Old 19th August 2017, 08:46 PM   #1
DaveA
DaveA's Avatar
Default Help Identify - Indonesia?
I recently picked up this knife at auction. The hilt makes me think of an origin in Indonesia, but the blade I do not recognize. The knife is well made, balanced, blade firm with no play.
Description:
- OAL = 10 3/8 inches
- Blade length = 4 5/8 inches, the first 1 5/8 inches are unsharpened false edge
- Blade thickness = 3/8 inches, tapering to 1/8 inch
- Blade Top is straight
- Blade edge has a broad sharpened bevel grind on one side only, the other side flat.
- Blade cross section is flat.
- Blade width broadens from 5/8 inch at hilt to 1 inch at the end of a false edge, then narrowing as it sweeps upward to the tip. This false edge is chisel grind (both sides)
- Bolster is brass in one piece roughly matching cross section of the hilt and with two raised ring portions nearest the hilt.
- Hilt length is 5 3/4
- Hilt cross section is a flattened oval with edge along bottom aligned with the blade and rounded on top
- Hilt material is dark hardwood with slight greenish hue
- Hilt design motif is floral with carved portion 3 inches long and 1 1/2 inches wide at the wides portion.
Your thoughts please?
Best Regards,
Dave A.
Old 19th August 2017, 09:21 PM   #2
Hello Dave,
it was very long on my watch list ( ) and like you I think it's from Indonesia or maybe Malaysia but I can't name it and also don't know from where it is exactly. But I know that I like it! Sorry that I can't be from better help. But I think that the hilt isn't from wood but from horn, I am nearly sure.
Old 19th August 2017, 09:34 PM   #3
DaveA
DaveA's Avatar
Default hilt material
Thanks. Malaysia is an interesting thought.
The hilt might be horn. That was my first thought. It doesn't seem to have the right grain when I look at it under magnification. I have not cleaned this item yet so perhaps there are more clues lurking beneath the dirt.
- Dave A.
Old 19th August 2017, 10:15 PM   #4
Hello Dave,
This might be a woodworkers tool (artisanal carving knife, possibly doubling as an EDC).
As suggested, it possibly may be Malay (including the coastal communities of Sumatra and neighbouring islands).
I'm also inclined to believe the hilt is from kerbau horn.
Old 20th August 2017, 03:00 AM   #5
Default Kind of Like?
http://www.vikingsword.com/vb/showth...o+womens+knife
Old 20th August 2017, 03:29 AM   #6
This blade style is widespread in SE Asia, the chisel edge permits a very sharp edge when correctly sharpened. Ideal for splitting rotan and similar materials. M'ranggis use this type of knife for general purpose work, I have several that I use for bench work.
The area of origin is probably going to be determined by the hilt:- ID hilt style, ID knife.
In Bali today these knives are called temutik.
My guess for this one would be Lombok. It is a guess.
Various sizes, ages, qualities:-
Old 20th August 2017, 08:54 PM   #7
DaveA
DaveA's Avatar
Default Horn
Originally Posted by kai
Hello Dave,
After cleaning and looking more closely at this an other examples, I now agree it is horn. The greenish color I have not seen in water buffalo horn before, nor is this example as dark black as others. I suppose this is just natural variation.
Old 20th August 2017, 09:34 PM   #8
DaveA
DaveA's Avatar
Default Hilt curves up
On further thought, I'm not yet convinced about the identification of this knife as pemutik/temutik.
I cannot find a pemutik example with a similar hilt that curves upward and away from the sharpened edge as this one does. Also, this hilt cross section does not match the typical symmetrical elongated barrel shape either.
Would you call this floral hilt design puntung? It is much more elaborate than other examples I can find on the forum or elsewhere on any knife.
- Dave A.
