Old 24th December 2005, 04:31 PM   #1
Henk
Henk's Avatar
Default Three spears for comment
I bought three spears.
Any ideas about their origin?
Old 24th December 2005, 08:00 PM   #2
Henk,
They look Indonesian, except the one that looks somewhat barbed. That one puzzles me, but does look a little African to me (but just a guess).
Old 25th December 2005, 01:44 AM   #3
Justin
Justin's Avatar
I agree ,the first two are probably Indonesian,but the last barbed one could be Indonesian or African.
All nice pieces,congrats!
Old 25th December 2005, 09:10 AM   #4
Henk
Henk's Avatar
Thanks for your comments Battara and Justin,
But Indonesian for the first two puzzles me a bit.
If i compare these blades to my tombaks, they differ so much. The blades are smooth like they are polished but still wear the signs of forging. The surface of the tombaks are rough and wear the signs of etching with warangan.
The base of the blades differ also to the tombaks. The peksi of the tombak is round and the angle of the smallest blade wich is good visible is square.
My tombaks all have a round mendak shape forged ring were the peksi ends and the blade starts, but I know that not every tombak has such a methuk. At that point the blade of the tombak have edged sides while the spear blades have thick unsharp edges. Those blades look so unindonesian to me that I really doubt they come from Indonesia.
Old 26th December 2005, 04:06 AM   #5
Justin
Justin's Avatar
Not all Indonesian stuff is pamor.I am sure I have seen both the first two spears pictured in 'Weapons of the Indonesian Arch.' I could be wrong but I think they are Sumatran, and not necessarily 'tomboks'.
Old 26th December 2005, 09:41 AM   #6
Henk
Henk's Avatar
A bit too much focused on pamor, I guess. You're right, Justin. I will take a look in my books if I run up to such sumatran spears. Thanks for putting me back on earth
Old 26th December 2005, 11:09 AM   #7
Yes, Justin brings up an excellent point (again like the one on my head ). There are some spears from Borneo that also do not have pamor, or at least not noticable pamor. In fact, some Borneo tombak may be Moro or linked to Moro spears since there are Moros living on and around Borneo. This may explain the square peksi (though I have seen mostly round Moro peksi).
Old 26th December 2005, 12:12 PM   #8
Henk
Henk's Avatar
Justin and Battara,
You guys are completely right. I've been stupid and ignorant. I just looked through the book by Van Zonneveld and guess what? Just search the page with spears and you know enough. The most beautiful examples in wich the first two spears just lovely would fit in. Those two probably come from Sumatra or Borneo.
Thanks again guys for opening my eyes.
Has anybody still an idea about the third one? The spear mouth, if i may call it that way, is wrapped with copper wire.
Old 26th December 2005, 04:26 PM   #9
Justin
Justin's Avatar
Glad to help, .
The third one is tricky. The barbs make me think its African,and it may well be,but overall it seems Indonesian as well,if you bought it with the other two then I would suspect it may be from the same place as the first two.
They definately had barbed spears next door in the Philippines:
http://www.aiusa.com/medsword/rila/krieger.html
Old 26th December 2005, 04:34 PM   #10
I would tend to agree with Justin, although one might at first glance think Africa, I am not sure. In the dark back of my mind I think I have seen a picture of something very similar but cannot quite think where. I think it is very nice. Tim
Old 27th December 2005, 05:18 AM   #11
The 2 reasons I would vote for Africa for the last one is:
a) the barbs and they manner they are pointed
b) as opposed to many Indonesian and Philippine spears and weapons, Africans make more use of pure copper and copper coil wrap
BTW - the spears that do have barbs from the Philippines are from the Igorot tribes of Luzon and point in one direction.
Old 27th December 2005, 02:30 PM   #12
Henk
Henk's Avatar
Yes, the link shows barbed spears with the barbs in the same direction indeed.
I bought the spears together with some sumatran pieces, but also the yagathan I showed in another thread and that possible Phillipine dagger was in the buy and a kukri. It was a bit of a mix.
The haft of our "african" spear becomes thicker after 20 cm. The middle part is 82 cm long and ends in a thicker end of 26 cm. I think the haft is bambu although it hasn't the bambu knots. But color and feeling of the wood gives me the idea of bambu and it looks like the tree parts are stuck into each other and are attached very firmly. The haft is old and not a recent replacement.
Old 19th August 2010, 09:42 AM   #13
erikscollectables
erikscollectables's Avatar
The first is Batak to me the second also North Sumatran - maybe Aceh or also Batak - the third is a riddle....
Old 19th August 2010, 01:33 PM   #14
The third spear does seem African to me.....possibly a Zande 'makrigga' . There seems to be a fine wire 'woven' collar, which is similar to some decoration found on African weapons.....could you post a better picture of the 'collar' ?
Regards David
Old 19th August 2010, 07:15 PM   #15
Henk
Henk's Avatar
David,
I hope these pictures give you the information you want. And of course I hope you can enlighten us
The shaft could be cane like Rick mentioned in the other thread of texspearchunker. Or maybe an african bamboo specie. The typical bamboo knots are missing on this shaft.
Regards, Henk
Old 19th August 2010, 09:01 PM   #16
Hi Henk,
that is the type of wire-work I have seen on a few African spears....the wire 'coiled' (spring like) around a central wire and then wrapped around the shaft. However, I am sorry I cannot remember the origins of those spears at the moment ...will do some 'digging' The very fine wire wrapped above is probably 'telephone' wire or coil windings from small electric motors. I do not think it very old ....my guess around mid 20th C.
Kind Regards David
Old 19th August 2010, 09:42 PM   #17
Henk
Henk's Avatar
David,
Hope you can dig up the info. Would apreciate it very much.
The very fine wire is yellow copper also. Was telephone wire or coil windings from small electric motors not red copper wire? I used to break up some of that stuff in my younger years with friends in an attempt to do some technical time spending I cann't remember seeing yellow copper wire in those things then.
Your age guess could be very correct. It would surprise me if this one is much older.
Thanks and regards, Henk
Old 19th August 2010, 10:39 PM   #18
Actually many southern Sudanese spears did use bamboo, and from I understand this was from Nuba regions. This barbed style spear does seem to resemble some Sudanese spears, though it does seem rather sheet like steel and more likely fairly modern. Interesting on the coiled wire also, and how surplus or salvaged materials are always put to use in these ways, incredibly industrious.
It does seem that Zande, as David suggested might be quite possible also, as they are situated in regions of southwest Sudan, along with Congo regions in the northeast part, and the influences mentioned might well be a factor.
All best regards,
Old 20th August 2010, 08:55 AM   #19
Henk
Henk's Avatar
Jim,
Thank you for your input. Although the blade is rather thick it isn't as far as i can see a forged blade but a sheet like steel blade like you noticed.
Old 21st August 2010, 01:30 PM   #20
Hi Henk,
check this out.....notice the decoration
http://www.vikingsword.com/vb/showth...ighlight=gille
and this page.....scroll down (approx. 1/4 page)
http://www.ezakwantu.com/Gallery%20A...%20Weapons.htm
Regards David
Old 21st August 2010, 03:14 PM   #21
Henk
Henk's Avatar
Hi David,
Awsome. So it is Somali, Danakil, a ceremonial spear.
Great!! Thanks David!
Regards, Henk
Old 21st August 2010, 04:04 PM   #22
Hi David,
Regards, Henk
You're very welcome
Regards David
Old 23rd August 2010, 03:21 PM   #23
Andy Stevens
Andy Stevens's Avatar
Hello folks, we thought these pictures of some of our new arrivals might be of interest. We've got them marked down as Somali or Danikil. The beatiful wire bound head in the lowest picture we've had a while and the quility of the workmanship is superb. The hafts on all appear to be wood.
Regards Andy and Karina
Andy Stevens is offline   Reply With Quote
