Old 18th October 2010, 02:51 PM   #61
Matchlock
Matchlock's Avatar
Hi Lee,
Thank you so much for deleting those posts containing erraneous thoughts that were not mine! You sure did a great job.
Michael
Old 18th October 2010, 03:02 PM   #62
Matchlock
Matchlock's Avatar
Hi Zwielicht,
The touchhole is on the right hand side of the cartrigde so that its position is within the pan where the ignition takes place, just like on any 'normal' barrel.
As I tried to point out in my thread, for as far as we know from similar 'cartridges' or exchangeable breeches preserved still loaded (I posted one specimen here), we can tell that these insertable devices only contained the powder measure and plug, while the ball was separately shoved into the rear opening of the barrel before inserting and closing the breech shut.
The measurements of the Passau arquebus are:
overall length 107 cm
barrel length 78.9 cm
length of lockplate 35 cm
caliber 1.5 cm
cartridge: length 7.8 cm, outer diameter 2 cm
Michael
Old 26th October 2010, 04:31 PM   #63
Matchlock
Matchlock's Avatar
Default Touchhole and Shutting Lug on the 'Cartridge' of a Breech-Loading Pistol of ca. 1540
Author's photos taken in the Hofrüstkammer Vienna.
Old 31st October 2010, 11:09 AM   #64
Swordfish
Hi Zwielicht,
caliber 1.5 cm
Michael
Hallo,
The chambers or cartidges of breech loading handguns were not loded with powder and plug. The attached photo is taken from an article of Zeitschrift für Historische Waffen und Kostümkunde (Volume 9 of 1922, No.4), a standard work on arms and armour, which should be familiar to any who can read German. The photo shows two chambers of breech loading handguns of the 15th Century in the collection of the Berlin armoury. Both chambers contain the original charge of powder and lead bullet. This is a clear indication that at least chambers of small bore were loaded with a lead bullet, and the bullet was not pushed awkward in the rear of the barrel before inserting the chamber.
Best wishes
Susi
Last edited by fernando; 1st November 2010 at 04:01 PM. Reason: Dispensable mode of introduction
Swordfish is offline   Reply With Quote
Old 1st November 2010, 05:24 PM   #65
Matchlock
Matchlock's Avatar
Hi Susi and welcome here,
Thank you for your interesting input from the Zeitschrift für historische Waffen- und Kostümkunde. I have been a member of their society for 30 years and own all their volumes from 1897 thru 2010.
First, these are by no means exchangebale breeches for 'handguns' but for cannon! Portable handguns of the 15th century had small bores of ca. 12-16 mm and their breech chamber never had handles; they had no grips at all and and an overall length of only ca. 6-8 cm. Please cf. the measurements of the 1540 Passau arquebus breech chamber you cited!
Second, these seem to be exceptions to the rule. For these unregulated ages, almost anything was possible in general. As I noted though earlier in this thread, we know of other loaded breech loading cannon chambers only containing powder and wooden plug, and attached I repost my own photos of one of them. The rest of the original handle can bee seen.
Similar ones were found on the wreck of the Mary Rose, sunken in 1545, also just loaded with powder and plug.
'Nando, my dear friend, would you mind posting good images and measurements of your ca. 1440 fine cannon chamber as this is almost identical to the ones preserved in Berlin?
Michael
Old 1st November 2010, 06:16 PM   #66
There you are
Bore about 30 mm.
Length 230 mm.
Width at base: 65 mm.
Weight: 3,135 Kg.
.. The wooden set up picture is a bonus
Old 1st November 2010, 06:47 PM   #67
Matchlock
Matchlock's Avatar
Thank you, 'Nando,
And congratulations!
Michl
Old 1st November 2010, 06:53 PM   #68
Matchlock
Matchlock's Avatar
Another argument for my theory that breechloading cannon chambers did not normally contain the ball:
As we can see, most of them taper and narrow towards the fore end, in order to be shoved into the barrel and tightly fit. So I think that, had they contained to ball, the latter would have been of too small caliber to match the barrel.
Any comments much welcome!
Michael
Old 1st November 2010, 07:04 PM   #69
Swordfish
Originally Posted by fernando
There you are
Bore about 30 mm.
Length 230 mm.
Weight: 3,135 Kg.
Hallo,
it doesn`t matter if these are chambers of small cannons, the
interesting fact is that they were loaded with a bullet. If even
chambers of cannons were loaded in this way, surely the
chambers of small handguns, where the chamber and barrel
have exactly the same bore, were loaded with a bullet.
Best wishes
Old 1st November 2010, 08:28 PM   #70
Matchlock
Matchlock's Avatar
Sorry,
Do you completely ignore the evidence photos I posted?
m
Old 1st November 2010, 08:37 PM   #71
Swordfish
Sorry,
m
I have never expressed any doubt that chambers of cannons were
loaded with a plug. I refer always to chambers of handguns.
Confused ?
Old 2nd November 2010, 12:05 AM   #72
Matchlock
Matchlock's Avatar
Oh yes, I definitely am.
Any evidence produced?
And why, in your opinion, should breech loading of handguns differ from cannon?
m
Old 3rd November 2010, 02:54 AM   #73
Matchlock
Matchlock's Avatar
Swordfish,
Are you there?!
m
Old 15th November 2010, 07:41 AM   #74
Spiridonov
Spiridonov's Avatar
Does anybody have photos of these breech-loading handgonne?
"breech loading handgonne, chamber missing, late 1400's. length 1,460 mm, cal 18 mm "
from
http://homepages.tig.com.au/~dispater/handgonnes.htm
Old 15th November 2010, 02:58 PM   #75
Hi Alexander.
Is this the same thing?
This is included in a PDF document with 186 pages, that i can send you by e-mail, if you are interested.
Old 15th November 2010, 03:24 PM   #76
Spiridonov
Spiridonov's Avatar
Thank you, Fernando!
Yes, I am interesting in... My e-mail is Spiridonov12@yandex.ru
Old 15th November 2010, 07:11 PM   #77
Hi Alexander,
I didn't realize the file was so heavy and not possible to send by regular email.
So i have sent it through a special email system. I hope it reaches you any time from now. When you get it please confirm that you can open the file.
Old 15th November 2010, 07:55 PM   #78
Matchlock
Matchlock's Avatar
No, 'Nando,
It's another but very similiar item, and your scans are great, thank you so much!
I attach a better image of the gun Alexender meant.
Michl
Old 15th November 2010, 08:09 PM   #79
Spiridonov
Spiridonov's Avatar
Hi Alexander,
Thank you. I have got it . Thanks for Michael too
Old 15th November 2010, 08:24 PM   #80
... and your scans are great, thank you so much! ...
Have you got the article were tey came from, Michl ?
Old 15th November 2010, 10:07 PM   #81
Matchlock
Matchlock's Avatar
No, 'Nando,
I don't.
So please try and mail me the document as well.
Michl
Old 15th November 2010, 10:23 PM   #82
On its way, Michl.
Hope it works.
DONE !
Please confirm when you get it.
Old 16th November 2010, 05:42 AM   #83
Spiridonov
Spiridonov's Avatar
Michael, I can dowload it at my FTP if you need...
Old 16th November 2010, 09:53 PM   #84
Matchlock
Matchlock's Avatar
Thank you so much, 'Nando,
I received it.
Had you told me that is was all about a series of articles in the ZWHK, I could have spared you a lot of time because I got all the original volumes and have been a member of the society for more than 30 years.
Thank you as much, Alexender, for your kind offer!
Some select assessments and termination in these articles by now have become obsolete.
Michl
Old 1st December 2010, 04:37 PM   #85
Spiridonov
Spiridonov's Avatar
We may see the thickening in the form of balls on these stock. It is a very common element of staffs in XV century.
Old 1st December 2010, 04:38 PM   #86
Spiridonov
Spiridonov's Avatar
else
Old 2nd December 2010, 01:36 AM   #87
Matchlock
Matchlock's Avatar
Perfectly right, Alexander,
Your input clearly confirms the theory I formlerly posted stating that all contemporary works of arts and crafts unanimously reflected the style common to the respective period - in short: Gothic gun barrels generally looked like contemporary architectural towers and columns!
Michael
Old 3rd December 2011, 12:11 AM   #88
Matchlock
Matchlock's Avatar
A wrought-iron breech-loading ship cannon, ca. 1480-1500.
m
Old 3rd December 2011, 12:18 AM   #89
Matchlock
Matchlock's Avatar
Two Portuguese bronze breech-loading cannon pieces, early 16th c. each, and obviously two from a series.
m
Old 3rd December 2011, 05:02 AM   #90
HERE ARE A FEW MORE PICTURES, HOPEFULLY NOT POSTED ALREADY., TWO PICTURES OF A OLD PRINT. AND DRAWING SHOWING LOAD FOR GUN.
