Old 5th October 2013, 07:50 PM   #1
archer
Default 'Saidi' Style??
What are these all metal hilted Saidi-like khanjars called? This one is in great detail but pint sized are they simply tourist pocket size or meant to show skill? The minture is 7.5 inches tall. Thanks, Steve
Old 6th October 2013, 12:31 AM   #2
kahnjar1
kahnjar1's Avatar
Hi Steve, I think the one you show is probably a touristy type, as the decoration appears to be rolled into a sheet of silver.
I have one of these (pics attached) which has the decoration applied and incised into it, and is also on a nice belt. This one I believe is made for a boy hence its smaller size. I stand corrected here by those with greater knowledge than I if my belief is not correct.
Stu
Old 6th October 2013, 06:28 PM   #3
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Salaams archer. These are purely tourist/kids daggers. Made often in India and probably soon in China. Omani law now indicates that all silver traditional items should be stamped with the Omani cultural ministry insignia proving genuine and real... It can only be a matter of time for these items to be swept from the shelves... I wish... The problem is that they are not Omani having been imported like cheap toys and made on a machine that stamps them out ...The other thing to point out is that when they first started appearing they were bought as gifts for children (and in fact they still are) even by local people and now they seem to permeate shops and souks. How can I say tourist junk without offending anyone?
For correct form and detail please see http://www.vikingsword.com/vb/showthread.php?t=14878
Ibrahiim al Balooshi.
Old 6th October 2013, 07:14 PM   #4
archer
Default followup
Hi, Stu, This one displays the same degree of workmanship I like the fact yours has a belt included.
Ibrhiim, I'm a bit surprised that they are all three tourist items. I'm familiar with and agree that the pressed rolled foil ones are high profit, low labor works.
This why this forum is an ongoing learning process. Thank you both,
Steve
Old 6th October 2013, 07:36 PM   #5
Steve
Yes it surprises a lot of people however the simple rule is... Is it silver? The pressed ones (and I show examples on the thread http://www.vikingsword.com/vb/showthread.php?t=14878 are not silver but a mixture and or zinc foil. The Omanis would not buy a non silver Khanjar. Of course ~ When purchasing a Khanjar they look at it the other way around in terms of priority deciding first on the quality of blade then hilt then scabbard. In terms of tourist items they wouldn't be seen dead with one... let alone inspect it for quality.
Old 7th October 2013, 04:28 AM   #6
kahnjar1
kahnjar1's Avatar
Steve
Hi Steve, Your latest pics indeed show the applied decoration. In your first lot it looks like rolled decoration. So is it silver (as mine is) or as Ibrahiim suggests some other cheaper metal? I have seen (and handled) the foil type and they definitely are only tourist, and very easy to pick from the real thing. I would think by the look of yours that it is probably silver, so therefore maybe a boys Khanjar.
Stu
Old 7th October 2013, 04:31 AM   #7
kahnjar1
kahnjar1's Avatar
Steve
Hi Steve, Your latest pics indeed show the applied decoration. In your first lot it looks like rolled decoration. So is it silver (as mine is) or as Ibrahiim suggests some other cheaper metal? I have seen (and handled) the foil type and they definitely are only tourist, and very easy to pick from the real thing. I would think by the look of yours that it is probably silver, so therefore maybe a boys Khanjar. I note that the label on the frame states Sterling so one must assume that it is.
Stu
Old 7th October 2013, 05:51 PM   #8
archer
Default Reply
Stu, The silver one in the frame is likely a shell and just for decoration. The one I'm talking about may well be well constructed in metals other than silver, not sure. Looking at the rings one on left appears to be copper looking and plated. So it is likely a well made tourist only trade item as Ibrahiim pointed out. Steve
Old 7th October 2013, 08:39 PM   #9
kahnjar1
kahnjar1's Avatar
Hi Steve, I assumed that they were the same item. The rings could be another metal with silver plating.
As Ibrahiim states, there are many of these around now and often seen on ebay, but I think your one is better than those and COULD be a boys Khanjar. Worthy of inclusion in your collection IMHO.
Stu
