Old 24th January 2014, 06:23 PM   #1
CharlesS
CharlesS's Avatar
Default Two Interesting Moroccan Koummya Daggers
I am glad to see Moroccan koummya daggers back as a focus of interest. I will add these two interesting examples to our archives.
Based on quality I am not sure the two examples belong on the same thread, but I purchased them both recently and will include them together here.
The silver example is 18.5in. long and has a 10in. long quality blade that is finely fullered and features a combination or numbers and letters stamped on one side. I imagine this is a European made blade...French??? Spanish???
Notice on this one that while the artwork is basic and rudimentary, its dimensions are more elongated and elegant than the norm. The scabbard and blade are more narrow than usual. The hilt is also narrow, but more typical, and it accentuates the elegant style.
The gold example is actually a scabbard made of gilded silver alloy in a detailed floral motif. This is a much earlier example being at least 100 years old and perhaps older. The blade here is the rarer "claw" style with a well defined fuller. The hilt is rhino horn mounted en suite. It is 15in. long with a 8in. blade and is 3inches across at the pommel.
Old 24th January 2014, 07:38 PM   #2
Martin Lubojacky
Being not an expert in koummyas, but having strange feeling that these two pieces are exceptionally interesting, I would like to congratulate you to your recent purchase !
Martin
Old 25th January 2014, 12:01 AM   #3
spiral
Lovely specimens Charles!
Any history with them?
I don't think the white hanger on the first is original though? it just doesn't look right... adds to completeness though...
With the same one. The ferrule seems not to fully match the hilt? is it slightly proud at the rear? {on the right hand side in your photo.} or is that an optical illusion? Also The rear pin hole in same ferrule seems to be missing the pin? Could it be a rework or marriage perhaps? What's your take on this?
Either way a nice piece with a beautifully forged & ground blade. & has as you say an artistic flair in design.
The claw type is truly delicious though! I think Patton picked up a similar piece when he was in North Africa? Ive never had the delight of handling one of these claw pieces.... I like them in photos though!
Quality all the way through.
Spiral
Old 25th January 2014, 01:24 AM   #4
CharlesS
CharlesS's Avatar
Spiral
Thanks for your comments.
Spiral, you are 100% correct regarding the baldric....I added it just for looks. I do not have the proper baldric rings yet...that would change everything.
The ferrule and rest are all 'born together'. There may be something in the pic that is throwing you off.
Old 25th January 2014, 09:19 AM   #5
spiral
Ahh thank you Charles.
The photo or my eyes!
Fantastic pair all round then!
spiral
Old 25th January 2014, 03:26 PM   #6
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
First; Please press into this http://www.vikingsword.com/ethsword/koummya/
Then~ a small but important resource exists on http://www.vikingsword.com/vb/showthread.php?p=81117
Salaams all Note to Library; There is here at # 1 a certain degree of craftsmanship, thus, perhaps the tag Jewish Craftsmanship applies. In the second example the design with the pointed star of David is displayed twice. In the first example the balance and artistic definition are very high...though I would attribute both to Jewish workshops.
I was looking at Koummya generally and discovered a good and plentiful web back up from which I have added the pictures below to aid research; Thus both designs are identified.
The single black horizontal dagger is described as 20th Century
Morocco - Ait Ouaouzghit region, Southwest Atlas
Steel, silver, ebony wood
Full length: 41 cm, blade length: 23, 5 cm...
The interesting postcard is circa 1900 from Forum library Oran, Algeria..
Ibrahiim al Balooshi.
Old 25th January 2014, 04:41 PM   #7
CharlesS
CharlesS's Avatar
Ibrahim,
Thanks for your images. The most valuable one is the smallest identifying hilt forms....any way to blow that up and re-submit??
The example to the left(since moved to the right) is of tourist quality as are most in the dagger pile pic.
The bottom pic is a lovely piece of quality, and an early to mid 20th century date on it would not surprise me at all.
My impression is that koummyas of this more common form are a 20th century phenomenon altogether, but with huge differences in quality. I think we would be generally correct to say the older ones are of higher quality.
That said, I have seen some lovely new examples coming out of Morocco currently and sold as new, though they tend to be oversized, and lack the elegance and charm of the older ones.
Old 25th January 2014, 05:47 PM   #8
Iain
Iain's Avatar
Originally Posted by CharlesS
Ibrahim,
It's a pity the source wasn't given before. You'll need to translate from the French but the excellent page this was taken from is: http://blade.japet.com/koummya.htm
Old 25th January 2014, 05:58 PM   #9
Salaams Iain, That wasn't my source that's why I didn't refer it as such. I just Googled it. I will work your reference into the thread.
Old 25th January 2014, 06:09 PM   #10
Ibrahim,
The example to the left is of tourist quality as are most in the dagger pile pic.
Salaams CharlesS~ No need since the original page is now identified as http://blade.japet.com/koummya.htm. A highly recommended view is urged ... It is in easy to comprehend French. I will post the relevant pictures for research as under;
Old 25th January 2014, 06:58 PM   #11
Iain
Iain's Avatar
It's worth the time to try and find the origins of the material you find via a search engine. For those that have put the effort into making the information available online and creating graphics such as these, it's the least we can do, and it also gives proper context and allows for those reading these threads to actually make use of the images you are posting.
In most cases it is not particularly difficult to ascertain, particularly using Google's image search features.
I'm glad you are now aware of Louis-Pierre's site and his work, as his pages contain well sourced material.
Old 25th January 2014, 09:47 PM   #12
archer
Default Congrats
Hi Charles, very nice finds. The narrower blade just looks like it means business. The gilt claw style has been hard for me to find and besides the gilt it looks as though the hilt is Rhino to boot. Excellent, Steve
Old 26th January 2014, 04:18 PM   #13
Salaams Iain, As I said .."I Googled it and it came up as often it does as an unrelated picture"...but now that you have very kindly pointed out the works provenance I have of course noted to thread the details for research purposes.
Some people do not have the vast resources of private libraries, nor can they afford the extortionate fees for publications. My nearest decent bookshop is about 3,000 miles away and we have no libraries here of note. Thus, I use the web ~ very often.
On occasions, if a slip is made, it is so kind of you to remind me of the correct provenance to a reference so that library can be properly served...
By the way I have a name and usually it is the courteous form of addressing Forum posts and of course signing your name at the bottom... If you have time?
Old 26th January 2014, 06:05 PM   #14
A general note to all who use Google images in the course of their research. Google images NEVER come up as unrelated pictures. That is not the nature of how a search engine works. When you single click on a picture on a google image search it opens in a larger window that allows you the option to either travel to the website of that image's origin to see it in context ("visit page") or open the image for a full-size viewing and/or downloading to your desktop ("view image"). Also, a second click on the image once opened in the larger window will also take you to the site of origin. Please see the attached screen capture below. Hopefully this information will help facilitate a more informed and effective use of images culled from the internet for our research process. Thanks.
Old 26th January 2014, 06:26 PM   #15
Salaams David,Thank you for your kind, helpful and supportive post on how the web works.
Old 26th January 2014, 06:31 PM   #16
My pleasure Ibrahiim…
Old 26th January 2014, 08:25 PM   #17
Martin Lubojacky
There were "a few" threads on koummyias and another Maghreb short cold weapons in this forum already. Let me recall this one: http://www.vikingsword.com/vb/showth...hlight=koummya
Jim put very important question (from my point of view) that time: "If there were any references which might address these which might note regional or tribal characteristics". I would be very interested in anthology on Koummiyas with tribal and place allocations etc. Many descriptions inform just about what we can simply see - kind of material used, description of the shape of pommel or handle, measurements, and dated ... often within the range of a century.
(BTW, if speaking about the quality of the blade and the age of this weapon: When I bought the forth piece from the left side /in my entry to a.m. thread - massive sheath body made of silver alloy and fully covered with small floral motives/, the wendor told me it was completely new made. But the quality of this new blade is much better than the quality of the blade of another koummiya - third from the left, which is definitely much more older ...)
Martin
