Old 18th March 2014, 04:05 PM   #1
Emanuel
Emanuel's Avatar
Default 3 large yataghan (T-spine, T-pommel, Turkish Ribbon)
Hi everyone,
After a long pause I recently acquired these three Yataghan. I am most attracted to this type of yataghan because they are substantial, heavy-duty pieces, much sturdier than the thinner, slimmer, fancier type. They also feature an integral bolster construction that doesn't actually seem to be that wide spread in European/Mediterranean/Ottoman weaponry.
The top one is a monster, with 29" (74cm) blade that is 1.3cm thick at the base. The bolster is almost 3cm wide. With a large horn T-pommel, the type is associated with Zeybek irregulars/mercenaries The blade has scratched decoration on the surface, can anyone decipher? The scabbard is wood wrapped with leather and green fabric strips, similar to the kind seen on some Surmene and Laz weapons. The rough scabbard throat and tip might be tarnished silver, or just steel. I think I see 1913 very roughly punched on the throat. An identical one is pictured in this old thread
The second one shows better quality, and I had thought it might have a Turkish ribbon pattern-welded blade. I will know after a trial etch. The large blade is 28" (71cm) long. The T-pommel had a piece broken off and reattached with some putty. It broke during shipping but I should be able to re-attach it nicely. The scabbard is leather glued over wood, with brass throat and tip. The blade doesn't fit in very well so maybe it wasn't original. This blade seems to have lots of silver inlay and overlay, made with the later triangular punch technique. Can anyone translate any of the cartouches? In one or two cases I'm not sure of the correct orientation.
The bottom one shows the best quality. The blade definitely has Turkish ribbon construction and it has nice brass inlay. It is dated 1239 = 1823. This would make it the earliest dated yataghan with integral bolster I have seen. The blade is still generous, at 24"(60cm) long and 1cm thick. The profile of the T spine is more refined and lighter than the larger two. Here is one with very similar blade.
Any thoughts of comments about the very large yataghan in particular and how they fit in what we know about this weapon style?
Thanks,
Emanuel
Old 18th March 2014, 04:08 PM   #2
Emanuel
Emanuel's Avatar
Default Top one
Detailed pics
Old 18th March 2014, 04:11 PM   #3
Emanuel
Emanuel's Avatar
Default Middle one
Not sure about the orientation on some of these.
Old 18th March 2014, 04:12 PM   #4
Emanuel
Emanuel's Avatar
Default Bottom one
And the nicest one
Old 19th March 2014, 06:52 PM   #5
Emanuel
Emanuel's Avatar
Originally Posted by Emanuel
Detailed pics
Do I read this correctly as a stylized 1279 = 1862?
Another inscription on the top yataghan.
Old 19th March 2014, 07:26 PM   #6
Zifir
Zifir's Avatar
I will start with the post #5:
As far as I see it's; li-sene 1331 / Year 1912/13
The inscription:
Lā fetā illā Ali, lā seyfe illā Zülfikār / There is no hero like Ali, there is no sword like his sword (zülfikar)
Zifir is offline   Reply With Quote
Old 19th March 2014, 07:53 PM   #7
Zifir
Zifir's Avatar
Post # 4
Maşae Allah, 1239, sahib Mustafa / As Allah wishes or willed (a phrase used to show appreciation -as well as to avoid casting a bad eye on something), Year 1823-24, owner Mustafa
Emmanuel can you post the rest of this picture, because I cannot be sure without seeing it.
Old 19th March 2014, 07:55 PM   #8
Emanuel
Emanuel's Avatar
Great, thanks Zifir!
That matches the 1913 on the scabbard then. So this makes the large yataghan the latest I have seen, and an example of 20th century production
This also matches what Sancar and others have said concerning these monster yataghan with T-pommel being more for show. The craftsmanship is quite poor, despite the large quantity of steel.
I will take better pictures of the inscription on the bottom one tomorrow.
Emanuel
Old 19th March 2014, 10:21 PM   #9
TVV
TVV's Avatar
Nice yataghans Emanuel, all testaments to the longevity of this blade design, which remained in use in Asia Minor and the Balkans until WWI. I believe there is a good chance at least 2 of the 3, if not all 3, have Turkish ribbon blades. Look forward to seeing them after you etch them.
Teodor
Old 21st March 2014, 09:39 PM   #10
archer burak
very good yatağans cong...
archer burak is offline   Reply With Quote
Old 23rd March 2014, 04:50 PM   #11
Zifir
Zifir's Avatar
Post # 2
Names of seven sleepers and their dog:
Yemliha, Meksalina, Mislina, Mernuş, Debernuş, Sazenuş, Kefestetayuş, Kıtmir
Old 23rd March 2014, 05:48 PM   #12
Zifir
Zifir's Avatar
Post #3,
similarly some of the names of seven sleepers:
but the rest are missing.
I am not very sure about the makers name, and I could not the second inscription.
Old 24th March 2014, 05:45 PM   #13
Emanuel
Emanuel's Avatar
Many thanks for the translations Zifir!
I think I pretty much covered all of the inscriptions but I will check and upload anything missing.
Just trying my hand at etching using 1:3 ferric chloride:water solution. I shouldn't have any problem with the silver inlay should I?
Old 31st July 2014, 06:26 AM   #14
sfenoid13
Originally Posted by Zifir
Post # 2
what language are these spelled in? it doesnt look like Ottoman..
sfenoid13 is offline   Reply With Quote
Old 31st July 2014, 08:48 PM   #15
Zifir
Zifir's Avatar
I believe they are arabified versions of Roman names.
Ottoman Turks probably learned them through Arab/Islamic sources.
Old 20th November 2023, 07:34 PM   #16
werecow
werecow's Avatar
According to the seller this yataghan is 113 cm long. Unfortunately not mine so I can't confirm it.
