Old 25th October 2013, 08:16 PM   #1
manteris1
Default African Sword with European Mark
Hi Everyone, I have a new sword, African, Manding with a European mark. I would really like to identify this mark. The sword is 29" probably shorten......................thanks............... ..........jimmy
manteris1 is offline   Reply With Quote
Old 26th October 2013, 08:11 AM   #2
Iain
Iain's Avatar
A pity the rest of the text is faded. However, the mark closely resembles one attributed to a British based maker P. Spitzer. Since this is clearly a "G" somebody, I would guess it could be a continuation of the same workshop perhaps. The style of the head at least is a pretty good match.
G Spitzer I know from later bayonet blades, but there's probably been a lot of folks with the name over time.
Old 26th October 2013, 03:32 PM   #3
manteris1
thanks Iain...................jimmy
Old 26th October 2013, 05:40 PM   #4
CharlesS
CharlesS's Avatar
Just noticing the baldric rings are on the edge side of the scabbard meaning that more then likely the sword hung edge side up under the wearer's shoulder...that might even explain why there are no superfluous ornamental tassals, etc. attached. This sword is all business!
Old 26th October 2013, 07:47 PM   #5
archer
Default Unicorn Marks on koummiya
Jimmy, This makers mark appears on a koummiya They appear to be just initials with a period after each letter. The blade has remnants of silver plating. It's mounted in silver. I tried but, no luck as I recall finding out about the maker. Iains, suggestion may be correct. Regards, Steve
Oh, the sheath on this one has a Roman date 911 for 1911 made up of segments of coins, if I understand their system correctly. the second date looks to be 900 on another Koummiya. Please advise if I'm wrong and this this actually Arabic writing. Thanks, Steve
Old 27th October 2013, 01:09 PM   #6
Iain
Iain's Avatar
Great corroborating example Steve! I was more less taking a guess on Spitzer part, but seeing that your blade as the G.S. initials it becomes much clearer.
This would place it as a Solingen trade blade, which is about what you'd expect given the mounts and circumstances.
I've often wondered if some of these later Solingen blades started out as military pattern imports to equip local colonial forces?
Old 29th October 2013, 06:06 PM   #7
manteris1
What about the Unicorn Mark................jimmy
Old 29th October 2013, 06:16 PM   #8
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Default Unicorn Mark.
Salaams manteris.. I didn't see the unicorn though I studied it for ages from different angles thinking it was some strange alphabet... soon as you said Unicorn my brain must have triggered (left brain right brain) and now it's clear. Thank you. Was the Unicorn the mark of GS swords?
Ibrahiim al Balooshi.
Old 29th October 2013, 08:28 PM   #9
Iain
Iain's Avatar
Yes... The examples shown in this thread are unicorn marks... I would have noted this but I thought it was clear. It's a variation on an older mark with the full bodied animal.
Old 30th October 2013, 08:30 AM   #10
thinreadline
thinreadline's Avatar
G.S. written in this style is also the mark of British bayonet maker George Salter & Co . They were based in Birmingham.
Old 30th October 2013, 08:32 AM   #11
thinreadline
Hi Iain
Of course I am aware that in the 19th C , the British government used a lot of Solingen contract blade makers ( culminating in the great bayonet scandal of the 1880s ) , many of whom were based in Britai , but do you have any pictures of Spitzer marked British blades ? I have many of these contract blades but to date have never encountered a Spitzer marked one .
Old 30th October 2013, 12:52 PM   #12
Iain
Iain's Avatar
Hi Iain
Sadly I don't, the reference was from one of the blade mark compendiums. I'll see if I can post an image later on, but it doesn't offer anything beyond a sketch of the unicorn head, the name and the mention of Britain.
Old 30th October 2013, 03:17 PM   #13
thinreadline
Hi again Ian ,
I cannot locate the maker P- Spitzer but I have just checked out a ref in John Walters German Bayonets book...he mentions a Carl Gustav Spitzer 1873 - 1972 Solingen, Felder Str.
Stamp; a wide variety of marks applied including BAAS and Codex, devices used include a lion, a lion and a fish, a hammock, crossed open pocket iknives and the head of a farmer.
As you say , a late comer into the bayonet field not known to have been involved in the manufacture of edged weapons until c1938.
(Ref Walter p 158) .
Old 30th October 2013, 03:47 PM   #14
thinreadline
I enquired with a friend who has an extensive library and he has just checked the two volume set by Schlesinger of the Solingen rolls/registers and has found a Gottried Spitzer 1865 and a Hans Peter Spitzer 1719 .
Old 30th October 2013, 03:54 PM   #15
manteris1
you guys are the best....................jimmy
Old 31st October 2013, 09:08 AM   #16
thinreadline
And just to add further to the mystery .. here is an Italian pistol from the 1860s with a very similar GS on it !
Old 1st November 2013, 09:19 AM   #17
Salaams thinredline, Was that not Guillaume Scholberg of Liege ?.. Famous Belgian gunmaking family.
Old 1st November 2013, 02:45 PM   #18
thinreadline
You may well be right ..... but I have seen GS on a number of Italian guns too , including this one .
