Old 9th August 2005, 05:17 AM   #1
M ELEY
Default Colonial-era spike axe/tomahawk
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=6193507374
Old 9th August 2005, 05:39 AM   #2
M ELEY
Picked up this nice item for a steal. I got it because it looked similar to many of the boarding axes from the early 19th century. Turns out this spike axe dates to late 18th/early 19th century and could have been carried by anyone from a soldier, trapper, frontiersman or Native American (contrary to popular belief, American Indians traded and used axes such as these just as much or more than the classic tomahawk). These early axes were weapons as well as tools and not treated as respectibly as other bladed weapons. They were badly treated and many don't survive. The blade on this one has an old rivet repair. The notch in the head might be a trap chain pull apparently used to set early fur traps. I think these items make an interesting 'ethnographic' touch to a collection, as no two are completely alike.
Old 9th August 2005, 03:29 PM   #3
Justin
Justin's Avatar
oops posted twice....
Old 9th August 2005, 03:32 PM   #4
Justin
Justin's Avatar
Very cool axe,congratulations! It seems that many cultures found that their everyday work axes worked especially well on people too.
Ive been hesitant to buy anything that could be a 'tomahawk' from ebay,it seems that this is another weapon favored by forgers and Im definately not able to tell the good ones from the not so good.
Old 9th August 2005, 04:02 PM   #5
Hi Mark , that notch may also be for pulling nails as these were a very valuable commodity in Early America and elsewhere .
In those far away times decrepit houses and ships were often burned as a way to recover the nails used in their construction .
/just speculating .
Old 9th August 2005, 04:57 PM   #6
Gt Obach
oddly.... I can't help but think that the rivet repair was actually intensional...
my thoughts are that this is the way the axe was made..
- if the axe was made of wrought iron..... which is fiberous... the fibers will split generally in the direction they are heading.....
- in other words.. the split should be perpendicular to that one on the axe..
well.. this is just my idea.......
Greg
Old 10th August 2005, 09:30 PM   #7
M ELEY
Justin-
My point exactly concerning fakes- see my post under Chinese fakes. They are getting to be very numerous. I find these particularly insulting, because they are such treasured Native American artifacts and considering what we did to them as a people, this is a double wamie...
Rick-
Excellent point as well. I forgot to mention that angle. I hadn't thought about the sheer scarcity of man-made nails back in those times. I'm told true nail production throughout the western world began around 1801, so this fits.
Greg-
Interesting point, and I don't know enough about smithing to land an oppinion. Would riviting like this have been around pre-1840 or so, I wonder? How would the rivit/plug be put in place?
Old 11th August 2005, 02:56 AM   #8
Gt Obach
Hi
it's is also possible that the rivet is a repair..... just that I have a suspicious feeling that is was made like this..
- yes... riveting would be a very well known practice back then..
- to rivet.... you basically use a punch or a drift to make the hole...... find the appropriate size round stock to fit the hole........ then pein the ends of the rivet to flare out the round stock at either end...... looks like a mushroom..... then you grind the rivet flush with the axe profile.... then use a axe drift to reshape the axe handle socket..
- ofcourse i've never made an axe like this..... but this is a possible scenario..
- my axes are usually welded up or drifted
- perhaps this was a case were the smith had no flux to weld......or maybe the smith was not experienced with welding and felt a rivet would work as well..
personally, i've seen rivets being used in areas that take a beating and hold up real well..... so it is a method of securing steel
just my opinion
Greg
Old 11th August 2005, 05:59 AM   #9
M ELEY
Thanks for the information,Greg. I just saw a naval dirk from ca.1805 with rivits through the hilt to secure it, so I see that you are right that this is a possibility. Thanks!
Old 11th August 2005, 06:26 AM   #10
Andrew
Andrew's Avatar
I don't want to get into valuations, but allow me to comment that I've seen similar 'hawks sell for obscene amounts of money.
If this is the real deal, Mark, you may have won the lottery!
Old 11th August 2005, 05:54 PM   #11
M ELEY
www.tomahawks.info/id58.htm
Thanks, Andrew. It's always nice to be reminded when we collectors get the occasional bargain. I love the axe. Here's a site I stumbled upon by accident with some of those prices (eBay prices, so some of these would probably sell for more in edged weapon catalogs). The guys on this site seem to have as much affection for their collecting area as we do, colplete with knowledge. I've definately been bit by the 'axe' bug now! Probably try and pick up a few more of these over time.
