Old 28th December 2014, 10:03 PM   #1
drac2k
Default Newly acquired yataghan for comment.
I just acquired this yataghan and it is my first all metal handled one ; have them with bone handles, "glorified bone,"wood and horn, but not solid metal.The drag is a little different, indicative of some area that I've seen before, but I can not seem to remember.
Old 30th December 2014, 03:00 PM   #2
drac2k
Well, since no one has commented on my sword, let me now do so.I was just reading a post on this blog "titled favorites," sublisted "Black Sea Yataghans," and I noticed that the drag on those scabbards looked like the drag on mine(very distinctive), so could one infer, mine is from the same area ?
Old 30th December 2014, 06:00 PM   #3
TVV
TVV's Avatar
The reason that nobody has commented is probably because yataghans are very difficult to attribute as little has been written on the subject - Elgood has a nice chapter in "The Arms of Greece and Her Balkan neighbors" book, but it is far from a comprehensive guide on all the regional hilt varieties. Astvatsaturian has a typology in her Turkish Arms book, but it is somewhat questionable and debatable, as the author herself admits. The other books on the subject are catalogues - a few from Croatia, which simply list the yataghans in the collection of a Zagreb museum, and one from the Askeri museum in Istanbul, where everything is described simply as "Osmanli" in the notorious Turkish scholastic tradition when it comes to weapons that were found in areas once part of the Ottoman Empire.
To make matters more complicated, yataghans traveled throughout the Empire over the vast trade routes and fittings were replaced regularly according to the taste and means of local owners.
All metal hilts are usually associated with the Western Balkans, and the one on yours may have been made in Epirus. The scabbard is a separate addition and I cannot guess from where. Blades were produced in many centers and traded as blanks - unless the inscription contains the name and home town of the bladesmith, there really is no way of determining where the blade was forged with any degree of certainty.
Teodor
Old 30th December 2014, 09:31 PM   #4
drac2k
Thanks, Teodor, your post was very informative, especially the part about metal handles being from the Western Balkans. I thought, since the scabbard was very distinctive, it might lend a clue, especially since I saw some yataghans with such sheaths attributed to the Black Sea Area.
I realize that with posting, it is "hit or miss ;" I was trying to interject a little(a very little), humor .
Old 31st December 2014, 06:48 AM   #5
estcrh
estcrh's Avatar
I can not add much other then what I have observed on other yatagans. First, the scabbard is not your typical Ottoman scabbard so unless it is identifiable as being from a specific region or culture it will not help much. Second, the workmanship on this yatagan is a bit crude, it appears to have been rehilted at some point or repaired. This type with a metal hilt is not as common as others, here is another more ornate example.
Old 31st December 2014, 12:57 PM   #6
Originally Posted by TVV
The reason that nobody has commented is probably because...
...of the time of the year too
Old 31st December 2014, 02:23 PM   #7
drac2k
Estcrh, beautiful yataghan; is it yours ? I think you are absolutely right about it having been rehilted, especially since it is missing the extensive metal foil work at the hilt which usually accompanies these swords.I did notice some other similarities with your sword; first the heavy throat on the scabbard with a similar stylized design and could your sword also have been rehilted, since it appears that some of the inscriptions appear to have been covered up by the metal foil at the hilt ?
Old 1st January 2015, 04:44 AM   #8
I agree - most of these type of yats with these type of pommel "ears" usually come from the Balkans.
Nice piece. Have you tested the metal to see if it is low silver or white metal?
Old 1st January 2015, 05:23 AM   #9
drac2k
The handle is quite heavy, I originally thought it could be brass with a silver wash, however I didn't see any brass leaching out from under the silver color, so it has yet to be determined ; is there any other way to test for silver other than acid ?
Old 2nd January 2015, 12:07 AM   #10
estcrh
estcrh's Avatar
Yes it is mine and it appears to have been rehilted unless inscriptions were routinely covered over. I have a lot of yatagan photos but it was the only one I could find with a similar hilt and scabbard. If you compare the hilts they have the same basic shape, the scabbards both have a decorated throat and no chape.
