Old 20th May 2014, 09:40 PM   #1
Kubur
Kubur's Avatar
Default what is this? Ottoman Caucasian Balkans?
Hi everybody
Do you know what are these pistols?
Thanks
Old 21st May 2014, 02:32 AM   #2
trenchwarfare
trenchwarfare's Avatar
I've never seen anything like them. The grips are mounted on a frame, that is very similar to what you would find on a pinfire, or early rim/centerfire revolver. The fore end is unusual, with a "Schnabel" finial. The lock on the top pistol looks odd, like what you would find on tourista pieces from Turkey in the 1950s-60s. What are the grip panels made of?
Old 21st May 2014, 09:03 AM   #3
Runjeet Singh
Runjeet Singh's Avatar
Dear Kubur,
It is hard to give a definitive answer without seeing close-ups'. Even then it may not be possible! But it seems as though there is a mix of styles.
My guess would be Ottoman/Balkan - I have seen Ottoman pistols with later applied grips from Montenegro / Bosnia before - a possibility to consider.
Runjeet Singh
Runjeet Singh is offline   Reply With Quote
Old 21st May 2014, 07:52 PM   #4
Kubur
Kubur's Avatar
Dear Runjeet & Trench,
Thanks both
it is brass
it was my first idea, Bosniac/ottoman
but i found this Persian pistol who looks similar...
Any idea about Persian pistols?
Kind regards,
Kubur
Old 25th May 2014, 04:18 AM   #5
Oliver Pinchot
They're Balkan-- perhaps Montenegrin, interesting that the butts emulate the form of the Gasser revolver. Consider that when they were holstered or thrust through the belt, only the grips would show.
Old 3rd June 2014, 10:26 AM   #6
Kubur
Kubur's Avatar
I will do some photos of the grip.
Thanks!
Old 29th August 2014, 11:23 PM   #7
Kubur
Kubur's Avatar
Photos of the grips
Sorry... better late than never...
Old 1st September 2014, 10:28 AM   #8
RDGAC
RDGAC's Avatar
That looks like a very modern screw in the grip you show in close-up; is the grip, as it looks, cast brass? The screw holding the cock to the tumbler square also looks very new, and held in rather crudely with a washer; bit suspect. I'm wondering if these were knocked up for tourists.
Have you had a look at the lock innards, and checked to see if either barrel has a load down it?
- Meredydd
RDGAC is offline   Reply With Quote
Old 1st September 2014, 03:35 PM   #9
Kubur
Kubur's Avatar
Hello Sir,
I'm very afraid that you are right fro the screws.
The pan and frizzen are very well connected to the barrel.
But the cock is a little bit lose so the screw is probably new.
For the grips, they really look like original.
The overall impression of the gun is good, it doesn't look like a toy or a bad copy from Ankara/Istanbul.
I'm happy with the Montenegrin proposal of Runjeet & Oliver.
Best wishes
K.
