Old 2nd August 2011, 10:32 AM   #1
Atlantia
Atlantia's Avatar
Default Like a Dha but not a Dha.....
Trying to ID a sword.
Similar to a Dha with a grass bound long wooden handle (around 27cm long) with a carved wooden bulbous pommel (slightly smaller than a pool ball) which is facetted like a crown or fircone (almost).
Simple brass ferrule, no guard.
Blade about 50cm long, V shaped near the hilt like a Dha, then curving upward from just over half way down, and getting broader toward the end to a wide flat thin 'chopper' near the end.
...... Perhaps I should draw this?
Any thoughts?
EDIT: Ok here's a sketch, reasonably close.
Old 2nd August 2011, 11:52 AM   #2
Panabas?
Old 2nd August 2011, 01:37 PM   #3
Atlantia
Atlantia's Avatar
Originally Posted by ariel
Panabas?
Excellent cheers buddy! That seems to be probable.
Old 3rd August 2011, 09:23 AM   #4
Any chances to obtain a pic, Gene?
I don't think this likely is a panabas. While some abberant panabas have been posted (try a search), the hilt seems to be off on several features.
If it does look like a dha to you, I'd guess this is much more likely to be of Burmese/Thai/Lao/Khmer craftmanship.
Is the braiding raw "grass" or worked plant fibers or finely split rattan?
Old 4th August 2011, 10:20 PM   #5
Well, as long as our opinions are based on the Atlantia's artistic talents rather than plebeian photographs, we can throw in any possibility under the sun: dha with unusual blade, panabas with unusual handle, ottoman dagger with a broken blade etc, etc.
Old 4th August 2011, 10:27 PM   #6
Atlantia
Atlantia's Avatar
LOL, sorry chaps, no chance of a picture at present.
