Old 29th November 2012, 04:21 PM   #1
CharlesS
CharlesS's Avatar
Default Minor Restoration to a Moro Kriss
I made some minor restorations to kriss I recently bought on Ebay. Some of you may have seen it there. I thought it would make a prime candidate for some minor restoration work and it turned out quite well.
The biggest problems were dirt, rust and a scabbard with very rough edges. The cleaning was easy, but the scabbard's bumped and bruised edges made me have to use and age more rattan than I wanted to.
Old 29th November 2012, 05:52 PM   #2
Hello Charles,
very well done. Can you tell us/me how you age the rattan and how you have done the binding?
Old 29th November 2012, 11:24 PM   #3
Nirghosa
Nirghosa's Avatar
I would second those questions!!
Nirghosa is offline   Reply With Quote
Old 29th November 2012, 11:31 PM   #4
Nice work, dude!
I like this form of Sulu kalis with the great scabbard carving......
Old 30th November 2012, 01:21 AM   #5
Robert
Robert's Avatar
Very nice work Charles. Like Jose I especially like the scabbard carving and the great job you have done in its repair. Keep up the good work.
Robert
Old 30th November 2012, 12:07 PM   #6
Spunjer
Spunjer's Avatar
great job, charles! what a beaut, that kalis is...
did you completely remove the rust on the blade?
Old 2nd December 2012, 02:14 AM   #7
CharlesS
CharlesS's Avatar
Thanks guys. Next time I replace and age some rattan I will do a thread on it. If I describe it without illustrating it some of you might faint!
Old 12th September 2013, 02:51 AM   #8
ThePepperSkull
I must have messed this one. Absolutely beautiful. I'm a sucker for a curvy Sulu piece.
Old 12th September 2013, 05:53 AM   #9
drac2k
Great job on the blade, which looked like it had some areas of deep pitting.Did you use an abrasive cloth? What grit if so?
Old 13th September 2013, 06:25 PM   #10
CharlesS
CharlesS's Avatar
I always try to use 600 fine grit when possible. Sometimes with tougher jobs I'll use a more abrasive grit and then finish with the finest grit, typically 600.
Some of the 3M and Ace sanding sponges do a terrific job, and they are available in a variety of degrees of coarseness.
