Old 26th July 2012, 06:16 AM   #31
ah, well. did a bit more research.
armour piercing handgun bullets are made with a sintered tungsten alloy or a case hardened steel penetrator core that unlike lead does not deform when striking a kevlar jacket. the deformation of the lead projectile (even if copper jacketed) spreads the impact load even further on the kevlar layers not yet penetrated, slowing the projectile and resisting penetrating further. the pointier tungsten penetrator doesn't deform and thus can get thru more layers of kevlar.
teflon is used to protect the bore of the handgun from frictional erosion from the harder projectile. they may also be copper jacketed to aid in engaging the rifling. they are also less accurate and have a shorter effective range.
kevlar jackets that have been shot have been compromised and are replaced as further shots in the area where bullets strike have broken kevlar strands and if hit again may be penetrated. normal bullets may also penetrate up to 18 layers of kevlar armour at close range when fired out of longer (5"+) barrels. people wearing kevlar who are shot are often put out of action temporarily or even knocked out due to soft tissue injury and trauma. it's like being hit hard with a hammer. still better than being penetrated by a bullet.
the gravity powered device used in the video to impact a soft iron bodkin onto a flat steel armour plate backed by what appears to be an inflexible hard backing layer may be an over simplification of the terminal ballistics. tests with actual arrows show penetration of breastplates, tho the points were usually stopped in the padded undergarment (but would have been uncomfortable to any wearer).
the agincourt video above implies the bodkin points were soft iron and could not penetrate armour at all. contemporary accounts recorded that they could at close range. case hardening was a known technique used since late roman times, often used to add carbon to rods used in pattern welded swords. maybe the bodkins were case hardened? not terribly hard to pack a bunch of them in an air tight container filled with leather, hooves, salt and urine and heat the mix. case hardening of armour items would be more difficult. actual tests with case hardened bodkins would be interesting.
the subject of kevlar also brings to mind the old layered linen armour which would stop arrows and resist sword cuts. british archers wore padded jackets for the same reason. nothing new under the sun.
Old 26th July 2012, 08:35 AM   #32
Chris Evans
Tend to agree with your observations.
The reason that video caught my attention is that it pointed out that there was more to that epic battle than what the more popular renditions would have us believe.
Cheers
Chris
Old 26th July 2012, 09:55 AM   #33
Timo Nieminen
Timo Nieminen's Avatar
An interesting exercise on the effectiveness of the English longbow is to (a) write down the best estimate of the number of men-at-arms killed on the French side ("men-at-arms" = "armoured soldiers", so knights and other well-armoured soldiers), (b) write down the best estimate of the number of English archers. Then calculate (a)/(b), which is the maximum possible average number of men-at-arms killed per archer. Some French men-at-arms were killed by things other than arrows - at Agincourt, many (most?) of the French men-at-arms killed were killed when Henry V ordered the prisoners to be killed.
Compare this result with outcomes expected if the more extreme propaganda of arrows slicing almost unimpeded through enemy armour was true.
Clearly, the longbow, and English archery in general, was effective (at least often enough to justify the investment). Perhaps not the superweapon it is sometimes claimed to be. Better to appreciate the weapon for the reality, rather than the fiction.
Old 26th July 2012, 01:04 PM   #34
Chris Evans
Hi Timo,
At one stage of my life I played around with bows and crossbows and even owned a real English long bow. Based on my experiences, my suspicion was that as a weapon of war it was probably more effective against slowly advancing armoured infantry, rather than heavy cavalry. Galloping horses at 20mph (30ft/sec) can close the range of a bow, say 900ft in around 30sec or thereabouts, not giving all that much time to shower them with arrows, but foot soldiers would have allowed for much more time.
But, as always, troop dispositions, coordination, battlefield terrain and so on were far more important than weaponry.
Cheers
Chris
Old 26th July 2012, 04:14 PM   #35
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Hi Folks,
An interesting take on Agincourt: http://www.youtube.com/watch?v=uy7DT_FTms0
Cheers
Chris
Salaams Chris Evans ~ I think your inclusion of this video is key to understanding the battle. I was wondering when the researchers would get down to the effect of the English archers on the French Knights horses but it was somewhat glossed over however they did agree that horses were much more vulnerable since the horse armour was not steel (as was the French Knights). I think much more confusion can be attributed to French Knights horses; shot out from under them, collapsing into the mud and causing and adding to the knock on effect in the funnel. Great video thanks...
Ibrahiim al Balooshi.
Notes; In reference to Turkish weapons so that Forum may compare European with Turkish and for interest please see http://margo.student.utwente.nl/sagi/artikel/turkish/and http://turkishflightarchery.blogspot.com/ whilst at http://en.wikipedia.org/wiki/English_longbow there is an excellent description and history of the English Longbow.
Last edited by Ibrahiim al Balooshi; 26th July 2012 at 07:52 PM. Reason: added notes
Old 26th July 2012, 10:14 PM   #36
Chris Evans
Hi Ibrahiim,
I was wondering too.
Great and very informative links, especially on Turkish archery - Thank you.
Cheers
Chris
Old 27th July 2012, 12:39 AM   #37
Timo Nieminen
This leads to two interesting points: charging attackers are on the receiving end of more energy. A war arrow might be moving at 40-50m/s. A 10m/s charging speed of an attacker can transform an arrow energy of, say, 125J into an effective energy of 180J. That's a lot of extra free energy for the archer.
Second, since they're going to close quickly, save that last arrow for in close, when you'll have more energy, and won't miss. One Japanese writer wrote that the whole point of military archery is putting arrows through armour at 15m.
Soar's "Secrets of the English War Bow" has a chapter on shooting at charging enemies. Reports experimental tests of shooting at a moving armoured target. The target speed does help. And you don't get many shots. One at long range, and one at very short range.
Obstacles and field fortifications will help. Also your own spearmen, to stop attackers and let you shoot at them.
Old 27th July 2012, 02:16 AM   #38
Chris Evans
Timo,
ose quickly, save that last arrow for in close, wThis leads to two interesting points: charging attackers are on the receiving end of more energy. A war arrow might might moving at 40-50m/s. A 10m/s charging speed of an attacker can transform an arrow energy of, say, 125J into an effective energy of 180J. That's a lot of extra free energy for the archer.
An excellent observation of an often overlooked fact.
Cheers
Chris
Old 28th July 2012, 02:29 AM   #39
Chris Evans
Hi Folks,
Here is an interesting video on how a longbow may have been made: http://www.youtube.com/watch?v=fAMNN6ryZeg
Ironically, it is in French, though it must be said that self bows were known all over Europe, but only the English managed to field large enough numbers of archers to make a difference.
Cheers
Chris
