Old 10th May 2012, 01:05 PM   #1
mykeris
Default Mamas Bugis Pendokok.
Got this one, perhaps my first time encountered with this piece. Sharing pics with you all...Happy viewing
mykeris is offline   Reply With Quote
Old 10th May 2012, 01:24 PM   #2
Jean
This is a so-called "Bugis cup" by Edward Frey especially, made from brass and not mamas?
Old 10th May 2012, 01:37 PM   #3
mykeris
Hi Jean, you are perfectly right. All my bugis cups are made of brass but this one shows to contain 'low grade' gold via testing..of course, more brass content.
Old 10th May 2012, 01:39 PM   #4
Mamas is generally a silver colored metal.Mamas is not gold nor does it have any gold content. This looks either gilded or painted to me, but i doubt it is over mamas. We most often see that metal used on pendoks.
Old 10th May 2012, 01:49 PM   #5
mykeris
thanks for that info David,
Old 10th May 2012, 02:16 PM   #6
BluErf
BluErf's Avatar
I doubt this pendoko is made of pure base gold. Too much to spend on a cast pendoko. Likely to be brass which is gilded. At any rate, if it is gilded and it still retains much of the gilding, it can't have been done too long ago. I see brass showing through at the mid section of the rim.
Old 12th May 2012, 06:20 AM   #7
mykeris
Bluerf: It is small amount of low grade gold+silver...no brass. The pendokok is light
Old 12th May 2012, 08:27 AM   #8
Jean
If this is correct (gilt silver), then it is a rare and probably old piece, congratulations!
The silver base should appear more shiny by applying a silver paste or using a silver cloth.
