Old 20th December 2010, 06:07 PM   #1
chregu
chregu's Avatar
Default Mongolian heavy knife?
Hi
Can anyone define more precisely the origin of this knife?
after I suspect it comes from Mongolia.
grüsse Chregu
Old 20th December 2010, 06:45 PM   #2
dennee
It looks like a Bhutanese knife. The shape of both the blade and the waisted hilt are characteristic, as are the construction and tripatite covering of the sheath. The gadrooned brass fittings ("khaser") are typical on Bhutanese edged weapons that do not use a higher-grade metal. Sheet brass is common on knives and swords that are lower grade but not solely utility examples.
dennee is offline   Reply With Quote
Old 20th December 2010, 07:56 PM   #3
definitley a bhutanese 'dossum' or 'doo zum', as noted, the faceted grip shape is a dead giveaway. yours has more of a 'sword' tip to it (swords are 'patang') and thus could be a short 'patang'. they also make these in eastern tibet, near the bhutan border - styles do blurr there a bit, but even the tibetan ones are 'bhutanese style'.
i've one, a bit more dressy:
yours is a bit more utilitarian, i like it. many older ones are made from hairpin laminated steel.
here's a photo of the current king wearing a slightly larger (and much more expensive than ours) one. note he wears it on the right side, the negative is not flipped. it's a rank thing apparently.
another link to another forum where these were discussed. the original poster is a well educated bhutanese...LINKY
best bits are on page 3. the other 2 pages are also worth reading.
Old 20th December 2010, 08:46 PM   #4
Originally Posted by chregu
Hi
grüsse Chregu
Hi Chregu,
is the grip from wood or bone? Like the others, it's from Bhutan. Nice old one. Try to etch the blade, there is maybe a lamination.
Grüsse,
Old 21st December 2010, 10:39 AM   #5
chregu
chregu's Avatar
Hi
Thanks for the information. I was so totally wrong!
have more knives from this region to determine
if you lust habt.smile.
the violation is clear wood, the forged blade has traces
processing. The blade measures 29cm wide 3.5 cm thick 8mm
Wedge-shaped.
gruss Chregu
