Old 3rd December 2011, 01:40 PM   #1
chregu
chregu's Avatar
Default Military Kukri?
hello together
a friend has bought this kukri and now knew anything about it. age, origin,... etc.
I think that it is militarily, because the numbers?
Blade length 33.5ch
blades thick 10mm
greatest one width 64mm
total length 45cm
Thank you for everything.
greeting Chregu
Old 3rd December 2011, 01:54 PM   #2
spiral
Its an early 20th century British Indian Army mk.1 Pattern kukri. There quite sought after by collectors.
When dated the dates on the kukri I have seen are usualy between 1903 & 1915 although some scabbards were made at least as late as 1917.
Its worth Checking the spine & scabbard for further marks.
The blade markings probably imply use by the 2/8th Gurkha rifless as they have a penchant for marking thier kukris with soldiers & unit numbers.
Spiral
Old 3rd December 2011, 04:21 PM   #3
thinreadline
thinreadline's Avatar
Hi Spiral
I am interested to see you have IDd this as a MkI military kukri .... are there to your knowledge any refs in the lists of changes which refer to kukris and their various pattern as used by the British military ? Also how many Mks are recognised.
Thanks
Old 3rd December 2011, 04:28 PM   #4
spiral
I did this one awhile back.
linky.....
Its not perfect but it may be of some help.
There are 5 mk. or pattern kukri but obviously there were many unit purchases from private contracters & some manufacture amongst units as well.
Spiral
Old 3rd December 2011, 05:28 PM   #5
thinreadline
linky.....
Spiral
Thats bloody marvellous Spiral ! Thank you.. I now need to look again at my kukris !
Old 5th December 2011, 10:00 AM   #6
spiral
Thank you! Your to kind!
I first did it about 6 or 7 years ago & have updated it a couple of times, I will probably give it a final update early next summer.
Feel free to email or message if I can help you with any of your kukri.
{spiraltwista @ aol.com}
Spiral
Old 6th December 2011, 08:39 PM   #7
chregu
chregu's Avatar
Thanks for your help
greeting Chregu
Old 12th December 2011, 11:34 PM   #8
sirupate
A nice Mk1 there Chregu, Have you checked the spine for a FW stamp? The Mk1 seems to have potentially been made from the early20th century to around 1917.
The 2/8th were renowned for having their own battalion kukri rather than Mk issue
as this one below;
typical 2/8th GR armourer markings on a kukri;
The 2/8th were raised in 1907 from the then 7th GR, so it is possible that this kukri dates from that period, having originally been a 7th GR kukri, that was then armourer marked 2/8th upon the transfer.
For more on kukri try this link;
Link
sirupate is offline   Reply With Quote
