Old 20th December 2004, 10:32 PM   #31
ibeam
Now here is a picture of the scbbard after restoration. In this work, I cut and stained pieces of wood to match as best as possible the original wood. Some pieces, I had to recarve the design decoration to match that nearest the toe at the bottom and the "wing" at the top left hand to match the lines as best as possible. After all of the piecing and gluing, I wrapped rattan top and bottom. Perfect? - No, but better than the gaping holes that were there (whole chunks missing).
The only thing I did to the pommel is replace a small dot of ivory.
Old 21st December 2004, 01:37 AM   #32
Spunjer
Spunjer's Avatar
federico,
thx for the link! i'll definitely save that in my favorites.
battara,
quickrete sure can do some wonders
Old 22nd December 2004, 05:58 AM   #33
ibeam
ibeam's Avatar
Default Thanks Again
Thank you Battara for sharing your pictures.
Nice job on the scabbard. Very nice Jungayan barung.
ibeam is offline   Reply With Quote
Old 22nd December 2004, 10:28 AM   #34
Your welcome. I am pleased with my barong. I had to pay money and trade my clothes (well, not off my back, some PI textiles), and trade a lesser barong and a 1950 Scottish sgian dubh. But it was worth it in the end.
Old 22nd December 2004, 03:55 PM   #35
zelbone
zelbone's Avatar
Spunger, your barong turned out nice! Good job!
Battara, do you have to post pics of that barong of yours? I always get green with envy every time I see it !!! That's has got to be one the most detailed hilts I've seen on a barong! You made out well in end...it was WELL worth it !
zelbone is offline   Reply With Quote
Old 22nd December 2004, 08:56 PM   #36
Spunjer
Spunjer's Avatar
thx zel, learned from the best...
Old 12th November 2011, 11:36 PM   #37
Wow, this thread went around and around...
Thanks for pointing it out!
I have a question about sealing wax. The old one was made on the basis of shellac, ie the same "lac" that was used to secure tulwar handles.
Nowadays, all sealing waxes are based on some kind of plastic and are softer and bendable: would obviously not do the job. Or would they?
Anybody knows where to get the original dark-brown sealing wax that is shellac-based?
Could solids, such as crushed brick or just sand be mixed with it?
Old 13th November 2011, 12:33 AM   #38
A.alnakkas
A.alnakkas's Avatar
Master work!
Jose, you never thought of working on items from other parts of the world?
Old 13th November 2011, 03:20 AM   #39
Thank you very much.
I have worked on dhas, tulwars, kukris, Chinese dao, some Turkish stuff, Scottish sgian dubh, and even on US Civil War stuff.
Some of what I have worked on has been on this forum, for example:
http://www.vikingsword.com/vb/showth...hlight=battara
http://www.vikingsword.com/vb/showth...ttara+koftgari
Old 14th November 2011, 03:33 AM   #40
DaveS
I use jewlers pitch. It is black and looks exactly like what the moros
use. Just heat it up till it's soft and press it in. Unlike expoxy, when the
blade is slightly heated the handle can be easily removed........Dave
