Old 2nd June 2014, 09:12 PM   #1
Kubur
Kubur's Avatar
Default Fake Persian axe??
Do you think this Persian / Qajar axe is a fake?
How to reconize a good piece??
Thanks
K
Old 3rd June 2014, 03:29 AM   #2
RSWORD
RSWORD's Avatar
How do you define fake? Modern made but in the style of Persian Qajar period axes? If that is your definition of fake, then no, this is not a fake. It is a late Qajar period axe. How do you recognize a good piece? Depends on what your definition of a good piece. What do you look for in a good piece? This could be considered a good piece for a number of collectors and this could be considered a fairly average piece for a number of other collectors. I think you have to determine what you are looking for yourself. Do you want a functional, battle worthy piece? Then this is not it. Do you want a piece that is probably of wootz steel? Then this is not it. Do you want a piece that has fine chiseling? Then this is not it. Looks to be an etched pattern. Do you want a piece that is legitimately Persian and of the Qajar period that would be used in theatre or ceremonies? Then this is a perfectly good example.
Old 3rd June 2014, 03:48 AM   #3
Oliver Pinchot
Couldn't agree more, Rick.
I would add only that, like most of this type, it is assembled in three pieces. Somewhere along the line, the head was inverted.
Old 3rd June 2014, 06:24 AM   #4
Cthulhu
Cthulhu's Avatar
I've seen these with the "tail" of solid metal, of hollow box construction like this, and also as simply a flat piece of metal of a vaguely similar shape. Do those represent further abstractions of each other, and are they from specific time periods?
Cthulhu is offline   Reply With Quote
Old 3rd June 2014, 10:25 AM   #5
Kubur
Kubur's Avatar
Thank you very much both!!
My question is related to some extensions between the pole and the blade.
In most of the Persian axes that I have seen there is no such little intermediary pieces (in red).
I'm right or wrong??
Old 4th June 2014, 12:39 AM   #6
Oliver Pinchot
Cthulhu's observation is a good one. By the latter Qajar Dynasty, more complex construction, and by extension, imagery, usually preceded simpler work. This was driven largely by expense: if a dragon's head which was cut out of sheet looked indistinguishable from one more carefully wrought when viewed in profile, a shift in production could take place quickly. Kubur's question as to the construction of the head and the appearance of the blocks indicate workmanship of a higher grade; this is supported by the complex construction of the pean as well.
Nasr alDin Shah Qajar singlehandedly revived the arms-making industry in Iran during the second half of the 19th century. The products wrought by smiths in this period are often of excellent quality. They represented a brilliant if brief rebirth of the armorer's craft before its ultimate demise.
Old 7th June 2014, 01:24 PM   #7
Currently it cannot be called a fake, because after 100 years anything becomes antique:-)
But it is certainly not a fighting example and never was. Any fighting axe has a wedge-like profile. This one is flat.
Decorative would be a better word.
Old 7th June 2014, 04:10 PM   #8
CharlesS
CharlesS's Avatar
I thought you might enjoy this period pic of a Persian "Fakir" with a very similar Qajar era axe of ceremonial type. In the pic it's a little hard to tell, but I believe the axe is looped over his shoulder in some manner and that he is holding a cane just below it. It almost seems as if the axe has been mounted on a wooden haft...but I can't see any point in that, so it may take a more careful look at the pic, thus my inclination towards his holding a cane.
He also seems to have a medallion of some sort looped around the axe.
Old 7th June 2014, 06:42 PM   #9
Kubur
Kubur's Avatar
Default Persian double head axe
Thanks all
Your photo is very interesting.
My question is:
We always say ceremonial, but these axes were used by Fakir and sufi in India and Persia,
then it was the same with the dervishes in Sudan.
All these people are connected by faith and by their axes...
I enclose one double headed axe that I guess is from the 19th.
and connected to what I said.
Any ideas, comments or more photos??
Old 8th June 2014, 02:43 AM   #10
machinist
Not much to add but a lovely picture of two Jewish dervishes supposedly from Iran and taken in the nineteen twenties.
machinist is offline   Reply With Quote
Old 8th June 2014, 05:17 PM   #11
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
See~
1. http://touba.tumblr.com/post/1021697...arvish-and-his
2. http://shahrefarang.com/en/qajar-dervishes/
for more examples.
Ibrahiim al Balooshi.
Old 8th June 2014, 05:46 PM   #12
Kubur
Kubur's Avatar
Default valuable object for an ethnographic collection
The second link is amazing!
Elf choukran
I wanted to say that 'ceremonial' means used by people (sufi or fakir)
not for battle, but it's still cool
I think that an object used is still a valuable object
if we follow the definition of an ethnographic collection
it's the same with African masks.
Kubur
