Old 15th April 2014, 10:42 PM   #1
CSinTX
CSinTX's Avatar
Default Lantaka Real Vs Fake
I recently purchased this and it appears real but I have some concerns with the bore. It looks to me like there is a layer of bronze that wraps inside the bore and the inside past that "might" not be made of bronze. It shows up pretty well in the pics. It doesnt look like it could have been fired like this because the muzzle looks to be smaller than the bore as a result. Ive noticed in other lantaka pics that its pretty common for the muzzle to be gnarly looking like this one is though but Ive never seen the inside of another one. The touch hole is round but not drilled with a drill round. It also angles slightly forward but is not clear all the way through. The muzzle measures to go 1/8" past the touch hole. It measures 47.5" and weighs 70 lbs. There is also what appears to be a piece of rusted steel inside the cascabel. Maybe for attaching the tiller or maybe the end of a steel pipe used to fake the bore? The trunnions appear that they were added separately. I don't know if that's normal or not.
Could anyone with any lantaka experience give me their thoughts? Thanks ahead of time!
I am currently working to resize pics and adding them to the forums upload.
Old 16th April 2014, 04:04 AM   #2
I think some shots that show the entire weapon would be helpful.
Old 16th April 2014, 04:05 AM   #3
Well, honestly, it looks wrong to me. The fuse hole looks too sharp. The inside of the bore doesn't look right and doesn't make sense. Even the front of the mouth looks odd to me to be cast. Is that a casting line I see? - not too sure.
Sorry to have to say all this, but this is what I see so far in the pictures. Perhaps other pictures, especially of the whole thing, might be helpful.
Old 16th April 2014, 07:16 AM   #4
CSinTX
CSinTX's Avatar
Thanks for your time guys. Here are some other pics I have. I can get more if it would help.
Old 17th April 2014, 10:47 PM   #5
While I have absolutely no knowledge of lantaka, and little on artillery in general, I am more than willing to spend some time looking through references so I can offer some thoughts here. It is a wonderful thing to learn, and this interesting example offers perfect opportunity.
It seems that these usually small cannon were typically mounted on merchant vessels throughout waterways in various archipelagos in Malaysia, Phlippines and Indonesia among others . From what I understand, these became not only important weapons as defense against pirates, but of course by the pirates themselves. Eventually these became items of status beyond their obvious use as weapons, and heavily produced for use in ceremonial cases as well as even trade items. With colonial presence there were many versions of these produced by Portugal and the Netherlands, with these being often intended for trade.
It is indicated that prior to the 18th century, there were iron pins to center the clay covered wood core which produced the bore. As the mold was broken open, these pins actually became part of the cannon itself, and later these iron residues became spotted rust in the bronze. Later in the 18th century it seems barrels were poured solid and the bore drilled out.
Without actually having this item at hand, and with the little exposure I have to them, I would have to defer to those more experienced, but I would ask if it appears this cannon could be fired. Going by the material I read, it would seem the cast lines (if that is what they are) would indicate early make and probably in these archipelagos. It is suggested that the European made examples had more refined casting. However, it is well known that Europeans often produced trade arms which were notably inadequate, obviously concerned about the results if insurgency should develop.
Beyond that, perhaps this one could have been for trade use among local tribes, in the sense of intertribal gift in wedding, currency etc. parlance?
Hopefully others will offer more on this.
Old 18th April 2014, 05:38 AM   #6
As far as I can see in the pictures so far, I fear that this may be a fake. There is an industry of fake lantaka making in the Philippines and Indonesia. There are certain features that indicate newly made pieces.
One good source for helping you since you have the piece in hand is this:
http://www.cannonsuperstore.com/fake_cannons.htm
Old 18th April 2014, 07:08 AM   #7
CSinTX
CSinTX's Avatar
Thank you everyone for your thoughts and opinions. I am trying to deal with the seller in an attempt to return the item. At first I thought I might have some luck but he is now refusing to accept it even though he offered a 3-day return option on the listing. Regardless of the outcome I will update this thread with everythig I have gathered. Some, I think is fairly interesting.
Old 18th April 2014, 02:25 PM   #8
Hi Jim,
Let me take a ride under your cape of 'absolutely no knowledge' and digress a bit myself ...
... Eventually these became items of status beyond their obvious use as weapons, and heavily produced for use in ceremonial cases as well as even trade items... Beyond that, perhaps this one could have been for trade use among local tribes, in the sense of intertribal gift in wedding, currency etc. parlance?...
In a manner that this gives place to a third category; besides operational and fake lantakas you have, as you well note, the ones used for other than firing ... intentionaly made for such purpose, with no thought for fraud. As long as you don't pretend that a determined lantaka is or was for combat, there is on step to consider before calling it a fake. At the end, there were probably more lantakas for multiple inland purposes than those aboard ships; this before junk ones were made for opportunity business. It is said that in some local wealthy people mansions, the surrounding walls were made of zillions of lantakas set upright.
... It is indicated that prior to the 18th century, there were iron pins to center the clay covered wood core which produced the bore. As the mold was broken open, these pins actually became part of the cannon itself, and later these iron residues became spotted rust in the bronze...
The so called cruzetas ... or chaplets
Here i upload two collectable valuable small examples of so called cannon money, a status achieved by non combat lantakas (and other).
One aledgely cast in Melaca in the XVIII century, in a style similar to those introduced there by the Portuguese and a triple barrel (as triple currency unit) cast in Sião during the XVII-XVIII centuries; a very rare example.
Old 18th April 2014, 05:39 PM   #9
LOL! Thanks Nando We can both have capes of zippetee do dah knowledge on these, but with you I know better.
Nicely presented explanation on these serving in capacity other than weapons, signaling methods and gifts or presentation items.
While it seems puzzling that these would be considered as a monetary exchange, I think it was more associated with status. As you note...look how many cannons he has!!! etc.
Obviously in later, or I should say more recent, years, it has become lucrative to create fakes, as well shown in the excellent link Battara added. As collectibles and antiquities have become prime commercial merchandise as well as 'investments' the industrious charlatans of varying countries have stepped up their production.
These days caveat emptor has reached astronomical dimensions!!
In this case, much as with the often harshly and arbitrarily labeled 'tourist' pieces in edged weapons, many of these are actually still part of modern native tradition and have their own place in these cultures.
It does seem that an attractive and formidable appearing cannon such as this would be a lucrative addition to a tribal 'portfolio', despite not ever being intended for actual firing. Though not exactly the same in analogy, with American Indians wealth was often measured in horses; in other cultures sheep or cattle; and so on whether livestock or tangibles.
With these cannon it does seem a bit inconvenient using these as currency though.....I mean, what is the change in transaction for two cannon? perhaps a pistol and some ammunition?
Old 18th April 2014, 06:22 PM   #10
LOL! Thanks Nando With these cannon it does seem a bit inconvenient using these as currency though.....I mean, what is the change in transaction for two cannon? perhaps a pistol and some ammunition? ...
Oh no; it was a bit like those copper bars and bangles they used (use?) in Africa for currency. The cannon form was just an allegory; not to be associated with weaponry, for what counts. In the maximum a symbolic representation of power. The currency basis is based on the bronze material
You would used them as a monetary means; from buying things to set up the value of a dowry, i would guess.
Old 16th March 2015, 04:02 AM   #11
CSinTX
CSinTX's Avatar
Sorry, I forgot to come back and update this thread after resolving the issue. The seller finally come through in allowing me to exchange it.
After much research, I feel that the lantaka shown here fell in the grey area of likely a money item and not meant for firing. However, typically the basic and early designs with open yoke are accepted as working pieces while the later more extravagant pieces were thought of as wealth items. I believe there also continued to be more basic designs produced as wealth items even after the accepted changes had taken place. This piece did test out to be made of all bronze except for the correct chaplets in place inside the bronze.
The most troubling part of this piece for me was the added material capping the end of the muzzle. Through research, I found a large percentage of "correct and antique" lantakas had the same feature. I am guessing during the construction process, there was reason for more material to be added at the end for some reason. Im not sure why, but it was definitely common. This can clearly be seen in this thread on the last picture at the bottom right- http://www.vikingsword.com/vb/showthread.php?t=4249. It can also clearly be seen in this example with good provenance. http://jamesdjulia.com/item/lot-1542...w-shinn-47729/
Finally, the casting lines would suggest it was made post 1800 with a two piece cast rather than the original method of a one piece cast.
Hopefully this will help someone at some point in the future.
Thanks,
Casey
