Have won this barong from epray recently: http://www.ebay.com/itm/120961143777...84.m1439.l2648
Any information is very welcome, age, area and so on. And have someone good informations how I can remove the shellac coating from the barong without destroy patina? Haven't received it yet. Thank you in advance, Detlef |
Very nice older barong. My guess it is from Samal. The carvings on the pommel are similar to mine and mine is Samal.
I'd say you got a good deal on that Detlef. If i had seen that auction i might have given you a bidding war.
Still looking for the right barong for the right price.
#4 | |
nice warrior's barung, detlef! are the wraps leather, or twine?
#6 | |
thank you for the hint of origin. Indeed similar carvings! Regards, Detlef |
#7 | |
I am sure you will find one by time. To be open I never have thought that I will get it by this price.Regards, Detlef |
#8 | |
Regards, Detlef |
Any suggestions how I can remove the coating from shellac?
Hi Sajen, yep nice one. Saw it but isnt my stuff. I bet the handle is 'twine' covered with black paste (resin; authentic).
To remove the shellack I would use paintremover; a tin of fluid acid that only reacts on the chemical lack but not with the organic material! Doesnt cost much and is bit acid to the skin (!). Apply richly to the handle >no worries< and wait (sometimes it take a while before working) and perhaps best is to whipe it off carefully with tissue in combi with an extra soft toothbrush for the holes etc. Or wash it quickly off with hot water (n toothbrush) and dry immediately after with tissue. Water will probably take more patine off than the 'dry tissue-whipe' method. Good luck. Btw been sawing that billiardball already?!? he he he. Would love to see you do that! Greets Wouter |
#11 | |
Hi Wouter, you have tried it before? What is with benzine? Haven't tried to saw the the billard ball until now! Greets, Detlef |
#12 | |
Hello Wouter,
Detlef, shellac is easily soluble in ethanol which will be much gentler to wood but still suck out some oils. What do you wish to remove, exactly? Regards, Kai |
#13 | |
Hello Kai, I am with you, I am afraid to use paint remover! Look to the description from the seller. He states that the complete barong is covered with shellac which I plan to remove. Regards, Detlef |
Detlef, was I you I would only try to remove the 'shellac' from the exposed parts of the silver Punto .
You get into that wood and fiber with solvent and you will have a real mess on your hands . Wood alchohol will remove the stuff from the silver with patience and a little rubbing .
Hi all, yes paintremover is quite an agressive stuff, but that is also the good think about it! One doesnt need to rub and brush and use substances that penetrate the wood etc!!!
It will just only affect the shellack and NOT the wood or organic matter and also patine. (it is like a siliconejam you put on top and does NOT penetrate materials) Meaning; one does not need to rub and brush the piece thoroughly and therefore rubbing off patine and destroying the dried out materials under. Yes I have used this myself quite often and I mostly clean it off just putting the object -already having the remover doing its work- under the (semi)hot running water and a very soft brush and dry it immediately after. Bit slight oiling of the wood and you'l see the piece come to life. Any method will take some patine off and -as a 'patineman' myself- I think this is the savest way to preserve any of that. Even if you have never dealt with it before it is quite safe but just dont put it on your hands or eyes and it does have a 'stingy' gas coming from it. But can easily and without damage be put on organic materials and be whiped away. You are becoming a handyman, arent you?!? He he. Good luck with any method you choose. Best, Wouter |
Shellac will quickly dissolve in ordinary rubbing alcohol (70% isopropyl). So you could cautiously try a bit of that; if it does not dissolve it, then it is likely lacquer or another modern coating that will require a more powerful solvent.
Thank you all for your inputs, when I have received it I will try at first to clean it with isopropyl carefully at some points to see how it works. Will keep you updated.
#18 |
I've now can post first pictures of my restore work!
I was able to remove most of the coating with acetone, no other solution want to work. I've fixed carefully the opened scabbard and started to polish the blade, one side is nearly finished with 180 grit and show already a hardened edge. The handle ferrule is worked from white brass. Here some pictures. |
#19 |
Nice work dude!
#20 | |
#21 |
Congratulations!!! Very ince work!!!
#22 | |
#23 | |
Hello Detlef,
Nice barung - I'm looking forward to the etch! ![]() Quote:
BTW, the scabbard tip is made from horn? Regards, Kai |
#24 |
Hello Kai,
thank you! No, I don't try paint remover! And yes, scabbard tip is from horn.Regards, Detlef |
#25 |
Six years between your first post and your latest!
Did you misplace it for some time; or do you have a backlog of restorations to do that is that big??
#26 | |
yes, I've noticed the same. By this you can see how fast the time went. It's the latter, there are a lot of pieces which need still care before I am happy with them. Blade polish is the hardest job which I don't like really. And some things need the correct way to get finished, so I've tried many different solutions for removing the coating from the handle and scabbard, benzine, alcohol and some other before I tried acetone. Time is another problem when you working. An ideal would be to have all items in such a good condition like this other barong: http://www.vikingsword.com/vb/showth...ghlight=barong or this dao: http://www.vikingsword.com/vb/showth...ghlight=kachin But sadly there are a lot of items which can need similar care. But I think every collector know this problem! Regards, Detlef |
#27 | |
I find that it's a lot easier to spend a little money on an item with a lot of potential than it is to spend a lot of time (polishing, which I also don't like) to make that potential happen. So yes, I too have a big back log. Have fun, Leif |
#28 |
Too many are never enough.
and: So many swords, so little time...
#29 |
Looks really good, Detlef. Lots of stuff worth buying on eBay, like those excellent keris handles and mendak you sold me.
#30 | |
Truer words have never been spoken. |
