Old 10th January 2016, 06:26 PM   #1
Default An antique Thai enep
Not long ago I purchased a very neglect enep from Thailand, this is what I think it is. Like always I could be wrong but think that I am correct.
After some intensive maintenance it turned out that it is a very nice little knife. So I think that it is worth to share it with you.
First three pictures from the seller.
All comments are welcome.
Old 10th January 2016, 06:32 PM   #2
Here some pictures after it was received.
Old 10th January 2016, 06:38 PM   #3
Here some pictures after I have given it care. Could it be that the handle is from rhino horn?
Old 10th January 2016, 08:00 PM   #4
harrywagner
harrywagner's Avatar
Default Nice
Wow. You did an amazing job of restoration. Any tips you can pass along regarding how you did it? Thanks for sharing. An interesting knife. An amazing restoration job.
harrywagner is offline   Reply With Quote
Old 10th January 2016, 08:31 PM   #5
Thank you Harry for the kind words but I wouldn't call it restoration, I've just cleaned it up.
Since I was able to pull up over the brass bands from the scabbard I was able to clean the wooden scabbard inside since it is built from two parts of wood. The wood from outside I've polished with car polish and oiled it. The fittings I've cleaned with 000 steel wool and metal polish. The ferrule was a difficult project since I want to protect the dark patination from the iron part, so I've polished it with 2000 sandpaper and WD40. The horn was polished with car polish also and oiled with linseed oil.
The heavy corroded blade I've sanded with sandpaper, started with 120 up to 1000.
Old 12th January 2017, 11:45 PM   #6
Question
Hello Detlef,
Sorry, I missed this thread a year ago.
I don't think so; however, we need a close-up of the end grain, i. e. the tip of the pommel, to verify.
Old 13th January 2017, 02:46 PM   #7
CharlesS
CharlesS's Avatar
Nice job Detlef! Nothing's more fun than bringing a worn, neglected piece back to life, and you have done it well!
Old 13th January 2017, 05:40 PM   #8
Thank you Charles and I agree complete with you! A great fun is it to see that I was correct to buy this knife because I've known about the outcome.
What's crazy, the blade is worked from a very good steel, there are no deep pittings left from the hard corrosion and that the blade is still extreme sharp after the cleaning.
Old 13th January 2017, 05:32 PM   #9
Hello Kai,
I am not sure as well, it's difficult stuff, every rhino horn I've handled has had a different look. A close up of the handle top isn't helpful since it's cone-shaped and glossy patinated.
Old 13th January 2017, 06:20 PM   #10
Hello Detlef,
Color, translucency, feel, and surface texture vary a lot with rhino (and age and storage conditions of the pieces). Only the microstructure can be relied on.
One very rarely has a nicely orthogonal cut of the end grain; usually we can deal with it though. Just give it a try...
