Closed Thread
Old 1st April 2014, 02:07 PM   #1
mjamerks
Default Strange Indo persian dagger info needed.
Hi All
Would like to know more about this dagger.
It has a rectangual blade (armor piercing?)
Walrus Ivory grip.
Some traces of gold to the blade.
Length is 40cm.
Maybe the steel is wootz but this is hard to see.
Would like to know age and origin.
My feeling says its Ottoman (court dagger)?
Would like to hear your opinions.
Thanks!
mjamerks is offline
Old 1st April 2014, 04:14 PM   #2
ALEX
ALEX's Avatar
It is Ottoman. Could be a marriage of Court dagger handle and a Hancer dagger blade. the handle could be retrofitted for crossguard or bolster, and the blade yet another later addition. it is of substantial age. Is the ridge on one side only? Here's another hancer dagger without the ridge.
ALEX is offline
Old 1st April 2014, 04:18 PM   #3
mjamerks
Originally Posted by ALEX
It is Ottoman. I think the handle could be a later retrofit for crossguard or bolster, and the blade is yet another later addition. Is the ridge on one side only?
The blade has 4 ridges and as far as I can see the grip and blade are very tight and looks like they Original to each other
mjamerks is offline
Old 1st April 2014, 04:31 PM   #4
ALEX
ALEX's Avatar
both handle and blade are of substantial age, so could be original or of same period. The handle had some sort of attachment in the past, so this made me think it was lost and blade added later.. just a guess. I've seen at least one Ottoman blade with 4 ridges, and it was quite old, around 17 century, so they are known. I think others may have more suggestions. Its an interesting dagger
ALEX is offline
Old 1st April 2014, 05:14 PM   #5
mjamerks
Hi Alex
Thanks for the info.
I would like to get the guard restored but have no idear what it has looked like,a ring or a crossguard?
mjamerks is offline
Old 1st April 2014, 05:44 PM   #6
ALEX
ALEX's Avatar
I'd advise not to add anything, and leave it as is. There's not much to base the restoration on and it's better not to disturb it's character and to leave it untouched).
ALEX is offline
Old 1st April 2014, 06:00 PM   #7
CharlesS
CharlesS's Avatar
I'm think it's a cut down and curved bayonet blade added to an Ottoman hilt and is clearly missing its original bolster....which may also have hidden the mystery of whether the two were meant to be together or not.
CharlesS is offline
Old 1st April 2014, 06:07 PM   #8
mjamerks
The blade has on the base on all 4 sides remains of gold inlay,so I dont believe its an old bayonet blade.see extra pics
mjamerks is offline
Old 2nd April 2014, 01:55 PM   #9
napoleon
nice walrus handle, i could be wrong but it looks like a marriage to my eyes,the blade looks like its from european smallsword re shaped perhaps
napoleon is offline
Old 2nd April 2014, 04:57 PM   #10
A.alnakkas
A.alnakkas's Avatar
Looks like a genuine item. Was there smallswords with 4 ridges made curved? everything is possible, but this item would have looked alot better if the missing part was there.
A.alnakkas is offline
Old 2nd April 2014, 05:02 PM   #11
mjamerks
If you see it in real you can see that the steel and shape of the blade is well made in that way,also the proportion in relation to the grip.
What can be the missing part shape etc maybe a simple silver ring of 5mm thickness?
mjamerks is offline
Old 3rd April 2014, 01:15 AM   #12
russel
The recesses in the ivory suggest a four-sided quillon arrangement to me. (just an idea)
russel is offline
Old 5th April 2014, 07:23 PM   #13
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Brown Bess Bayonet?
Ibrahiim al Balooshi is offline
Old 5th April 2014, 08:20 PM   #14
mjamerks
Brown Bess Bayonet?
The blade has 4 ridges and traces of gold at the base.
mjamerks is offline
Old 5th April 2014, 08:24 PM   #15
ALEX
ALEX's Avatar
I tend to agree, it is likely a bayonet blade. it's an old marriage though. the gold was added to make it more decorative
ALEX is offline
Old 6th April 2014, 12:16 AM   #16
spiral
Brown bess bayonets only have 3 ridges not 4.
But mjamerks although despite description of 4 ridges, this can not be seen in the pics, , can we have a photo of other side of blade & hilt please to confirm ?
Thank you.
spiral
spiral is offline
Old 6th April 2014, 02:07 AM   #17
Robert
Robert's Avatar
I believe that this shows both sides of the blade on this dagger as the hole in the hilt is broken out on one side and not not the other. I hope this is of some help until better photos can be added by Mjamerks.
Robert
Robert is offline
Old 6th April 2014, 10:59 AM   #18
mjamerks
Robert
Hi Robbert
Hereby pics of all 4 sides.
every side is 1 cm wide,the blade is exactly 30 cm long.
Martin
mjamerks is offline
Old 6th April 2014, 09:12 PM   #19
Thank you.
spiral
Lebel Model 1886 ? That has 4. It could perhaps be a cut down sword stick... or some variant gilded bayonet used in hunting..?
Old 7th April 2014, 07:39 PM   #20
mjamerks
The ridges of a lebel bayonet are much thicker,compared with this blade the ridge is very thin almost sharp also the point is different compared with a lebel bayonet.
Maybe it is not a bayonet at all but made in the shape it is specially.
mjamerks is offline
Old 8th April 2014, 08:46 AM   #21
Could be.. but doubtful... I suggest either a hunting bayonet remodelled as a dagger or one of the other weapons... a lancehead or snapped sword or sword stick fashioned into a dagger. see http://www.truefork.org/Photography/...ant_Angelo.php for a quadrangular blade...but there many possibilities.
Old 10th April 2014, 09:07 AM   #22
Then again~ what we could be looking at may be related to "Dague Miséricorde" style...
Ibrahiim al Balooshi.
Old 12th April 2014, 03:43 PM   #23
ALEX
ALEX's Avatar
The blade could be something similar to this. This one is not bayonet's, could be a spear, alam or something similar. I've seen another Ottoman dagger with a huge ivory handle and short 4-edged blade - an obvious old retrofit. these types are not common and likely old put-togethers from different parts.
ALEX is offline
Old 10th May 2014, 10:09 AM   #24
mjamerks
FYI
I will put this dagger for sale on ebay.
Rgds
Martin
mjamerks is offline
Old 10th May 2014, 10:19 PM   #25
Andrew
Andrew's Avatar
Thank you for the advice.
A
Andrew is offline
Closed Thread
