Old 8th May 2013, 04:20 AM   #1
Dmitry
Dmitry's Avatar
Default Straight-bladed yatagan
It's brass-mounted AND straight-bladed, both are not usual yatagan characteristics. The blade looks like it came from a 1700s broadsword, or was made in that style by a local blade-maker. I had a Saiif with a similar blade once.
The hilt is decorated with a repeated pattern of blooming flowers or vines on a stippled background. There are polished horn or bone inserts between the two halves of the grip and the tang, almost kindjal-like.
Blade is 58 cm. long. I've leafed through Asvacaturian's book, but didn't see anything remotely similar.
What are your thoughts?
Old 8th May 2013, 06:42 AM   #2
This is from the Balkans. The brass "ears" are cast and probably from the middle or late 19th century.
Old 8th May 2013, 02:30 PM   #3
Dmitry
Dmitry's Avatar
Thanks. I suspected Albania, based on the brass hilt, but there wasn't another one like it in Elgood's Greece book. Do you have a printed source for comparable pieces?
Old 9th May 2013, 12:36 AM   #4
TVV
TVV's Avatar
If I recall correctly there are similar examples in Boskovic's catalogue of yataghans from the Zagreb Museum, suggesting this is probably from the Western/North-Western Balkans.
Teodor
Old 9th May 2013, 03:29 AM   #5
Teodor
Indeed there are three within that show similarities in hilt styling...a shame they are black and white images because a lot more would be understood if they were colour.
One of the three also carries a straight blade.
Gavin
Old 9th May 2013, 06:57 PM   #6
Dmitry
Dmitry's Avatar
Thanks again!
