Old 5th October 2005, 09:50 PM   #1
Robert
Robert's Avatar
Default Small Philippine Dagger
My latest, a small "Spanish Colonial"? Philippine dagger.
Total length 11-1/2 inches
Hilt length 4-7/8 inches
Blade length 6-5/8 inches
Blade at thickest 5/16 inch
Blade at widest 1-1/4 inches
All fittings are brass.
The grip is horn with a spiral groove cut into it that is lined with a channel shaped brass strip. By the way the channel is secured into the groove at each end ( by a small nail) I also believe there might have been a twisted wire set into the channel at one time that is now missing.
As usual, all comments on this piece are welcome.
Robert
Old 6th October 2005, 03:34 AM   #2
Ferguson
Ferguson's Avatar
Hi Robert,
I can't really tell you much about yours. I have a single edged knife with a similar hilt. Supposedly the brass in the channels was to look similar to a sword hilt. Here's mine.
Steve Ferguson
Old 6th October 2005, 05:43 AM   #3
Robert
Robert's Avatar
Hi Ferguson,
At the ends of the brass channels on your knife how is the brass held in place? On this dagger there is a flat headed nail with the head being flush with the outer surface of the horn grip which leaves about 1/32 or a little more of the nail shank exposed. The nail head is not small enough to be driven down into the channel and there is enough room for a wire to easily go around the exposed nail shank. That is why I think at one time there might have been twisted white metal or coin silver wire in the channel and the nails held it and the brass both in place. I wish I had the sheath for mine like you have for yours. What are the dimensions of your knife?
Old 6th October 2005, 06:12 AM   #4
I HAVE A DAGGER JUST LIKE THAT AROUND HERE SOMEWHERE I PICKED IT UP AROUND 1965. I WILL SEE IF I CAN DIG IT OUT TO SEE IF THERE IS ANY WIRE IN THE HANDLE OR A SHEITH. I HAVEN'T SEEN MANY OVER THE YEARS SO I WOULD GUESS THEY ARE UNCOMMON. INTERESTING BLADE AS IT IS MADE TO LOOK ALMOST LIKE A SPEAR BLADE.
Old 6th October 2005, 08:29 AM   #5
I have a similar hilted katipunan bolo and the nail keeps the twisted brass wire in the handle also, at both ends.
Old 6th October 2005, 11:27 AM   #6
Ferguson
Ferguson's Avatar
Mine has a hole about the width of the groove at the end of each channel. A dowel made of horn or wood holds the brass strip in. I'll post dimensions tonight.
Steve
Old 7th October 2005, 07:15 PM   #7
Robert
Robert's Avatar
Vandoo and Battara, could you post pictures and dimensions of the examples that you have? Would anyone like to make a call on whether or not this piece is Spanish Colonial? Thanks to everyone for your replies.
Robert
Old 9th October 2005, 12:26 AM   #8
Ferguson
Ferguson's Avatar
Dimensions on mine:
14" overall
8 1/2" blade length
1 5/8" blade width
Blade thickness .240" at guard
Pic of the hilt showing the horn pin that holds the brass in.
Steve
