Any comments or info on this one?
According to the seller this was a worldwar II bringback, and untouched for the last six decades (kept in the closet). Because of the patina I guess it was also a long time untouched before the person brought it back! Note the old restoration of the crest, that has been broken off a long time ago! Metal bands on the handle, probably brass (or some kind of brass alloy). In between woven fiber bands. After cleaning the brown varnish of the blade (which was on the blade) and a slight etch with hot vinegar, already nice laminations popped up. Maurice Last edited by Maurice; 16th April 2010 at 08:02 PM. |
The blade looks Sulu while the scabbard looks Maranao. The little okir I can see beneath one of the bands also looks Maranao. Not unheard of, lots of trade between these regions.
The scabbard looks well carved .
Can we see a picture or two of the recarved crest area please ?
Oops! Forgot to upload the image of the crest I referred to!
Here it comes Rick!
By the way, the metal bands look more like tarnished silver, not brass.
Hi Maurice,
very nice old kris also when the crest of the pommel is missing. Hope that I can own one day such a nice kris! Do you have tried to polish the metal? Regards, Detlef |
#7 | |
On the bands in the middle (the two smaller onces) there are some traces of green assessment, which is also seen on those brass lantaka's. But at the other hand the lowest one looks more "white". Now I am in two minds......if it is silver I want it to get polished........and if it would be brass I like this kind of patina........
#8 | |
#9 | |
I like the broken crest where the old restore is visible. I rather like them this way and don't want it to be restored (but tastes differ). I am sure that it is possible to find one. I was looking for this one for quite some years, and believe it or not, after chasing after morocollectors to get one like this, epray was the solution afterall.... ![]() I didn't polish the metal, I just sanded the blade to get rid of the surficial rust and black spots/pitting. I attached two more images of the cleaning/etching result. Kind Regards, Maurice |
Hi Maurice,
two missunderstandings! I also like the pommel like this and also don't would like to restore it. And by polish the metal I mean the bands at the pommel, try to polish only a small part where it is not visible direkt to see which metal you have there when you don't have silver test fluid.
Hi Sajen,
Yes I see now when reading it back! But whilest typing my last comment responding yours, my wife was already with her coat on ready to go, telling me to hurry up!!.........I guess that will be everywhere the same! So my mind was split in two pieces: At one piece it was reading and typing, and at the other half assuring my wife that it didn't take long anymore before shutting my laptop! Kind Regards, Maurice |
#12 | |
#13 | |
Thus I am shocked that there would be some green patina. If brass, it is obvious, but if silver, don't be surprised that some green patina might be present. |
Hello Maurice,
Congrats, that's a really sweet 19th c. blade - really like this Sulu style! Quite typical with a length of 20.5 inches, too. Nice etching job! ![]() Also love the small pommel style as you know... Did you tried a bit of wax on the scabbard to get a less dry look of the wood? (As well as offering a bit of protection from the low-humidity in-house.) Regards, Kai |
#15 | |
Hello Jose,
BTW, I remember that Maranao silverwork as found on hilts got exported to the Sulu archipelago, too. However, Sulu kris with imported Maranao parts would sport Sulu scabbards, no? Regards, Kai |
#16 | ||
Maurice, have you tried the "cold" needle test to gauge the malleability of the metal? Regards, Kai |
#17 | ||||
#18 |
Regards, Kai[/QUOTE] cold needle test ? do you practice voodoo , Kai? can you explain what you mean with that test?
#19 | |
I know what Kai means because we had a "non forum" conversation about silver and silver alloys a time ago. Kai means that it could be worth trying pricking it with a steel needle at an inconspicuous place. Low grade silver is tougher though and less easy to differentiate from nickel silver, etc. Maybe Kai can add or correct me if wrong or not complete! |
#20 | |
#21 |
If you hear a kris screaming in the other room, you'll know why...
#22 | |
#23 | |
That pin on the crest might not have been a restoration. Maybe it was there at the initial carving of the ivory, pinned the crest for added support, and then the crest broke off with much handling. I have a Kris with a bone kakatua pommel that has pieces of the crest pinned together. I'll post a photo when the sun rises. |
#24 | |
I am looking forward to the photo about the piece with the crest pinned together! |
#25 |
Here are a couple of photo's of the kris that I mentioned.
Both of them had pins holding the kakatua's crest in place. The pin on the ivory might have been inserted as a repair because the crest has a break in multiple places. The smaller bone kakatua, you can clearly see that the pin was used to hold the stacked pieces of the kakatua's crest at the onset of the carving. |
#26 |
Albert you have a good point (like the one on top of my head
) about the pin holding the rest in place. I now see what you are saying and the pictures you post help, thank you.
#27 | |
Are the pins in both your krisses metal or wood? Maurice |
#28 |
Maurice, I believe the pins are brass , definitely not wood.
#29 | |
That would never be strong enough to hold different pieces together.. Maurice |
#30 |
Maurice, I think an ivory "nail" would be able to hold small things together, in this case, a small crest to the pommel.
