ) by mounted troops especially in India and South Africa .
Old 26th March 2015, 11:27 AM   #10
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
1909
Birmingham
Comments welcome.
Stu
Salaams Khanjar1 ... I last handled a similar set of charge, wadd, ball and belt about a year ago in Muttrah Souk... exactly the same material and I thought at the time ...bamboo...The buckle is indeed Omani and I remember writing something to library about the old cuttle fish bone moldings the master craftsmen used... Reading on I see the very uniform looking pouches are discussed successfully . The style of leather stitch on the rear of the broad belt section using a thick flat lace of leather curiously interwoven also appears to be the Omani style.
I definitely ought to have collected that old gunbelt as I'm sure it will have gone by now...However, next week I will take a look.
Ibrahiim al Balooshi.
Old 26th March 2015, 04:55 PM   #11
kahnjar1
kahnjar1's Avatar
Salaams Ibrahiim,
Thank you for the confirmation as to Omani origin.
Stu
