Old 4th September 2011, 07:40 PM   #1
Atlantia
Atlantia's Avatar
Default Interesting club (I hope)
Why oh why have I started buying these thrice damned things?
Here's my latest.
Appears to be some kind of bashing impliment.
Solid (and I mean SOLID) ancient seasoned Oak.
Like it was turned from an old ships timber.
Not rounded or flattened on the end enough to be a pestle.
Too big and heavy to be a rounders bat, too short for a baseball bat.
Lanyard hole appears to be contempory with manufacture.
Length 55cm, weight 1kg. 6.5cm wide at the end.
Any thoughts?
Old 4th September 2011, 09:35 PM   #2
KuKulzA28
KuKulzA28's Avatar
an Indian club for conditioning and exercise maybe?
Old 4th September 2011, 11:05 PM   #3
Default Fish Billy ?
Possibly a 'tranquilizer' for larger fishes .
Usually these have a lanyard hole .
Possibly an old 'gang weapon' ?
21" is too small for a baseball bat; not to mention the weight of oak .
Old 4th September 2011, 11:13 PM   #4
Atlantia
Atlantia's Avatar
Hi Rick
And too big for rounders.
But fish?
If they were this big I guess?
Old 5th September 2011, 12:10 AM   #5
ThePepperSkull
They cast Sam Jackson in everything these days.
(Interested to see where this thread develops. Quite a familiar shape but the size is a little different then what we're all used to.)
Old 5th September 2011, 12:17 AM   #6
Atlantia
Atlantia's Avatar
Here's a picture of it next to aviators for scale.
It's really chunky.
Old 5th September 2011, 01:45 AM   #7
fearn
You need something like that to kill large halibut, since they can get up to 300 pounds and can hurt people in the boat if you let them flop around.
It could also be the equivalent of one of those "ozark tire thumpers," although those reportedly have a lead center, and I don't see evidence of that in your club (I calculated the density from the figure you gave, and it's within the realm of solid wood).
F
Old 5th September 2011, 07:26 AM   #8
kahnjar1
kahnjar1's Avatar
Looks to have been turned on a lathe judging by the "ring" between the handle and the "bat".
Old 5th September 2011, 09:20 PM   #9
Atlantia
Atlantia's Avatar
It came from a house clearance of an old house here in Devon.
I still get the feeling of a reused piece of ships timber or ceiling beam. It was turned on a lathe. but possibly a fairly crude one. For sure the 'chisel' used to cut it left tiny lines, thousands spiralling around it.
It feels like its got great age.
I wondered if it was some naval or slavery item. I did a google image search for 'slavery club'......... that didn't go so well
Old 5th September 2011, 09:54 PM   #10
A.alnakkas
A.alnakkas's Avatar
LOL. I got curious and googled that... xD
Interesting club, I'd take it to a fight any day.
Old 5th September 2011, 10:22 PM   #11
kahnjar1
kahnjar1's Avatar
Hi Gene,
Is that a screw head I see at the centre of the business end? Does it serve any purpose or is it covering a hole filled with something like lead.
Another possibility is that this COULD be a Trench Club from WW1. The ones I have seen are usually covered with boot hobnails at the business end, but thats not to say that this is not one.
Stu
Old 5th September 2011, 10:35 PM   #12
Hi Gene,
surely this club would be defined as a truncheon. Oak was commonly used in Britain for both Police and Admiralty truncheons ....with so much Maritime history around your area ....and if old enough ...ex-press gang
All the best
Old 5th September 2011, 11:05 PM   #13
Atlantia
Atlantia's Avatar
Lotfy,
LOL, hope you had 'safe search' on?
Stu,
It looks like it in the pic, but it's just a hole from the crude lathe 'bit'.
David,
Thats what I was wondering. Press gang or slave trade?
Best
Gene
Edit: picture added. After a little polish (not on the Macana, thats just for scale).
Old 11th September 2011, 04:27 PM   #14
graeme gt
This is similar i am confident that its a trench club.
graeme gt is offline   Reply With Quote
Old 11th September 2011, 04:34 PM   #15
Atlantia
Atlantia's Avatar
Nice example Graeme! Can I ask the size/weight please?
Best
Gene
Edit: I just found a beyond doubt original example on the net which is dated and militarily marked. 21" long. Interestingly it has the same strange 'hole' on the end in the centre from a lathe bit. I wonder if it would have had three if it were not turned to more of a 'cone'?:
Old 11th September 2011, 05:34 PM   #16
Atlantia
Atlantia's Avatar
And mine, 21.75" long, for comparison:
Old 11th September 2011, 06:13 PM   #17
graeme gt
Here are 4 more all 18" lead filled heads dont know the weight but it would smart a bit .
Old 11th September 2011, 06:15 PM   #18
graeme gt
Here are 4 more all 18" lead filled heads dont know the weight but it would smart a bit .They should be here now.
Old 11th September 2011, 06:19 PM   #19
Atlantia
Atlantia's Avatar
Hi Graeme,
The reason I didn't initially consider trench club is the lack of studs etc on mine.
Are you familiar with other plain examples?
Mine does have the addition of having extra weight in its design to compensate for the lack of lead or studs.
Oak seems common too.
What are your thoughts?
Best
Gene
Old 11th September 2011, 06:40 PM   #20
graeme gt
Hi Gene, I dont know if its a trench club all the ones i own have some form of "doofer" on the end here is a Yank club same length as yours .Oak is common as is Beech.
Old 16th September 2011, 09:22 PM   #21
Atlantia
Atlantia's Avatar
Hi Graeme,
Hmmm, still seems like a good candidate though.
Are the pictures all yours?
Hell of a collection if so!
Thanks
Gene
Old 17th September 2011, 10:09 AM   #22
Indianajones
Indianajones's Avatar
Hi all, perhaps just a small addition to 'clarify' the holes at each ends of the clubs; they are actually the holdingpoints to keep the piece of wood staedy when turning on the woodcutmachine. Three points at each end are also common as this gives more grip on the wood when turning.
Old 17th September 2011, 11:41 AM   #23
graeme gt
All mine be carefull its addictive,
Old 17th September 2011, 11:43 AM   #24
Atlantia
Atlantia's Avatar
WOW!
Old 17th September 2011, 02:48 PM   #25
graeme gt
Hope i am not boreing you ,here are some springy ones .
Old 17th September 2011, 02:57 PM   #26
Atlantia
Atlantia's Avatar
Bore me? God no!
I'm really greatful for the help and very pleased to get to see such an amazing collection of examples.
You must have gone through some shoe leather finding so many? How long did it take?
Best
gene
Old 17th September 2011, 05:32 PM   #27
graeme gt
Been at it for years it all started with Knobkerries.
