Old 4th February 2012, 02:49 PM   #1
A.alnakkas
A.alnakkas's Avatar
Default Making a Wooden Scabbard
Hi all,
I have this Jambiya that requires restoration. The Jambiya scabbard is made of 2 pieces but the upper side was damaged, it was also welded with 2 iron pieces and lead... some sort of a random ugly fix that nearly destroyed the piece. I took it to a jeweller and he fixed it (basically, he added similar decoration and its hard to see that its new) So now the 2 pieces are ready but I am struggling to make a wooden body to fit them on it... I tried twice and I cant shape it properly, the first try the wood was too flat and it looked pretty ugly. The 2nd, i shaped the outside properly but I couldnt put the blade in.. So I tried to thin it but the wood broke :/
Currently am using cupboard covered by a random piece of cloth. A friend told me that I can harden the cupboard by dipping it in some glue and leave it to dry.
Any advice?
Old 4th February 2012, 05:32 PM   #2
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Hi all,
Any advice?
Salaams A.alnakkas ~ Do you mean cardboard?? I wouldnt do that as it will crumble . Have a carpenter knock up a wooden sleeve and show him an already complete example ... The carpenter will easily produce a reasonable wooden core... good luck ! Regards Ibrahiim al Balooshi.
Old 4th February 2012, 06:51 PM   #3
Atlantia
Atlantia's Avatar
Hi Lotfy,
At what point of the construction of the wood formers are you having difficulty?
If it were me I'd.......
Start by selecting the wood. I don't know what type is usual, but any fairly soft but seasoned wood should do.
You want two bits obviously, one slightly fatter for the top side.
Make a cardboard template, a few mm larger than it should be, trace it onto both parts and cut them out.
At this point I'd probobly use a line of glue right down the middle to fix them together and let it dry.
Then I'd start shaping the wood. They are usually flatter on the back and more domed on the front. You don't have to get it perfect as it'll all be covered.
I'd suggest using files rather than power tools. Take it slow and get it right.
When it's 'nearly there' smooth with sandpaper.
Split the two halves and trace the blade outline. I'd use something like a dremel to cut the slot for the blade but a purist might want to use a chisel.
keep trying for fit and remember that the wood formers stop short of the top of the top silver sleeve.
When you've got the fit right then glue the two sides together and wait for ti to dry, then you can start thinking about how you want to cover the gap.
Old 4th February 2012, 08:47 PM   #4
A.alnakkas
A.alnakkas's Avatar
wa alaikum elsalam Ibrahim. Yes Cardboard.. no idea why I said cupboard lol. I went to various carpenters but they refuse to do "just that" since it wouldnt pay much you know how?
Hey Gene, Excellent advice. I bought a dremel and most of the ones I worked on were with it. I'll try one more time soon with the things you recommended.
Gav, Stu and a couple of my friends recommended leather, Stu in particular recommended a more natural goat skin with some hair left. What do you think?
I think leather is both beautiful and traditional, but somehow I love velvet which is more indian.. hmm.
Old 4th February 2012, 09:20 PM   #5
Atlantia
Atlantia's Avatar
For the exposed part of the scabbard?
All of this type I've seen are covered with some sort of hide. Thin leather of any type will probobly be OK, but Stu might well be right that Goat skin is the 'authentic' choice. Thin cow hide shrunk to fit will do though. Especially if you bind it over with twisted wire and the section of belt that they often/usually seem to have.
Old 2nd June 2012, 12:44 AM   #6
Stasa Katz
Default Making a scabbard..Poplar wood
Friends, the oldegaffer site has a very interesting step by step. Poplar was recommended.
I purchased a Choora for Oriental Arms (many bows to Artzi!) and that scabbard had a very pleasant aroma, possibly cedar (?)
http://yeoldegaffers.com/project_scabbard.asp
The process is for a European medieval sword, but the techniques may be transferable to creating scabbards and sheathes for Jambiyas and other types of blade.
http://www.google.com/#hl=en&gs_nf=1...w=1024&bih=587
Stasa Katz is offline   Reply With Quote
Old 3rd June 2012, 03:40 AM   #7
kahnjar1
kahnjar1's Avatar
I suppose I should have included a pic of a Dharia I have with goatskin used as centre section. Never too late though.................
