Old 18th July 2010, 07:48 PM   #1
Default Another question about etching
I have been using a new bottle of the RadioShack etching fluid ( ferric chloride), diluted ~1:5. Took a soft cloth, soaked it, passed in a single movement over the blade (polished, washed, dried, alcohol defatted), and after ~10 seconds, washed it with copious amount of water , then sodiuim bicarbonate, then water again and dried it. From the beginning to the end it took no more than 1 min.
I got a wootz pattern ( pretty feeble), but the entire blade became grey.
What should I do to:
1. Enhance the pattern? More concentrated etcher? Longer exposure?
2. Eliminate the grey color? Rub it with rough felt?
Old 18th July 2010, 11:52 PM   #2
Hello Ariel,
Please post a pic or 2...
Is the blade expected to be wootz?
Old 19th July 2010, 02:32 AM   #3
Also what kind of water - distilled I hope? Did you also use baking soda afterward?
Old 19th July 2010, 10:33 AM   #4
Ferguson
Ferguson's Avatar
I've had wootz blades that didn't respond well to FeCl. They used nitric in the past I think. I've never used it. Very dangerous stuff.
Steve
Old 19th July 2010, 01:16 PM   #5
Thanks to all!
Both blades are unquestionable wootz: very weak pattern seen.
Yes, distilled.
Yes, baking soda ( sodium bicarbonate)
What %% nitric acid? How long?
And, if the rest of the blade is still grey, any rubbing afterwards or some other method?
Old 19th July 2010, 02:17 PM   #6
Originally Posted by ariel
Thanks to all!
Yes, distilled.
Ariel,
You speak the lingo and will find this a help.
http://playground.sun.com/~vasya/Obach-01.html
It works for me and as noted, is very dangerous, I mean very, be careful.
Gav
Old 19th July 2010, 03:41 PM   #7
Gav,
You are brilliant!!!!!!!
Many thanks.
Old 19th July 2010, 04:23 PM   #8
Default Happy to help
Happy to be of service, please send me the results and or post them here, I am interested to see how you got on with it...I am eager to know if it is the Kilij you were restoring some time back.
Gav
Old 21st July 2010, 09:18 AM   #9
ALEX
ALEX's Avatar
Thanks for the link, Gav! You're brilliant indeed!
Ariel, I'd recommend in this case not to keep FeCl on the steel for long, and instead do many short sessions in this manner: clean and polish the blade, etch and as soon as you see the colour change to yellow - stop, clean the yellow residue with steel mesh (not sandpaper!!!) with a drop of dishwasher liquid, clean and repeat the cycle. could take as many as 10 cycles or more, but it will work. The yellow residue will prevent etchant from developing the pattern, so you must remove it before each etch. Repeat until you see the improvement, clean with water and apply oil to the blade.
The yellow residue is indicative of particular quality of wootz, not the etchant.
Old 22nd July 2010, 12:11 AM   #10
By steel mesh you mean steel wool?
Also: how dilute should be FeCl?
Old 22nd July 2010, 12:23 AM   #11
Thanks Alex.
Ariel, Alex is indeed correct, this method works well too, though I fast tracked it a little...I'm not the most patient man. See the results of one Amanremu I have here from the Kelling Hall collection. This is a method I used to show the 'Wootz' or 'Wootz like' Inserted edge.
Fine 0000 grade steel wool is my choice.
Dilution, well, I ain't to scientific.
Gav
Old 22nd July 2010, 12:29 AM   #12
ALEX
ALEX's Avatar
sorry, it is steel wool of course.
1:5 is ok, no need to dilute more.
