Old 20th July 2013, 04:03 AM   #1
imas560
Default Moro Punal?
I have just received a punal.
The overall length is approx 300mm (11.8 inch).
The scabbard bands and guard look like aluminium.
The ferrul looks like brass (almost like shell casing brass).
Any help in identification would be much appreciated.
The auction read as "Original Philippine Islands Punal Fighting Knife in very fine condition as acquired after WWII by a US GI.."
many thanks
imas560 is offline   Reply With Quote
Old 20th July 2013, 05:06 AM   #2
Yup - definitely looks like a Moro WWII gunong. Not unusual for these during this period to have aluminum bands and the use of brass since both were plentiful then.
Old 20th July 2013, 07:16 AM   #3
imas560
thanks Battara
Old 20th July 2013, 10:07 AM   #4
Ferguson
Ferguson's Avatar
Very nice blade. You've got a good honest piece.
Steve
Old 20th July 2013, 01:49 PM   #5
imas560
Thanks Steve
Old 20th July 2013, 04:29 PM   #6
Hello Imas,
here a gunong from the same time frame, the fittings are also from aluminium. This one is 305 mm sheathed.
Old 21st July 2013, 07:42 PM   #7
drac2k
I have often seem many fine blades with aluminum fittings, etc. and the common assumption in my local area has been that these were WW2 period produced. I have often wondered if these could be older blades, repaired or refitted with what was apparently the most plentiful, easy to work with material from downed planes etc.Did the aluminum from these aircraft have any talismanic significance to those who harvested it ?
Old 22nd July 2013, 04:14 AM   #8
Usually these have later blades of the period. No talismanic meaning to the aluminum to my knowledge, only that it is a cheap replacement for silver.
Old 22nd July 2013, 09:53 AM   #9
imas560
Very nice example thanks Sajen.
Thanks for the posts everyone.
