Hi All,
Save for the unusual fullers and grooves at the base, the blade is typical (albeit well done) but I have never seen a hilt with a pommel like the one on this kris. To me it looks more Bagobo or T’boli-ish than what I would expect on a conventional kris. (If the hilt were a good deal larger and slightly more crooked, it would do well as a French dueling pistol grip.) The wood, very finely grained and almost without figure, isn’t binate or anything else I am familiar with. Before examining it with a hand lens, I had suspected that it was dyed horn. There are some carved designs where the hilt wrap ends and also on the pommel. Although the wood of the hilt is in perfect condition, I believe that the blade and hilt have been together for quite some time because the baca baca strap has worn almost completely through the hilt wrap on the back side and the strap on the underside has worn through a bit also. Specs: Blade; about 21.5” (54.6cm) long Hilt; about 6” (15.2cm) long Ferrule; very pale yellow (almost white) brass Hilt Wrap; fine cord Baca Baca; appear to have a high nickel content because they are only weakly magnetic Baca Baca Straps; apparently copper Sincerely, RobT Last edited by RobT; 17th December 2023 at 05:24 PM. Reason: extra period & word deleted |
I'd vote for Moro, Rob!
Looks all Moro to me too. That 20th C grip wrap is usually seen on Sulu kris.
These are Moro pieces from my collection. I believe these are Seko or horse hoof hilts and became more popular after the fall of the last sultanate. With that said I’m definitely open to input and wisdom from others that can shine more light on the subject.
Here are two more in a similar style.
Another. The carving is nicely done.
