Old 1st March 2020, 12:11 PM   #1
David R
David R's Avatar
Default latest spear head aquisition
This one turned up at a collectors meeting, just as I was looking for something like it. The square-ish tang makes me think Philippines, but the narrow, hollow ground section gives me pause for thought. It is very much a stabber and mail piercing blade rather than the broader bladed spears that seem more typical.
I punched it through some card to show the X section more clearly.
Old 1st March 2020, 02:33 PM   #2
drac2k
I would almost guess that it was a Japanese yari spearhead if it wasn't for the tang configuration. Nice blade whatever it is.
Old 1st March 2020, 08:40 PM   #3
Kmaddock
Kmaddock's Avatar
Hi
Do you think the tang has been worked on as it Looks to be very small in relation to the blade
I would have taught if it was mounted in a shaft the leverage of the blade would pop the tang out of the ide of the shaft quiet easily
I taught yari also when I first saw the photo.
Ken
Old 1st March 2020, 08:57 PM   #4
David R
David R's Avatar
It does look small, but so are the tangs on most Philippine spears. Like you say, they look too small, but I see the same on a lot of ethnic blades.....
Below is an example posted on this site some time ago.
Old 4th March 2020, 08:35 PM   #5
Hi David,
You are not getting much help with the Philippine origin (or otherwise) of your spear head, and I'm thinking that is because the hollow ground nature of the blade is causing people to scratch their heads a bit. I find it odd for a Philippine spear, but perhaps it is a rare variant. At the same time, I can't think of a clear alternative origin.
Ian.
Old 4th March 2020, 08:54 PM   #6
David R
David R's Avatar
This is exactly why I posted it, it does not look like the run of the mill Budiak, though I have seen some of them get close..... It is very much an armour piercing blade, and some Moro did wear armour!
At some point I will give it a scrub and an etch, and see what comes out.
